New AMD system keeps BSOD'ing. Please help me troubleshoot - Overclock.net - An Overclocking Community
post #1 of 43 (permalink) Old 10-25-2019, 01:49 PM - Thread Starter
Rep: 2 (Unique: 2)
Hi guys, I would be very thankful for input on how to troubleshoot my build. Any ideas and feedback is very appreciated. I have tried alot of things to get this rig stable in windows 10, without luck. This is the third fresh Windows install, and just dont wanna play ball. I have double checked that all cables are well connected. Double checked that all components are seated correctly in the motherboard. Things I havent tried ; Testing if its stable running Linux. Resetting CMOS. Updating to newest BIOS (bios was updated to newest in June 2019).
Stress tests run
OCCT CPU test - pass
Memtest 12 hours - pass
Unigine Heaven + Valley - pass
Realbench 2.43 Multiple runs - pass
Crystal disk mark and Crucial's own disk utility report zero problems with the ssd. - pass.
Symptoms
Windows BSOD : NON PAGED AREA, KERNEL POWER, many more and many different bsod messages. No real pattern.
PC can get stuck in loops, where one BSOD will trigger multiple new ones. Until Windows boots in start up repair. Windows will eventually boot and then on boot tell that its rolled back some updates.
Windows will sometimes on boot report that AMD whatman crashed.
The PC has some lucky streaks, if not rebooted; I've had windows running for a few days at best without powering down. Somehow, I feel our problems are boot related. And driver related.
It is more likely to crash while casually browsing the web or handling files, than under load (gaming).
Bios settings applied
Optimised Defaults.
Enable A-XMP.
Tried upping SOC voltage to 1.05 - no luck.
Tried setting Manual Override (constant) voltage 1.375v - no luck.
Tried running adaptive voltage with an offset (Maxing out around 1.375v). - no luck.
GPU running stock.
CPU boosting to around 3900 without touching mutipliers or anything regarding the clock.
Software run
Bios : 7A40vA6
OS : Windows 10 pro 64 bit.
Various games; Prey, Sekiro, doom 2016, DIshonored 2, Overwatch, Starcraft 2 can be stable for hours without crashing. Usually the PC appears the most stable under gaming sessions.
Max temperatures observed under load
CPU : 71c.
GPU : 68c.
Drivers installed
In sequence, with reboots between each install. All drivers listed on MSI's website for the board.
AMD chipset drivers. - clean install.
AMD GPU driver. - tried both DDU and clean install.
Realtek PCI-E Ethernet Drivers.
Realtek High Definition Audio Driver.
Components
PU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($117.59 @ OutletPC)
CPU Cooler: ARCTIC Freezer 33 eSports ONE (Black/White) CPU Cooler ($98.24 @ Amazon)
Motherboard: MSI B450I GAMING PLUS AC Mini ITX AM4 Motherboard ($124.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory ($77.98 @ Amazon)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive ($61.99 @ Amazon)
Video Card: Sapphire Radeon RX 580 8 GB PULSE Video Card ($178.98 @ Newegg)
Case: Phanteks Enthoo EVOLV ITX TG Mini ITX Desktop Case ($87.98 @ Newegg)
Power Supply: SeaSonic FOCUS Plus Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply ($95.89 @ OutletPC)
Case is maxed out with fans. The best airflow combo for this case. Any help would be much appreciated. I am really at my wits end trying to get Windows 10 stable on this hardware.
appylol is offline
post #2 of 43 (permalink) Old 10-25-2019, 01:56 PM
criminal's Avatar
Rep: 695 (Unique: 426)
Do you have other memory to try? Also, have you tried running it on another SSD?
I have a big bang house. I had all the materials for my new house brought in and dumped on a vacant lot. I took a stick of dynamite, lit the fuse on fire and tossed it into the pile of materials. BOOM went the explosion and when the dust settled I had a new house! Amazing isn't it?
Super P's Rig
(21 items)
Noahman
(9 items)
Ryzen 7 3700X
MSI MPG X570 GAMING PRO CARBON
Gigabyte RTX 2070S
XPG Spectrix D41 3600MHz
Samsung 850 EVO
MyDigitalSSD SBX
WD Black 500GB NVMe
EVGA SuperNOVA 850G2
Bykski CPU-XPR-AM
Phobya Balancer 150 Reservoir
XSPC EX280 Radiator
TC-A - CPU Liquid Cooling Pump
XSPC EX360 Radiator
Phanteks Pro M TG
Operating System
Windows 10
MSI Optix AG32CQ
Keyboard
G710+
Mouse
G305
Mousepad
Vipamz Extended XXXL
Audio
Sennheiser HD 439
Audio
Asus U7
5960X
Asus X99
MSI R9 380 Gaming
V-Color Skywalker 16GB 2666MHz
Kingston SSDNOW V300
EVGA 500 W1
CoolerMaster 120MM AIO
Fractal Design Define S
Operating System
Windows 10 Pro
criminal is offline
post #3 of 43 (permalink) Old 10-25-2019, 02:04 PM - Thread Starter
Rep: 2 (Unique: 2)
Hi, thanks for stopping by. No this is the only DDR4 kit i have. But I've tried running it without setting xmp. Optimised defaults + JEDEC 2133 Mhz without luck.
