Not downclocking at idle is that bad? Reduce life? Ryzen cpu - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 01-16-2020, 05:28 PM - Thread Starter
Rep: 0
Hey everyone,
i have one more question about my pc
i noticed that my cpu is not downclocking when idle it just stays at the same clock speed and voltage i gave it..
i did this because if i set c states enabled my vcore goes up pretty high for my liking 1.3-1.4v but when i disabled it i have it running at 1.2v
but does running my cpu at 100% speed and voltage will this degrage my cpu over time or not rly?
i believe if you use ''high performance power plan'' itll do the same thing as if you have c states enabled so im pretty sure its fine?
since a lot of people use the high performance plan...
my cpu is a ryzen 5 1500x 3.5ghz btw
i rly want to avoid c states cause of the voltage it gives so i hope its ok
Marlo B N-Mercy is offline
post #2 of 2 (permalink) Old 01-16-2020, 08:11 PM
Riding on the edge
The Sandman's Avatar
Rep: 356 (Unique: 249)
Quote: Originally Posted by Marlo B N-Mercy View Post
Hey everyone,
Not enough info, but I'll give this a shot. Please consider filling out your rig sig, it'll save a bunch of ???
Use OffSet Voltage Mode to set Vcore, not manual.
On my C6H/2700x PE3 OC I run Global C States set to auto without issue for down clocking/voltage.
With my 1800x I always ran a C State OC @ 3950MHz as C State required less voltage. Always down clocked as well.
With my OC I run High Performance power plan with Advanced Power Settings > Min Processor State set to 20%.
The snip below shows Freq/volt drop on idle.
The high idle voltage you're seeing is probably a very low load (not harmful). This can be verified using HWInfo64 and look at CPU Power. Maybe one or more back ground services causing usage issue?
Ryzen Build
(20 items)
Bruce
(14 items)
R7 2700x
Crosshair VI Hero
Diamond 7970
GSkill FlareX F4-3200C14D-16GFX
Samsung 960 EVO NVMe
Samsung 840 SSD
Corsair GT SSD
WD 2TB Black
WD 4TB Red
EVGA 850 G2
XSPC GPU Razor WB
XSPC RX 360
XSPC RS 360
D5 Vario
Gentle Typhoon AP-15 1850 rpm
EK-FB Asus C6H Monoblock
XSPC EX140
Xigmatek Elysium
Operating System
Win 10 Pro
Asus VE248H x2
FX 6350
Asus CHV-Z
PNY GT 710
G.Skill Trident X 16GTX 1866MHz 8-9-9-24-33-1T
Samsung 840 Pro
WD20EFRX 64M Red x4 raid 10
WD5001AALS Blk
Optical Drive
Asus DRW-24B1ST
Corsair HX500
Hyper 212 Evo R2
Corsair 330R Titainium
Operating System
Windows Server 2008 R2 Standard
Asus
Keyboard
Logitech MK300
The Sandman is offline
