Ram issue please help - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 10-20-2019, 10:45 AM - Thread Starter
browny2911's Avatar
Rep: 0
Okay so i recently upgraded to a 3600 from a r5 1600. Since then the bios was weird with overclocks and the voltage stock was all over the place, So i set a stable overclock on ryzen master, I benched it, stressed it and ran it for a few days without any issues. Since upgrading ive manged to finally run my ram at its rated 3200mhz speed. I thought because i had bad luck with my bios OC my cpu id try overclocking the ram further in Ryzen Master. However upon restarting it wouldnt boot. I reset the cmos, and booted and then just saved bios and booted the pc, which is just keeps failing. However If i do that process of reseting the bios and then going into the bios and without saving just exciting and continuing the PC boots fine. However now my Ram is only running at 2133mhz, and if i change the settings back to D.O.C.P in bios the pc fails to boot. I tried unistalling ryzen master completley and re-doing the process however the pc wont boot. Any ideas how i can set the D.O.C.P in bios with the pc booting, seems like something set previously on ryzen master is conflicting with it, even though the bios and ryzen master have been completley un-installed, aswell re-installing and having all the settings turned of for ram and set to auto as default.
Any thoughts?
browny2911 is offline
post #2 of 5 (permalink) Old 10-20-2019, 11:07 AM - Thread Starter
browny2911's Avatar
Rep: 0
Okay, i re-installed ryzen master a third time, and set all the settings for my ram into ryzen master, Its now working at 3200mhz again, Strange problem, and i don't understand how this work, seems like it kept saving settings from either my bios or ryzen master conflicting with each other, Ill try to do it through bios and never touch it again afterwards
post #3 of 5 (permalink) Old 10-20-2019, 02:50 PM - Thread Starter
browny2911's Avatar
Rep: 0
However, now i keep getting crashes in games like overwatch, in which i never had any issues before this happened, any thoughts?
post #4 of 5 (permalink) Old 10-20-2019, 02:52 PM
rdr09's Avatar
Rep: 863 (Unique: 631)
Try adding some voltage, If stock is 1.35v, up it to 1.36 - 1.37v.
Best bet is to use the DRAM Calculator if still not stable.
https://www.overclock.net/forum/13-a...ram-bench.html
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #5 of 5 (permalink) Old 10-21-2019, 12:02 AM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 2 (Unique: 2)
Any thoughts?
Which Ram and mobo?
  • Ryzen 3600x @4300 v1.34
  • Gigabyte Aorus Elite x570
  • G-SkillLL F4-3200C15D-16GTZ Trident Z Series CL15 Bdies @3733 16-15-15-1T 1.39v
Offical Ryzen 5 3600x Owner!
rastaviper is offline