SSD is a SATA MX500 512GB. It appears to be fine, according to monitoring software. Could try swapping in another ssd, I have a few on hand
appylol is offline
post #4 of 43 (permalink) Old 10-25-2019, 03:35 PM
Why is it smoking?
Mr. Mojo's Avatar
Rep: 359 (Unique: 295)
It's worth a shot, and I'd also recommend swapping the SATA cable. A bad cable can cause all kinds of random problems.
Black Feathers
(22 items)
AMD Ryzen 7 3700x
Gigabyte x570 Aorus Pro Wifi
Sapphire Radeon RX 5700 XT
Crucial Ballistix Elite DDR4 3600
Sabrent Rocket NVMe PCIe 4.0 M.2 2280
Sabrent Rocket NVMe PCIe M.2 2280
Seasonic FOCUS Plus 750
EK-KIT Classic RGB P360
EK-Vector Radeon RX 5700 +XT RGB - Nickel + Plexi
Arctic P12 PWM PST
DEEPCOOL RF120M
XSPC G1/4" Inline 10k Sensor, Chrome
EK-CryoFuel Solid Cloud White (Premix 1000mL)
Lian-Li PC O11 Dynamic (white)
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio Technica ATH-M50x
Audio
Logitech Z333
Intel Core i7 4710HQ
NVIDIA GeForce GTX 970M
16GB DDR3L
Samsung 850 EVO
HGST Travelstar 7K100
Operating System
Windows 10
BenQ XL2720T
Keyboard
Microsoft Sidewinder X4
Mouse
Gigabyte M8000X
Mouse
Steelseries
Audio
Audio-technica ATHM40x
Audio
MTX iX1 Headphones
Mr. Mojo is offline
post #5 of 43 (permalink) Old 10-25-2019, 03:39 PM
Destrto's Avatar
Rep: 80 (Unique: 63)
Kernel power can sometimes mean insufficient power from PSU. My guess would be your PSU isnt strong enough for the components you are using.
EK Club XCrossXFire ClubX
-OCN Water Cooling Club-
Destrto
AMD FX-8370
MSI 990FXA-Gaming
AMD PowerColor RX 580
G.Skill - Ripjaws X Series 16Gb
G.Skill - Ripjaws X Series 16 GB
Samsung 850 500Gb
Seagate 3 Tb
Raidmax Vampire 800 Watt
EK-Suprema​cy MX CPU ​Block
XSPC 240mm​ Radiator
EK-XRES 140 DDC 3.2 PWM Elite
HBT Gravity6
Destrto is offline
post #6 of 43 (permalink) Old 10-25-2019, 03:41 PM
Hardware Princess
Hydroplane's Avatar
Rep: 31 (Unique: 26)
Yeah but that would probably show up as soon as he hits a stress test
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #7 of 43 (permalink) Old 10-25-2019, 03:55 PM
Destrto's Avatar
Not always. I had a similar issue with mine when I had 2 R9 380's in my system. Would only occur during certain games being played. But would pass a stress test fine.
Destrto
AMD FX-8370
MSI 990FXA-Gaming
Samsung 850 500Gb
Seagate 3 Tb
HBT Gravity6
Destrto is offline
post #8 of 43 (permalink) Old 10-25-2019, 04:03 PM
Hardware Princess
Hydroplane's Avatar
It's possible as the GPUs would pull way more power than the CPU. Ex. my old Q9550 could run P95 all day 4ghz, but would hard lock after a few minutes of gaming. At stock settings, it would fix the issue. Turns out the 12v rail on the PSU was drooping badly. It could support ~150W from the CPU but would drop down quite badly when the ~300w from the GPU were applied. Replacing the PSU fixed the issue. But OP is able to run Heaven/Valley with stability so I'm not sure if that's it, in this case.
CHILLER DESTRUCTION
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #9 of 43 (permalink) Old 10-25-2019, 04:14 PM
Destrto's Avatar
The RX 580 he's running recommends at least 550 watts just for that alone. I would bet the issue is the PSU is underperforming..
Destrto
AMD FX-8370
MSI 990FXA-Gaming
Samsung 850 500Gb
Seagate 3 Tb
HBT Gravity6
Destrto is offline
post #10 of 43 (permalink) Old 10-25-2019, 04:39 PM - Thread Starter
Rep: 2 (Unique: 2)
Hey guys, appreciate the feedback.
Gonna try a new SATA cable, for sure.
About the PSU. Its a Seasonic Gold brand new. CPU should pull 100w max GPU 200w. I wouldnt think the PSU would be the issue? I've swapped electrical cables to the wall too..
appylol is offline
