Oh look another super low budget Ryzen build - Page 6 - Overclock.net - An Overclocking Community
post #51 of 54 (permalink) Old 02-11-2020, 03:03 PM
AMD K6-2 500MHz
neurotix's Avatar
Rep: 341 (Unique: 196)
Quote: Originally Posted by damric View Post
This motherboard is really weird. It has two BIOS chips, but no dip/toggle switch to manually select them. Basically one just acts like a backup if for some reason the other one gets corrupted or just won't automatically rest itself after a bad overclock. The guy who sold me the board had F10 BIOS on both chips (1st Raven Ridge BIOS). I tried out a few of the newest BIOSes and none of them allowed any better overclocking headroom, actually worse. When I pushed a bit too hard is when I noticed the backup BIOS switch over as it put me back on F10. That got me wondering if I could somehow manually switch back and forth between the BIOS chips, but with no manual switch and no selection within the BIOS itself, it looked like it wasn't possible. I did a lot of googling and finally I found an obscure forum post that said if you hold in the reset switch and power switch for 10 seconds while powering up, that it would switch the BIOS chips. I was skeptical, but I tried it, and it works like a charm. So now I can easily switch back and forth between different BIOS revisions, which will make it possible to enable PCIE 4.0 on the fly if I upgrade to Ryzen 2 since this board has that capability despite being X370.
My current 24/7 overclock: is now 3.875GHz and RAM at 3466MT/s CL14. Rock solid with the F10 BIOS.
In other news, we actually had a cold snap for 1 day last week, where we actually had some winter-like temperatures in the morning, about 33 degrees F, opposed to the 65-70 that has become the new normal for the gulf coast this time of year. I took advantage of this and ran benchmarks like crazy. I was even able to validate a 4.1GHz overclock.
Nicely done
Put the Vega64 in.
Ryzen 9 3900X @ 4.5GHz CCD0 1.375v VID OC, 4.2GHz CCD1- 1900Mhz fclk/uclk
ASUS ROG Crosshair VIII Hero BIOS 1201
EVGA GTX 1080ti FTW3 2025/5940MHz
EVGA RGB SLI HB Bridge
G.SKILL Flare X B-Die 3200 C14 @ 3800MHz C14-16-15-15-30-48 1T 1.475v GDM off
Samsung 970 Evo 500GB m.2 2280 PCI-E NVMe SSD
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Samsung 840 Evo SATA 256GB
COOLERMASTER V1000 (Seasonic 1000w 80+ Gold)
Arctic Cooling Liquid Freezer II 38mm 360mm AIO
Anidées AI-AUREOLA RGB fans x7
Prolimatech PK-3 Nano 30g tube
Anidées AI CRYSTAL AR3 RGB Midtower
Operating System
Debian Linux 10
Operating System
Win10 X64 Pro 1903 (gaming only), stripped down, updates blocked, Firewalled.
LG 34WN80C 34" 3440x1440 21:9 IPS, 300 nit, HDR
Keyboard
GMMK v2 104 key | Kailh Box Jades | HyperX PBT pudding (for now)
Keyboard
OCN Ducky DK1008 MX Blues
Keyboard
Corsair K70 Lux red led/MX Reds
Keyboard
Rosewill K85 RGB Kailh/Kaihua Blue switches
Keyboard
Ducky One 2 RGB fullsize
Mouse
Redragon Chroma M710 RGB (Omron Switches)
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Logitech Z2300 2.1 120w 8" sub, w/ 40w satellites
Other
Phanteks RGB 5050/Digital RGB strips
Other
Respawn Black/Gray Racing Chair
Raspberry Pi 3B
Optical Drive
DENON DCD-560 CD Player, dual integrated 20bit Burr Brown PCM61P DAC's
Operating System
Kodi 17.2
ASUS V238H 23" 1080p 60 Hz
Audio
Pioneer SX-255R Receiver, 4x 100w
Audio
TECHNICS SB-A32 Floor Standers, 4x8" polyurethane woofers, 100w/cabinet, 1" His and 3" Midrange
Audio
Polk Audio PSW-505 300w subwoofer, replaced woofer with CT SOUNDS TROPO 12" 4Ω DVC car sub wired in series, 8Ω, 300w
Audio
Kenwood GE-4030 Stereo Graphic Equalizer
Audio
TECHNICS RS-T18 dual tape deck
Motorola 68000 @ 7.8MHz
Macintosh SE logic board
Macintosh SE analog board (provides voltage + timing to CRT)
None. Graphics generated by ROM, OS and 68k (sans fpu)
NEC Electronics 80ns 9-chip 1MB SIMMs (four, 4MB total RAM)
FloppyEmu Ver C in clear case, front-mounted, 500MB HFS .dsk file
Optical Drive
Sony 800KB Double-Sided floppy disk drive. Cleaned and relubricated
stock, 75W
Single fan. Very small. (25mm?)
Cage in the case itself provides convection cooling.
Macintosh SE, platinum color, Snow White design language
Operating System
System Software 6.0.8 w/ Multifinder
Operating System
System Software 7.1 (rarely used; needed for Macintalk 2 speech synthesis)
9" 1-bit (black and white) CRT, 512x342, 58Hz
Keyboard
Apple Desktop Bus Keyboard 1 (cleaned and restored.)
