Need help with OC - memory cache failures - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 12-03-2019, 03:38 PM - Thread Starter
Rep: 0
Heeeere's Jonny. Well, its name is Ark actually.
Ryzen 7, 1700
Prime X370-PRO
4 DDR4 8gb Dominator Platinums
OC Settings
DRAM Voltage 1.365
VTTDDR Voltage 0.6825
Core ratio of 37
Voltage VDDCR - Offset, +, .2 volts
CPU and DRAM Load Line Calibration Level 4 (5 is the max I'm pretty sure...)
My issue - with 2 sticks of ram installed I can overclock to 3kMhz stable on Aida64. Good enough. With 4 sticks installed, I had to take it down one notch to just below 3kMhz. Now it's war.
I'm using the Bios to overclock. Not opposed to other programs if recommended. Last I head the Ryzen Master and the Assus whatever kind of ****s things up and that was my experience with them awhile back...
Been a while since I've OC'd and I've never been more than a Newby. I'm not really interested in pushing the CPU/ Ram hard, but I guess I'm really annoyed that the ram is being this annoying when I got the pretty platinums.
The overall question is what are recommendations from the pro's in general, and what specifically do you think I could do to just bump that ram and keep things stable if I wanted 3kMhz and CPU at 3.7k
Thank you.
VGMusic is offline
post #2 of 4 (permalink) Old 12-04-2019, 11:40 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1247 (Unique: 682)
1st gen Ryzen was all over the board with RAM clocks and you're filling all four slots, you're going to be limited.
be happy with 2933 or sell your 4x8 kit and buy a dual rank 2x16 kit (but dual rank RAM has its own set of problems and it might not even fix anything).
running 2933 with tightened timings primary/secondary/tertiary timings is going to outperform 3000 at XMP anyway, so if the 67mhz deficit is really such a woe then you can put the time into dialing in your RAM and it'll be a woe no mo'.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 4 (permalink) Old 12-05-2019, 02:53 PM - Thread Starter
Rep: 0
Well okay, guess I'm good then. Thanks.
VGMusic is offline
post #4 of 4 (permalink) Old 12-06-2019, 01:45 AM
Synoxia's Avatar
Rep: 8 (Unique: 6)
Wait mate. Did you even try overvolting VDDSOC? Try 1.10.
Is that ram b die? Either way i suggest atleast 1.4v on dram voltage for testing purposes, if you have Vboot voltage put 1.5v on that for testing it may help with training.
Use DRAM calculator and dont forget to put that you have 4DIMMS and not 2. (I did this stupid mistake first time)
CLD0 VDDP can solve memory holes (google) you may want to test every frequency from 3200 till 3600 with stupid timings like cl22. Sweetspot for ryzen 1 gen is either 3200c12 (which is really hard to obtain) or 3433 c14
Play with RZQ and Procodt settings. I have 4 dimms but with gen 3 zen, i've went from not being able to post at all to stable with almost the same oc as i had with 2 dimms, by playing with these settings. Also cad bus timings on 60 and setup 24-20-24-24 can help test dram calculator settings!
Check your temps while stresstesting, ram are fine till 95c without damage but ideally you want them below 50c for stability reasons (but then you have me who can pass testmemt5 at 60c see below lol)
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
G-Skill Tridentz OC 16 gb 3800 c14-16-17-16-32-48
EVGA G3 Gold
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 1903 build 18950 64bit
Viewsonic XG2401
Keyboard
Fnatic RGB Cherry mx brown
Mouse
Logitech G Pro Wireless 950 dpi
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
