AMD build advice - Page 3 - Overclock.net - An Overclocking Community
AMD build advice
post #21 of 121 (permalink) Old 11-17-2019, 11:36 AM
Tank destroyer and a god
Offler's Avatar
Rep: 88 (Unique: 69)
My current build (still in progress) in sub... I would go for AM4 socket, probably an AsRock or Asus MB, something in third gen Ryzen. Still Gskill FlareX, because those have Samsung B-die.
Case would be some mITX, with capacity to house one larger GPU.
--- Building in progress * AMD Threadripper 1900x * Asrock X399M Taichi * Radeon VII * Gskill Xflare / Samsung B-die 3200 14-14-14-32 * Samsung 970 PRO 512gb * Fractal Design Node 804 * Seasonic Prime Ultra 850 Titanium *
--- Desktop * AMD Phenom II x6 1090t @ 3,8GHz * ASUS M5A99FX PRO R2.0 * Gigabyte R9 FuryX * A-Data XPG 2.0 / Elpida Hyper MNH 1866 @ 1600 6-6-6-18 * LSI 9211-8i / Raid 0 / 5x Corsair Force 3 GS * Creative Xfi Fatal1ty * Intel I210-T1 * Steelseries 6Gv2 * Logitech MX518 * Samsung U28E590D *
Offler is offline
post #22 of 121 (permalink) Old 11-17-2019, 11:44 AM
CS+EE Alumnus
HybridCore's Avatar
Rep: 214 (Unique: 172)
The AsRock BIOS is pretty annoying to work with. It has a lot of features but a decent chunk of them are broken (maybe it's better now). VRMs on the ASUS B450 or X470 boards are pretty bad until the very high end, though at that point you're better off considering some of the $150-$200 X570 boards Buildzoid recommended in his motherboard roundup instead for better VRMs at a lower cost.
$130 would be the most I'd spend for non-X570 which would be the MSi B450 Gaming Pro Carbon AC. Buildzoid is slightly on the fence with that board just because a very good X570 board is right at $130 (Asus Prime X570-P) with another at $165 (ASUS TUF Gaming X570-PLUS), but if you don't plan on overclocking with a 3900X (stock 3900X or overclocked 3800X and below are fine on the good B450 boards) and either 1. don't want the chipset fan, 2. want Intel LAN, or 3. were going to get Wi-Fi anyways, this is a good board.
The B-die doesn't mean much if he isn't going to spend the time trying to tighten up his secondary timings and there's bad B-die as well. A CJR kit will be fine so he can at least get an FCLK of 1800MHz with no extra work. E-die if he wants to save another $30 over the CJR kit he currently has and is willing to spend the minimal effort needed to use the Ryzen DRAM calculator and copy paste those timings into his BIOS.
Edit: If you plan on overclocking with the 3900X, I'd swap to the ASUS Prime X570-P at the current $127. The B450 Tomahawk MAX and Gaming Pro Carbon AC are fine with the 3700X/3800X but a 3900X is pushing it if you're not running stock clocks (I edited my post on the 1st page to change the conflicting info there). Next meaningful upgrade would probably be the ASUS TUF Gaming X570-PLUS at $165. Get the TUF if the Prime X570-P goes back up to the normal $150.
HybridCore is offline
post #23 of 121 (permalink) Old 11-17-2019, 01:04 PM - Thread Starter
BSME
dirty elf's Avatar
Rep: 8 (Unique: 8)
I was only planning on overclocking as an academic exercise. Maybe I'll stick with the 3700x and the tomahawk... I'm not sure I need the 3900x... When you say 'pushing it if not on stock clocks' do you mean the VRMs? Would good airflow in case help that?
///M
First Build
(15 items)
10 Year Upgrade
(9 items)
Intel Core i7-870 Lynnfield
Asus P7P55D-E Pro
MSI RADEON RX480 8GB
G.Skill Ripjaws 2 x 8GB
Crucial MX 300
Western Digital Caviar Black SATA 6gb/s 7200rpm Drive
Optical Drive
LG Blu-Ray Drive
Corsair 650TX 650 Watt
Cooler Master Hyper 212 Evo
Antec Three Hundred
Operating System
Windows 7 64-bit Home
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Ryzen 9 3900x
MSI B450 Tomahawk Max
RX480
Crucial Ballistix Sport LT
Samsung 970 Evo Plus
Seasonic PRIME Ultra Titanium
Be Quiet Dark Rock Pro 4
NZXT 500
Operating System
Windows 10
dirty elf is offline
post #24 of 121 (permalink) Old 11-17-2019, 01:11 PM
CS+EE Alumnus
HybridCore's Avatar
Yup the VRMs. With the higher core count parts (3900X and 3950X), you'll need the higher phase counts (6+) with more efficient MOSFETs (60A+ smart power stages usually, you can probably get away with 50A ones if you have a lot of phases) if you overclock because those additional cores increase the current passed through the VRM by a lot.