Mouse
Apple Desktop Bus Mouse 1 (cleaned)
Audio
Mono Speaker
Other
"Macintosh Toolbox" 128Kb ROM chip- accelerates OS/System calls
Other
Replaced soldered 3.6V PRAM battery liable to explode/leak w/ 3V lithium coin cell meant for Gameboy games.
neurotix is offline
post #52 of 54 (permalink) Old 02-12-2020, 04:54 AM - Thread Starter
Turtle Lives Matter
damric's Avatar
Rep: 431 (Unique: 332)
Quote: Originally Posted by neurotix View Post
Nicely done
Put the Vega64 in.
Oh I would but it's tied up in my other computer which runs more demanding games at 4k.
Of note, my RX570 can play the new HALO game at 4K maximum detail at a constant 60FPS. We were testing it yesterday. That game is incredibly optimized and looks great.
Borg Cube
(16 items)
Sky OC
(10 items)
R5 1600(14nm) @4100MHz
GA-AX370-Gaming K5
XFX RX 570 4GB
Ripjaws V @3466CL16
VPN-100 NVMe
Rosewill CAPSTONE (SF GG)
TCP-612
2x EVGA FX 120mm Fan
2x Cooler Master MasterFan Pro 140 Air Flow
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Xonar SE
Audio
Logitech Z623
Z170 K4/D3
Vega 64
2x8GB RipjawsX
Silicon Power A80
Supernova G3
i7 Stock Cooler
Aerocool Bolt
Operating System
10 Pro
Samsung 58" 4K
damric is offline
post #53 of 54 (permalink) Old 02-12-2020, 08:44 AM
AMD K6-2 500MHz
neurotix's Avatar
Nice! Another game I would think would run well is Forza Horizon 4. I don't even normally play racing games, as you probably know, I mostly play WRPGs and JRPGs, action/adventure, and not many fps to be honest.
Its really well optimized, but unfortunately in my case tends to crash in the menus while tuning cars (driving/races are fine). Its usually while saving; fortunately the changes I make to a cars parts stick but I have to reopen the game.
I've heard it runs better on AMD and seen that a Vega64 outperforms the 1080ti by a solid margin in it (+15%)
Gameplay wise its impeccable; really really well done. The only racing game I ever got addicted to (Aside from SEGA Outrun and Super Hang-On arcades) is Tokyo Extreme Racer 2 on Dreamcast. This is a very similar style game with every aspect of the car tunable, and racing for money to upgrade or buy new cars. It also has like 400 cars or something, all licensed from real manufacturers, and isnt just limited to Japan Domestic Manufacturers cars like in the old TXR2.
Anyway, if you can get it on sale and you have any interest or ever played any older games in this style (Burnout Paradise on X360 and NFS Underground are similar) it'll keep you busy for weeks
Also gonna be doing a keyboard build in my build log so keep your eyes on that too. https://www.pcgamingrace.com/product...l-brown-switch
Got that and will be changing switches and keycaps
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Operating System
Debian Linux 10
Operating System
Keyboard
Keyboard
Keyboard
Keyboard
Keyboard
Mouse
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Other
Other
Raspberry Pi 3B
Optical Drive
Operating System
Kodi 17.2
Audio
Audio
Audio
Audio
Audio
Optical Drive
stock, 75W
Operating System
Operating System
Keyboard
Mouse
Audio
Mono Speaker
Other
Other
neurotix is offline
post #54 of 54 (permalink) Old 02-14-2020, 10:52 AM - Thread Starter
Turtle Lives Matter
damric's Avatar
Ok so another update.
Last year I replaced my beloved Rosewill Capstone 550W (Super Flower Golden Green) in anticipation that I would be doing all of these upgrades, and the for the fact that it's been running hard almost 7 years. After owning that PSU, I have really been wanting to try the LEADEX or LEADEX II platform, so I ordered the EVGA 650W SUPERNOVA G3 which is based on the LEADEX II.
Some things I like about it. It's smaller, so it's easier to run cables than my bulky Capstone. It has a 10 year warranty so this unit will likely last through a few rebuilds. The ripple suppression is very tight. Now I wasn't sure if it was the better ripple filtering or the extra 100W capacity, but my RX570 maximum stable overclock with my Capstone 550W is only 1415/2125, and with the SUPERNOVA 650W I could do 1437/2130. I would figure out more later.
In a fortunate turn of events, I was able to score a good used condition Radeon VEGA 64 from the Techpowerup forums. The thing is, I really needed to put that card in my downstairs HTPC because we play way more intensive games at 4K on that computer, and none of my mid-range cards were cutting it. Of course to power that pig I had to pull my new SUPERNOVA back out of my main rig and match it with the VEGA. All is well on that HTPC. Meanwhile CAPSTONE went right back in my main rig.
But my main rig also pushing a 4K monitor, I still plan on a more powerful graphics solution. I've had a couple good offers for a dirt cheap RX 570 that I could pair in crossfire, or I might save up and get something like a 5700XT. Either way, PSU needed first, so as soon as they went on sale again this month, I ordered another SUPERNOVA, but this time a G3 750W, and I'm glad I did. I installed it yesterday. We had some cool weather this morning so I fired up some benchmarks to test out what it could do. Now my RX 570 can push 1450/2130, so I assume it's just a power sucking beast when overvolted and overclocked to the silicon limits.
In summary very happy with these SUPERNOVA PSUs.
Borg Cube
(16 items)
Sky OC
(10 items)
GA-AX370-Gaming K5
XFX RX 570 4GB
Ripjaws V @3466CL16
VPN-100 NVMe
TCP-612
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Xonar SE
Audio
Logitech Z623
Z170 K4/D3
Vega 64
2x8GB RipjawsX
Silicon Power A80
Supernova G3
i7 Stock Cooler
Aerocool Bolt
Operating System
10 Pro
Samsung 58" 4K
damric is offline
