AMD 3700X OC help - Overclock.net - An Overclocking Community
AMD 3700X OC help
post #1 of 8 (permalink) Old 01-21-2020, 12:45 PM - Thread Starter
go4life's Avatar
Rep: 585 (Unique: 416)
AMD 3700X OC help
Hello all
My brother has an AMD 3700X and Gigabyte X570 Aorus Pro motherboard. As I am not used to OC'ing AMD (last was back in the Athlon X2 days), I need some help getting this overclocked.
What settings do you recommend? It is cooled by a 480 radiator, so temperatures is no issue.
What can be expected for a properly cooled chip to reach stable?
Thanks for any assistance.
From the cold North
|i9 9940X @ 4.7ghz 1.28v|
|MSI X299 PRO|
|MSI RTX 2080 Ti Duke @ 2ghz|
|4x4gb Corsair Vengeance @ 4000mhz CL19|
|1tb Samsung 970 Pro M.2| |2tb Intel 660p M.2|
|Corsair AX1600i|
|EK Velocity| |HWLabs Black Ice Nemesis 420 + 280| |Alphacool VPP755|
|LD PC-V7|
Operating System
|Windows 10 Enterprise x64|
|Acer Predator X34P|
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
|JBL L890| |2x Advance Acoustic MAA-705 mono amps| |Emotiva XDA-2 DAC receiver|
go4life is offline
post #2 of 8 (permalink) Old 01-22-2020, 03:10 PM
gerardfraser's Avatar
Rep: 94 (Unique: 73)
No need to overclock that CPU.AMD algorithm does the overclocking by itself and does a great job in PC gaming and applications.
AMD algorithm will increase clock speeds when the CPU has electrical, thermal, and/or utilization headroom to spare deemed safe by AMD engineers and the AMD engineers know something about there own CPU's but normally AMD when in idle will set up to 1.5v on CPU for light work loads and lower CPU voltage under heavy work loads.Under light work loads 3700X CPU can boost up to 4400Mhz.
When using any enhanced settings along with windows power plans and certain BIOS AMD will set upto 1.58v(this is the highest I have seen on early BIOS) on CPU and 3700X can boost to 4525 Mhz in light work loads.
Different BIOS along with Windows power plans will have different reading in software.
If you would like to overclock CPU ,go into AMD overclocking section on the Motherboard.There are different sections ,pick AMD overclocking section if you want.
Set CPU to 4300
Set voltage 1300
save,restart and test to see how it works.Not to complicated.Rinse repeat until satisfied.If you want a MAX CPU voltage no one can really answer that 100% certainty but some swear by 1.2850 CPU voltage as max and other 50% say 1.325 max voltages for 24/7 all core overclocks.
gerardfraser is offline
post #3 of 8 (permalink) Old 01-24-2020, 09:32 AM - Thread Starter
go4life's Avatar
Thank you for the answer.
While I am aware of that, I was hoping to see what this chip could do with a manual OC. So will give it a try.
Thanks again!
From the cold North
|MSI X299 PRO|
|Corsair AX1600i|
|LD PC-V7|
Operating System
|Acer Predator X34P|
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
go4life is offline
post #4 of 8 (permalink) Old 01-24-2020, 11:39 AM
Sure no problem.Good place to start is where I suggested in AMD overclocking section and go from there.There is not one guanteed voltage or clock speed and your chip may no even do what I suggested.90% of the 3700X do not but again starting place.
Set CPU to 4300
Set voltage 1300
post #5 of 8 (permalink) Old 01-25-2020, 02:28 AM - Thread Starter
go4life's Avatar
Set CPU to 4300
Set voltage 1300
Thanks! I saw Guru3D also recommended x43 multiplier as base point, however with 1.4v. Will be interesting to see what this chip can do, been to many years since I have OC'd an AMD cpu!
From the cold North
|MSI X299 PRO|
|Corsair AX1600i|
|LD PC-V7|
Operating System
|Acer Predator X34P|
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
go4life is offline
post #6 of 8 (permalink) Old 01-25-2020, 09:44 AM
Please share your results when finished and good luck ,have fun.
post #7 of 8 (permalink) Old 01-25-2020, 10:43 AM
Schmuckley's Avatar
Rep: 705 (Unique: 564)
Get offset to 1.29-1.30 , turn boost off. Start multiplier and testing from there.
Schmuckley is offline
post #8 of 8 (permalink) Old 01-26-2020, 04:35 AM - Thread Starter
go4life's Avatar
Thanks, will report back.
Alright, thanks!
From the cold North
|MSI X299 PRO|
|Corsair AX1600i|
|LD PC-V7|
Operating System
|Acer Predator X34P|
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
go4life is offline
