Crackling sound when watching youtube... - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 08-16-2019, 11:42 AM - Thread Starter
Rep: 1 (Unique: 1)
My build
3700x
Aorus x570 pro
Corsair Vengeance lpx 3600c18 (2x8)
GTX 1070 MSi Gaming X
Win 10 1903
Mobo bios version F4K
Every driver installed
Here's the video
It happens almost every few seconds. I loaded optimized settings in bios and it's still happening
CaptnJones is offline
post #2 of 13 (permalink) Old 08-16-2019, 01:32 PM
upgraditus's Avatar
Rep: 8 (Unique: 6)
Check sampling rate and bit depth, anything above 16bit 44.1KHz/48KHz is a waste. They often default higher which can cause issues with certain formats. I had issues with FH4 audio being garbled since it wanted 48KHz and defualt was 96KHz on the AE-5 (bit rate didnt matter in this case but can). Mute unused inputs as they can lead to noise even without something plugged in. Other than that you also have at the time in this video both discord and skype going through windows mixer so be sure to rule out other potential noise sources.
Between the background music, talking and screen tapping it's pretty hard to notice crackling in that video btw.
= Ryzen 7 3700X 4.3GHz @ 1.3v / Thermalright TS140 BW / Prime X470-Pro / 16GB Crucial BSLT 3733 MT/s cl16 / 1080Ti Amp Extreme 2GHz @ 0.987v / Aerocool Project7 P650 / Fractal Define XL =
upgraditus is offline
post #3 of 13 (permalink) Old 08-16-2019, 02:40 PM - Thread Starter
Rep: 1 (Unique: 1)
Doesn't help still the same crackling audio
what about now?
edit: tried to play the vid on the tablet and the crackling can't be heard
Have the same issues in FH4
post #4 of 13 (permalink) Old 08-17-2019, 04:46 AM
upgraditus's Avatar
Rep: 8 (Unique: 6)
what about now?
Spoiler!
Was this on a clean OS install?
New vid it's much more noticeable, but you still have multiple things going into sound mixer (VLC, Skype etc). I understand that is normal operation and should work, but for troubleshooting you're just adding more variables.
latencymon doesn't look happy, see lots of dxgkrnl latency / sound related issues in google...
Forgot to say in first post to try disable unused audio devices.
Just to confirm this is happening with the onboard audio? With this driver: Realtek Audio Driver / (Note) Win10 ver.1903 supported. / [6.0.8688.1] / 18.64 MB / 2019/06/14 ?
I'd uninstall the audio drivers and run with just basic windows hdaudio driver to see if it still chokes, if it works fine then you could try the driver from realtek
post #5 of 13 (permalink) Old 08-17-2019, 10:29 AM - Thread Starter
Rep: 1 (Unique: 1)
Yes clean windows install. onboard audio - X570 Aorus Pro
I tried to disable other audio soruces, uninstalled all audio drivers,...
Nothing helps
edit: I've reinstalled windows and still the same fecking problem.
I don't know what to do anymore. Spent over 1000€ and this is what i get
tyvm AMD
edit: a new error
******* hell
post #6 of 13 (permalink) Old 09-21-2019, 02:55 AM - Thread Starter
Rep: 1 (Unique: 1)
After 1 month of waiting i finally received my replacement - they replaced both the board and the cpu. So far no issue *knock on wood*
Though i'm still not seeing the proper boost speeds even after updating to latest bios. 4.391Mhz is max im getting on 2 cores
post #7 of 13 (permalink) Old 09-21-2019, 04:16 AM
Meep
Gilles3000's Avatar
Rep: 299 (Unique: 220)
The latest bios' still have reduced boost speeds, a fix should come soon.
Gilles3000 is offline
post #8 of 13 (permalink) Old 09-21-2019, 06:22 AM
rdr09's Avatar
Rep: 863 (Unique: 631)
Prolly your BCLK is lower than 100? Typical of Ryzen motherboards. On my Asus mobo, it is set at 99.8, so boost clock is slightly lower the 4200 on my R5 3600.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #9 of 13 (permalink) Old 09-22-2019, 01:06 AM
Rep: 0
Same issues here. Was blaming it on Windows 1903. You say it was the board or cpu?
