Big troubles with ryzen build - Page 3 - Overclock.net - An Overclocking Community
post #21 of 103 (permalink) Old 01-14-2020, 10:43 PM
cssorkinman's Avatar
Rep: 492 (Unique: 276)
Quote: Originally Posted by i core View Post
after a playing around with build heres what a gather.
1, System works well with xmp profile on (3200Mhz Ram set) and CPU override to 1.4V. I was gaming on it, ran 1hr Aida extreme without faults.
2, System is crashing on start up (black screen loop ) when vcore is on auto and RAM is on any settings ( auto or XMP )
3, System is boot looping when is set to Gaming mode (vcore set 4.46v and RAM on 2113Mhz)
Is anything to set to make most of the system pls.
Also weird thing is happened after testing and system boot looping. I set in bios all right settings to make it work again. Everything was fine except logitech mouse wasnt in default profile. So i fire it up ghub and mouse wasnt recognised by it. Message poped up and said that something hapened before and ghub loaded old settings for that reason. Then i clicked on update button and app started update then update froze on extacting files message. Bear in mind i was running latest ghub before PC system boot looping.
Only option left to download latest ghub again and mouse is recognised .
Is ghub messing up with pc? i tried also Logitech gaming software. It doesnt recognise g502hero so im stuck with ghub
I don't use that software , so I have no point of reference, but I have had some of those type of programs give trouble before
cssorkinman is offline
post #22 of 103 (permalink) Old 01-15-2020, 03:08 AM - Thread Starter
i core's Avatar
Rep: 0
today i had boot looping on start up with best settings yet (override vcore 1.4v and xmp profile). I had to rise vcore to 1.415v to make it work. Also had disk checking and repair c drive on start up then all worked well. No idea why is repairing C drive all worked well on 10y old rock solid Asus Gene2 .
Whats happening ? Do i have bad chip ? it wont work under 1.4v neither on auto settings even when XMP is off. Is it normal voltage for this chip and is it safe running 24/7 ?
Also noticed this in device manager. Any way to fix it please
i core is offline
post #23 of 103 (permalink) Old 01-15-2020, 03:40 AM
OG AMD
Redwoodz's Avatar
Rep: 596 (Unique: 465)
Have you updated to latest bios for motherboard?
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #24 of 103 (permalink) Old 01-15-2020, 03:50 AM - Thread Starter
i core's Avatar
Rep: 0
hi i bought it prebuild in late december. I checked it BIOS is latest no doubt
i core is offline
post #25 of 103 (permalink) Old 01-15-2020, 03:51 AM
deepor's Avatar
Rep: 483 (Unique: 328)
The vcore voltage you are using is not safe. It's kind of impossible to keep the CPU cool under full stress with that kind of voltage. I'd put it back to default.
Are all the crashes just a sudden black screen and reboot? That could be the PSU deciding to cut power from the system for some reason.
There's a setting named "power supply idle control" somewhere in the "AMD CBS" section of the BIOS. You can change that setting to "typical current idle" to help with those kinds of PSU problems.
There's also a "deep sleep" setting somewhere that might be interesting.
About XMP, it's not unusual that it doesn't work. If that's happening to you, you have to do memory speed and timings and DRAM voltage manually.
deepor is offline
post #26 of 103 (permalink) Old 01-15-2020, 03:55 AM - Thread Starter
i core's Avatar
Rep: 0
hi thanks im goin to try it. If i set vcore on auto it behaves like you described. XMP works well if you read my previous replies problem is with cpu.
i core is offline
post #27 of 103 (permalink) Old 01-15-2020, 04:04 AM
OG AMD
Redwoodz's Avatar
I would guess that's the drivers for the NVMe SSD you had installed. All this behavior sounds like a corrupted OS to me. 1.4v on the cpu is fine.
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
TeamGroup Excalibur
AMD FX Vishera 8350
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
Optical Drive
Samsung BD
Zalman 9900MAX
Fractal Design R3
Operating System
AOC 22" LED
Keyboard
Logitech
Other
Redwoodz is offline
post #28 of 103 (permalink) Old 01-15-2020, 04:31 AM - Thread Starter
i core's Avatar
Rep: 0
it didnt help. I set the idle state then set vcore on auto and i got same black screen boots. when i set it back to 4.125v all is good. when it was set on auto i saw vcore 4.448v or similar
i core is offline
post #29 of 103 (permalink) Old 01-15-2020, 04:33 AM - Thread Starter
i core's Avatar
Rep: 0
it didnt help. I set the idle state then set vcore on auto and i got same black screen boots. when i set it back to 4.125v all is good. when it was set on auto i saw vcore 4.448v or similar. i couldnt find deep sleep in bios
I THINK IT HELPED BIG THANK YOU. I rechecked bios again and noticed that amd cool and quiet was enabled also booting ssd was on 5th place in booting priority for some reason. vcore is on auto and now is 1.2v )
i core is offline
post #30 of 103 (permalink) Old 01-15-2020, 04:39 AM - Thread Starter
i core's Avatar
Rep: 0
when i was installing bios to pcie ssd the installation crashed in about 20 percent before finish due unstable hardware. For that reason i removed pcie drive completely. now im using fresh install win10 on samsung ssd which i succesfully installed on old pc then plug it in new pc
i core is offline
