Big troubles with ryzen build - Overclock.net - An Overclocking Community
post #1 of 103 (permalink) Old 01-12-2020, 04:21 AM - Thread Starter
i core's Avatar
Rep: 0
Hi i bought prebuild 3600x with b450 msi tomahawk b450 max mobo from retailer. I added to it new Nvme adata pcie 2tb drive, new Gskill Trident Z 3200c14 b die 2x8GB RAM and samsung evo 850 ,GTX1070 card, Evga 850 G2 PSU from previous computer. With all components PC is crashing more often. Problem is PC cant handle even win 10 install on auto settings and crashing with about 20 percent to finish the install with minimum components in it. I removed almost all parts just left 1 RAM , Samsung ssd and GC . Tried CPU override to 1.35v with no luck. Temperature looks ok its running cool with 3 case fans.
Everything is seated properly cant speak for CPU as it was pre assempled from retailer. BIOS is latest and sees all components no problem there.No idea what to check next this is my 1st build. I dont have any other components to swap and check atm .
Any advice will be much appreciate it
i core is offline
post #2 of 103 (permalink) Old 01-12-2020, 04:46 AM
cssorkinman's Avatar
Rep: 487 (Unique: 274)
When you say it crashes while installing windows 10, what does it actually do? Blue screen, freeze , black screen?
cssorkinman is offline
post #3 of 103 (permalink) Old 01-12-2020, 04:52 AM - Thread Starter
i core's Avatar
Rep: 0
its like instant crash just went black for 1 sec. then Arsenal Gaming logo appears .Then on screen is error that pc has restarted and windows install cant be done
i core is offline
post #4 of 103 (permalink) Old 01-12-2020, 05:19 AM
I guess i'd try clear cmos , set optimised defaults then bump up the ram voltage before starting win install.
Are you installing the os from a usb stick?
EDIT: if that fails I'd set cpu voltage from auto to overide and set it at 1.4 volts - good luck!
post #5 of 103 (permalink) Old 01-12-2020, 05:37 AM - Thread Starter
i core's Avatar
Rep: 0
yes from usb stick. It works well i did clean install with it before .i think cmos was cleared many times because im swapping power supply between old and new pc. Can you be clear please what optimised defaults mean.Also what RAM voltages do you recommend . I set cpu voltage override on 1.35v before with no luck. Any more suggestions before i swap PS to new pc
i core is offline
post #6 of 103 (permalink) Old 01-12-2020, 05:49 AM
I'd still go to 1.4 volts on the cpu and same on the ram. You still need to clear the cmos with a jumper or button if your board has it. The battery will save settings if you don't. Normally Pressing F5 will set optimised defaults,but your manual should tell you what it is for that motherboard.
post #7 of 103 (permalink) Old 01-12-2020, 05:55 AM - Thread Starter
i core's Avatar
Rep: 0
thanks will do that. Any follow up what to do next when i install win10. What to do next to avoid crashes because system is crazy unstable. thank you
i core is offline
post #8 of 103 (permalink) Old 01-12-2020, 05:58 AM
Bad5ector's Avatar
Rep: 10 (Unique: 7)
Do you have another drive you can try to install Windows on? Maybe that Evo 850 is on its last legs...
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #9 of 103 (permalink) Old 01-12-2020, 06:05 AM - Thread Starter
i core's Avatar
Rep: 0
hi . evo is fine. i did install on adata pcie and all unesesary componets were disconected . whole system is very unstable i doubt its ssds. Looks like problem between cpu, mobo ,ram, pcie ssd , power supply
i core is offline
post #10 of 103 (permalink) Old 01-12-2020, 12:26 PM - Thread Starter
i core's Avatar
Rep: 0
Big thanks for pointers so far so good now. Looks like upping ram voltage did the trick. I took ssd with win10 from old pc and it works now. Still didnt put in pcie drive just want to see how far it will go without crash. Only weird thing is happening on start up . In about 30secs reboots to black screen with BIOS logo screen then come back startup screen then black screen in about 40 sec. then start up screen and then black screen. Always after 3rd time reboot it works well then. Last time reboot said like it repairing c drive. Can i disable these check in BIOS somehow . Dont know why is that. 3 times reboot then it works well
i core is offline
