Ryzen 7 1700x/AsRock AB350 pro4 RAM question - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 09-16-2019, 06:30 AM - Thread Starter
Noctua Fan
Cysquatch's Avatar
Rep: 73 (Unique: 48)
The last couple months Ive been upgrading parts, It seems like my RAM is the next in line. Right now I'm using Gskill F4-2400C15D-16GVR. I managed to overclock it to 2666 and it has been stable in my use case. Looking at my motherboards memory QVL there isnt much for options @ 3200 mhz. Most is B-Die and most of the listed part numbers are out of stock. It seems like most of the RAM that is on the QVL is 3000 mhz supported. Is it worth upgrading mine for 334mhz? Thanks
edit: Am I maybe putting too much emphasis on the QVL? Do I grab a set of whatever RAM and hope it runs good?
Cysquatch is offline
post #2 of 2 (permalink) Old 09-16-2019, 01:31 PM
FX-5000
ShrimpBrime's Avatar
Rep: 67 (Unique: 48)
Probably not worth getting new memory. Some B350/B450 boards don't clock memory so well. (it's not the chip or RAM)
You could try the Ryzen memory calculator https://www.overclock.net/forum/13-a...ram-bench.html
ShrimpBrime is offline