There's some B450 boards like the MSi B450I Gaming Plus AC ($120 mITX board) which has a better VRM than the Gaming Pro Carbon AC and Tomahawk MAX which can actually handle a 3900X and even maybe a 3950X (it's using 6 phases with 60A smart power stages on each). The VRM heatsink is a bit small on that one though so you'd want a fan or something pointing directly at it should you overclock (perfectly fine stock).
Would a good airflow case help? Yes, but the most important part is making sure that airflow actually passes through the VRM heatsinks.
Overclocking on Ryzen 3000 doesn't really seem to give much though so it's basically a waste of time.
post #25 of 121 (permalink) Old 11-17-2019, 01:17 PM - Thread Starter
BSME
dirty elf's Avatar
Rep: 8 (Unique: 8)
Hmmm. Well that makes the decision to step up to a 3900x more complicated.
edit: Oh, so overclocking isn't much of a concern? So a 3900x on stock clocks with the tomahawk would be a decent route?
///M
First Build
(15 items)
10 Year Upgrade
(9 items)
Asus P7P55D-E Pro
Crucial MX 300
Optical Drive
LG Blu-Ray Drive
Antec Three Hundred
Operating System
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Ryzen 9 3900x
RX480
NZXT 500
Operating System
Windows 10
post #26 of 121 (permalink) Old 11-17-2019, 01:26 PM
CS+EE Alumnus
HybridCore's Avatar
You're better off using the $170 you save from going with a 3700X over a 3900X on switching to a 2TB SSD or on faster or higher capacity hard drives.
post #27 of 121 (permalink) Old 11-17-2019, 01:27 PM
CS+EE Alumnus
HybridCore's Avatar
Yup. Still, I think that $170 is better spent elsewhere or just not spent at all.
post #28 of 121 (permalink) Old 11-17-2019, 01:29 PM - Thread Starter
BSME
dirty elf's Avatar
Rep: 8 (Unique: 8)
Hmm. Alright, it will probably come down to what deals pop up over the next week... Thanks, I appreciate the input!
///M
First Build
(15 items)
10 Year Upgrade
(9 items)
Asus P7P55D-E Pro
Crucial MX 300
Optical Drive
LG Blu-Ray Drive
Antec Three Hundred
Operating System
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Ryzen 9 3900x
RX480
NZXT 500
Operating System
Windows 10
post #29 of 121 (permalink) Old 11-17-2019, 01:33 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Any 5400 RPM HDD is going to be pretty slow and the WD Blue´s you picked are even slower than the WD Red you picked at first or did you have those already i cant recall sory
Unless you just need space to dump stuff on and never access it again you should pick a 7200 RPM HDD like the Seagate Ironwolf or Ironwolf Pro or the Red Pro if you want to stick with WD
Seagate by the way is a lot better these days and are actually slightly better than WD in some areas
If you still think of Seagate like they where 10 years ago you should know they have gotten a lot better
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #30 of 121 (permalink) Old 11-17-2019, 01:35 PM - Thread Starter
BSME
dirty elf's Avatar
Rep: 8 (Unique: 8)
Yeah I don’t know what drives I’ll end up going with for the server conversion. It’s not necessary that I buy them right away. If a great deal pops up I’ll grab two. I left them in there so I could get an idea of what the total price would be.
Sent from my iPhone using Tapatalk
///M
First Build
(15 items)
10 Year Upgrade
(9 items)
Asus P7P55D-E Pro
Crucial MX 300
Optical Drive
LG Blu-Ray Drive
Antec Three Hundred
Operating System
Dell U2417H
Dell U2417H
Keyboard
Apple USB Keyboard
Mouse
Logitech M510
Ryzen 9 3900x
RX480
NZXT 500
Operating System
Windows 10
