First build, ryzen 3600 critique - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 08-19-2019, 05:33 AM - Thread Starter
Rep: 0
Hi guys,
First time builder here. Wanted some feedback on my setup.
- fractal design focus G case
- Ryzen 3600
-noctua U12S SE-AM4
-MSI X570 pro carbon wifi- was supposed to get the gaming edge wifi, but micro center screwed up and accidentally gave me an upgrade... i cannot complain, getting a $250 mobo for $169.
-g.Skill ripjaws V F4-3200C16D-16GVKB 16-18-18-38
-Samsung 970 evo m.2 SSD 500GB
Asus rog strix OC 1660TI
-EVGA G3 650w power supply
only area where i wish i had done more research is with the ram choice. Fortunately its using the samsung B die, and i should be able to squeeze out better timings in the future.
Was aiming for a sub $1100 PC and i was able to succeed
Sent from my SM-N960U using Tapatalk
sigfan86 is offline
post #2 of 8 (permalink) Old 08-19-2019, 03:24 PM
polar's Avatar
Rep: 41 (Unique: 34)
Looks good,first build and no issues that is a good start.I have seen some pretty bad first attempts and yours is not one of them.
One thing I would test is on cases with open vents in the top and no fans,I find it disturbs the airflow through the case.I would look at the vrm temp the way you have it then block the top 2 vents off and do the same.If you have any spare fans install one in the top blowing down on the vrm heat sinks.
Airflow is always up for debate but gives you something to mess with if you want.
3700x & H80iv2
Gigabyte x570 Gaming X F3 Bios
4x8 Team Dark 3200 14-14-14-31
Gigabyte 2070 OC
860 Evo 500 SSD m.2
Evga G3 850
Matrixx 70
polar is offline
post #3 of 8 (permalink) Old 08-19-2019, 06:27 PM - Thread Starter
Rep: 0
Thank you. I was definitely nervous building it, but it's a lot easier than i thought.
I willd definitely check that airflow issue out. My work always has spare pc components getting tossed, I'll see if i can get some 120mm fans from them to test with.
sigfan86 is offline
post #4 of 8 (permalink) Old 08-19-2019, 06:44 PM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
You were pretty lucky both with the RAM and motherboard...
Fractal really needs an updated Focus G case :S
It's missing minor things such as cable grommets , easily accessible bottom filter, a second USB 3.0 port instead of one USB 3.0 and one USB 2.0 (basically you waste one port from each header), and slotted rear fan mount.
Right now the top aesthetic / "newness" contender at <$79 is the Phanteks P400A but the Meshify C is currently selling for ~$67 which is well worth the price. The minor price increase over the Focus G would have been worth it unless you needed 5.25" bays.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #5 of 8 (permalink) Old 08-19-2019, 07:24 PM - Thread Starter
Rep: 0
In regards to the case, i agree. I kinda jumped the gun with that one, i wanted the meshify, but due to ordering from Amazon and wanted to get all my parts in asap, i got my second choice,impatience on my part.
The grommetless through holes aren't that bad actually, the metal is rolled in that area, and the risk of cutting wires are slim.
As to the motherboard, your 100% right. The gaming pro motherboard is actually pretty bad with VRM temps.
Havent heard many things about the carbon, both good or bad. But it's stable and my temps are showing normal on hwmonitor.
The ram prices kinda shocked me, and i went with the cheapest 3200 speed ram i could, since the ideal speed ram kits are $180+.
Do you have any recommendations once i decide to move up in ram quality?
sigfan86 is offline
post #6 of 8 (permalink) Old 08-19-2019, 08:20 PM
⤷ αC
AlphaC's Avatar
I think it's better to upgrade the CPU to a Ryzen 7 (which has all cores enabled in the CCX) in the future than to mess about with RAM.
X570 Pro Carbon is using 10x 56A Ubiq QA3111 Dual-N Fets (powerblocks that integrate high+ low side mosfets) instead of 8x Onsemi discrete mosfets on Edge / Gaming Plus. This means they aren't as good as powerstages but better than discrete mosfets. The only problem with the X570 Pro Carbon is the pricing (should've been cheaper given the Aorus Elite/Asus TUF/Asrock Steel Legend) and the VRM heatsink is pretty bad in terms of area and the plastic covers. It has intel LAN , ALC1220, wifi Ax, USB 3.1 gen 2 type C, etc. The other vendor boards at $250 have SLI support and the X570 Pro Carbon doesn't because it's using a 4 layer PCB that can't be certified SLI support with PCie 4.0.
If you can get it I would try to get the AIO promotion that MSI has. You already saved a lot of money, but it is worth a shot.
https://www.msi.com/Promotion/I-Love-You-3000-AMD
AlphaC is offline
post #7 of 8 (permalink) Old 08-20-2019, 12:40 AM
Senior OCN Member
shilka's Avatar
Rep: 2740 (Unique: 1626)
The SSD you bought is way overpriced and you could have gotten an SSD almost as good for much less so you should have asked before buying
https://www.overclock.net/forum/355-...2-toshiba.html
As for the PSU you should be aware that it has a problem with fan noise when its used in eco mode
https://www.overclock.net/forum/31-p...e-problem.html
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #8 of 8 (permalink) Old 08-25-2019, 07:57 AM - Thread Starter
Rep: 0
Not really sure how much cheaper an m.2 SSD could have been, I got it for $79 on an Amazon sale.
But even so, i wanted a samsung drive due to their reliability and much higher performance.
I know crucial mx500 is the new hottness, and ill probably give that one a try when i need another ssd
sigfan86 is offline