Cidious is offline
post #10 of 13 (permalink) Old 09-22-2019, 02:28 AM
Working as Intended
Filters83's Avatar
Rep: 0
This is annoyng im also having problem ... i already did like 3 fresh windows 10 install and picked up another cpu... this is at stock bios setting
__________________________________________________ __________________________________________________ _____
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:03:47 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: FILTERSPC
OS version: Windows 10 , 10.0, version 1903, build: 18362 (x64)
Hardware: ASUSTeK COMPUTER INC., ROG STRIX X470-F GAMING
CPU: AuthenticAMD AMD Ryzen 5 3600X 6-Core Processor
Logical processors: 12
Processor groups: 1
RAM: 16300 MB total
CPU SPEED
Reported CPU speed: 3793 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 509,50
Average measured interrupt to process latency (µs): 4,050631
Highest measured interrupt to DPC latency (µs): 507,70
Average measured interrupt to DPC latency (µs): 1,794898
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 845,948326
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,066809
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,081888
ISR count (execution time <250 µs): 115953
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 151
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1171,137358
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0,032665
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 436.30 , NVIDIA Corporation
Total time spent in DPCs (%) 0,085702
DPC count (execution time <250 µs): 550260
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 514
DPC count (execution time 1000-1999 µs): 1
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: winstore.app.exe
Total number of hard pagefaults 9620
Hard pagefault count of hardest hit process: 2025
Number of processes hit: 82
PER CPU DATA
CPU 0 Interrupt cycle time (s): 21,896339
CPU 0 ISR highest execution time (µs): 845,948326
CPU 0 ISR total execution time (s): 2,187103
CPU 0 ISR count: 108593
CPU 0 DPC highest execution time (µs): 830,449776
CPU 0 DPC total execution time (s): 1,980629
CPU 0 DPC count: 506109
CPU 1 Interrupt cycle time (s): 18,439638
CPU 1 ISR highest execution time (µs): 99,242816
CPU 1 ISR total execution time (s): 0,039809
CPU 1 ISR count: 3677
CPU 1 DPC highest execution time (µs): 604,964408
CPU 1 DPC total execution time (s): 0,026684
CPU 1 DPC count: 4352
CPU 2 Interrupt cycle time (s): 10,361659
CPU 2 ISR highest execution time (µs): 14,717110
CPU 2 ISR total execution time (s): 0,002944
CPU 2 ISR count: 710
CPU 2 DPC highest execution time (µs): 1171,137358
CPU 2 DPC total execution time (s): 0,175021
CPU 2 DPC count: 22781
CPU 3 Interrupt cycle time (s): 18,196513
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 391,170577
CPU 3 DPC total execution time (s): 0,003478
CPU 3 DPC count: 776
CPU 4 Interrupt cycle time (s): 13,565146
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 759,358819
CPU 4 DPC total execution time (s): 0,117791
CPU 4 DPC count: 10278
CPU 5 Interrupt cycle time (s): 18,131496
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 354,863696
CPU 5 DPC total execution time (s): 0,005291
CPU 5 DPC count: 895
CPU 6 Interrupt cycle time (s): 8,143666
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 588,584234
CPU 6 DPC total execution time (s): 0,010417
CPU 6 DPC count: 1979
CPU 7 Interrupt cycle time (s): 8,678053
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 23,873978
CPU 7 DPC total execution time (s): 0,000227
CPU 7 DPC count: 48
CPU 8 Interrupt cycle time (s): 4,695076
CPU 8 ISR highest execution time (µs): 5,419984
CPU 8 ISR total execution time (s): 0,001166
CPU 8 ISR count: 2363
CPU 8 DPC highest execution time (µs): 447,093593
CPU 8 DPC total execution time (s): 0,006082
CPU 8 DPC count: 1245
CPU 9 Interrupt cycle time (s): 4,449077
CPU 9 ISR highest execution time (µs): 1,162141
CPU 9 ISR total execution time (s): 0,000006
CPU 9 ISR count: 9
CPU 9 DPC highest execution time (µs): 21,148959
CPU 9 DPC total execution time (s): 0,000130
CPU 9 DPC count: 38
CPU 10 Interrupt cycle time (s): 5,444198
CPU 10 ISR highest execution time (µs): 1,933562
CPU 10 ISR total execution time (s): 0,000208
CPU 10 ISR count: 490
CPU 10 DPC highest execution time (µs): 406,719220
CPU 10 DPC total execution time (s): 0,008545
CPU 10 DPC count: 2105
CPU 11 Interrupt cycle time (s): 5,259441
CPU 11 ISR highest execution time (µs): 1,773267
CPU 11 ISR total execution time (s): 0,000159
CPU 11 ISR count: 262
CPU 11 DPC highest execution time (µs): 24,885842
CPU 11 DPC total execution time (s): 0,001030
CPU 11 DPC count: 169
Filters83 is online now
