Need to finalize the build within 24 hours - Overclock.net - An Overclocking Community
post #1 of 43 (permalink) Old 12-19-2019, 06:19 PM - Thread Starter
Still kinda lost
Awsan's Avatar
Rep: 116 (Unique: 86)
Hello everyone this is my parts list for my 3950x build
( https://pcpartpicker.com/list/WbMt3t )
Wanted to know if you were in my shoes what would you change?
Is the cooler enough for an oc'd 3950x?
Is the Mobo really as good as an overclocker as a hero/impact?
The ram will be running at 3800/3600 with tight timings.
Case will be bought locally as shipping will be outrageous.
Thanks a lot.
Godzilla HAF red
(18 items)
The Son Of Godzilla
(18 items)
Ryzen 3950x
MSI MEG UNIFY X570
EVGA RTX 2080 SUPER GAMING BLACK
G.Skill Trident NEO 32GB 3600mhz
Sabrent Rocket 4.0 1TB
WD blue 2tb SSD
Seasonic Prime Ultra Titanium 650w
Nh-D15 Chromax
CM H500
Operating System
Windows 10 pro
LG24GM77-b
Keyboard
Corsair K95 platinum
Mouse
Logitech G502 SE
Mousepad
Red Gear
Audio
AD900x
Audio
Beyerdynamic Custom Studio
Audio
Schiit Modi 3
Audio
JDS ATOM
Intel Core i7 Extreme 2920XM/Intel Core i7 2860QM
P180HMx
AMD Radeon HD 6990M
AMD Radeon HD 6990M
Samsung
Samsung
Samsung
Seagate 750GB 7200RPM
Optical Drive
Blu-Ray reader
300W+8 cells battery
Sager Cooling + CM SF-19 USB 3.0
SagerNP8180
Operating System
Windows 7 Ultimate X64
18.4 1920x1080 Glossy 16:9 Plastic covered
Keyboard
Gigabyte wirless
Mouse
Gigabyte wireless
Mouse
Table
Audio
ultrasone pro 550 + FiiO E7++ on board 5.1 sound system
Awsan is offline
post #2 of 43 (permalink) Old 12-19-2019, 06:37 PM
CS+EE Alumnus
HybridCore's Avatar
Rep: 214 (Unique: 172)
You could probably swap it with the ASUS TUF Gaming X570.
Non-wifi: https://pcpartpicker.com/product/whM...ming-x570-plus
Wifi: https://pcpartpicker.com/product/dmG...570-plus-wi-fi
The Wi-fi is actually cheaper right now because the non-wifi at $165 is out of stock right now.
HybridCore is offline
post #3 of 43 (permalink) Old 12-19-2019, 06:41 PM
CS+EE Alumnus
HybridCore's Avatar
Also unless you can benefit from a PCIe 4.0 SSD (e.g. all you do is disk intensive workloads like video editing for very, very large files) then I would just stick with PCIe 3.0 SSDs, specifically the Phison E12 + Toshiba BiCS TLC clones.
https://www.overclock.net/forum/355-...2-toshiba.html
I'd get two of the 2TB Pioneer APS-SE20G if you really need 3-4TB on 2 slots: https://pcpartpicker.com/product/tBj...e-aps-se20g-2t
For PSU: https://pcpartpicker.com/product/4pG...u-ionp-660p-bk
I honestly don't even see a reason to go past 80 PLUS Gold because that efficiency doesn't really get you anything. Unless you're running some server farm where those small efficiency gains will actually translate to large savings, I wouldn't bother. The good platinum and gold units usually cost the same though.
post #4 of 43 (permalink) Old 12-19-2019, 06:57 PM
Invalid Media
J7SC's Avatar
Rep: 60 (Unique: 26)
...your cooling solution should be more than sufficient for stock, but 3950X react very well to big cooling. If your locally-sourced case allows for it size-wise, you might try to shoot for a performance 280mm or even thick 360mm cooler
J7SC is offline
post #5 of 43 (permalink) Old 12-19-2019, 07:07 PM - Thread Starter
Still kinda lost
Awsan's Avatar
Yea can easily go for a 280mm and 360mm (there are cases that will support them)
+ I don't mind the price jump from the tuf to the unify if it will clock and Handel the ram better.
I use solar panels for most of the day which made me just go for that seasonic unit + it's just a difference of less than 15$
Thanks
Godzilla HAF red
(18 items)
The Son Of Godzilla
(18 items)
Ryzen 3950x
MSI MEG UNIFY X570
WD blue 2tb SSD
Nh-D15 Chromax
CM H500
Operating System
Windows 10 pro
LG24GM77-b
Keyboard
Mouse
Logitech G502 SE
Mousepad
Red Gear
Audio
AD900x
Audio
Audio
Schiit Modi 3
Audio
JDS ATOM
P180HMx
AMD Radeon HD 6990M
AMD Radeon HD 6990M
Samsung
Samsung
Samsung
Optical Drive
Blu-Ray reader
SagerNP8180
Operating System
Keyboard
Gigabyte wirless
Mouse
Gigabyte wireless
Mouse
Table
Audio
Awsan is offline
post #6 of 43 (permalink) Old 12-19-2019, 07:10 PM
CS+EE Alumnus
HybridCore's Avatar
Thanks
Doesn't make a difference. The TUF uses the same VRM as the Strix E and F Vcore side (-E has a different SoC VRM but that doesn't really matter since that VRM isn't powering an iGPU like on the APUs).
All of the 400 and 500 series motherboards use daisy chain for the memory trace topology (it's more or less a requirement by AMD). Unless the board has components over the memory traces to add noise, they'll all give more or less the same maximum frequencies and minimum timings. You're only really limited by your CPU's IMC.
post #7 of 43 (permalink) Old 12-19-2019, 07:15 PM - Thread Starter
Still kinda lost
Awsan's Avatar
I see, so basically won't lose any overclocking prowess and would cost around half the price.
Thanks
Godzilla HAF red
(18 items)
The Son Of Godzilla
(18 items)
Ryzen 3950x
MSI MEG UNIFY X570
WD blue 2tb SSD
Nh-D15 Chromax
CM H500
Operating System
Windows 10 pro
LG24GM77-b
Keyboard
Mouse
Logitech G502 SE
Mousepad
Red Gear
Audio
AD900x
Audio
Audio
Schiit Modi 3
Audio
JDS ATOM
P180HMx
AMD Radeon HD 6990M
AMD Radeon HD 6990M
Samsung
Samsung
Samsung
Optical Drive
Blu-Ray reader
SagerNP8180
Operating System
Keyboard
Gigabyte wirless
Mouse
Gigabyte wireless
Mouse
Table
Audio
Awsan is offline
post #8 of 43 (permalink) Old 12-19-2019, 07:19 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1326 (Unique: 704)
pretty sure the AsRock X570 Taichi is T-Toplogy.
daisy chain is better for 2 DIMM OCing, T-Topology is good for 4 DIMM. Daisy Chain is dog poo at OCing 4 DIMMs (my Z390 Taichi won't run more than 2 DIMMs above 3633, two DIMMs I can run 4266) so I have a hard time believing that AMD required it...
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (Blues)
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #9 of 43 (permalink) Old 12-19-2019, 07:22 PM - Thread Starter
Still kinda lost
Awsan's Avatar
I think this is the case too, I remember there were a Google spreadsheet that had an insane amount of info on x570/470 mobos
Edit: Aha found it https://docs.google.com/spreadsheets...t?usp=drivesdk
Godzilla HAF red
(18 items)
The Son Of Godzilla
(18 items)
Ryzen 3950x
MSI MEG UNIFY X570
WD blue 2tb SSD
Nh-D15 Chromax
CM H500
Operating System
Windows 10 pro
LG24GM77-b
Keyboard
Mouse
Logitech G502 SE
Mousepad
Red Gear
Audio
AD900x
Audio
Audio
Schiit Modi 3
Audio
JDS ATOM
P180HMx
AMD Radeon HD 6990M
AMD Radeon HD 6990M
Samsung
Samsung
Samsung
Optical Drive
Blu-Ray reader
SagerNP8180
Operating System
Keyboard
Gigabyte wirless
Mouse
Gigabyte wireless
Mouse
Table
Audio
Awsan is offline
post #10 of 43 (permalink) Old 12-19-2019, 07:23 PM
CS+EE Alumnus
HybridCore's Avatar
daisy chain is good for 2 DIMM OCing, t-topology is good for 4 DIMM. daisy chain is dog poo at OCing 4 DIMMs so I have a hard time believing that AMD required it... sure they didn't recommend it?
Hmmm my mistake then. Probably just the recommendation.
