EDC = 1, PBO TURBO BOOST - Page 2 - Overclock.net - An Overclocking Community
post #11 of 1345 (permalink) Old 01-24-2020, 05:51 AM
Super Noob
Delphi's Avatar
Rep: 91 (Unique: 83)
Anyone try this on a Gigabyte board? Mine didn't work, it freaked out but went in some sort of protection mode. ST only hit 4ghz, multicore was 3.5ghz.
Jack all Trades
(9 items)
Ryzen 3800x
Gigabyte x570 Aorus Elite
Giagbyte Windforce OC RTX 2080 Super
4 x 8GB Adata 3600mhz Ram
Samsung 860 Evo 1TB
Silverstone Strider 1000w
Fractal Celsius S36
Corsair 570x
Operating System
Windows 10 Pro
Delphi is offline
post #12 of 1345 (permalink) Old 01-24-2020, 05:57 AM - Thread Starter
Rep: 57 (Unique: 43)
I'm sitting on a X570 Gigabyte Xtreme. F12a BIOS.
Be sure to use a Agesa 1.0.0.4B bios. I don't know how this works in earlier versions. You might need to try different EDC and scalar values.
Some chips just maybe aren't stable with the extra boost.
1x scalar gives less voltage where 10X gives most voltage for multi-core load.
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X PBO boost, 2x8GB 4866/1900 18.27.24.48.90.tRFC 680 1T 1.650V [Micron Rev.J]
4x8GB 3800/1900 13.23.17.30.66.tRFC 600 1T 1.700V Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron Rev.E 19nm [D9VPP]),
2x8GB Kingston HX436C17FB3K2/16 3600C17 1.35V (Micron Rev.J 17nm),
2x8GB 3866/1933 15.21.20.32.60.tRFC 448 1T 1.590V Kingston HX436C17FB3K2/16 3600C17 1.35V (Hynix DJR 17nm)
Nighthog is offline
post #13 of 1345 (permalink) Old 01-24-2020, 06:23 AM
MikeS3000's Avatar
Rep: 2 (Unique: 2)
I have a Gigabyte board. To get around the restrictions you need to disable global c-states.
MikeS3000 is offline
post #14 of 1345 (permalink) Old 01-24-2020, 06:48 AM - Thread Starter
It isn't entirely a necessity but it makes it easier to manage and quicker to set.
If you want C-states & boost + single-thread you need to play around quite a bit to find something that works for you sample cpu. Will require work. [I'm doing it]
Nighthog is offline
post #15 of 1345 (permalink) Old 01-24-2020, 07:53 AM
Ipak's Avatar
Rep: 4 (Unique: 4)
hmm better ST score then stock 9900k and kf
https://browser.geekbench.com/v5/cpu/1074643
Ipak is offline
post #16 of 1345 (permalink) Old 01-24-2020, 08:01 AM - Thread Starter
Here is a ~balanced setting~ for my 3800X sample for Cinebench R20.
EDC 10
scalar 10x
LLC LOW
cpu voltage offset -0.03125V
Single thread is still throttling but it's not horrible like EDC set to 1.
EDC 11 could be better for single thread but I've not managed to get as good multi with my sample yet.
Multi-thread scores are about equal to manual 4.400Ghz OC.
Nighthog is offline
post #17 of 1345 (permalink) Old 01-24-2020, 08:58 AM
MikeS3000's Avatar
Rep: 2 (Unique: 2)
x570 Aorus Pro Wifi. 3900x
EDC 10
scalar 10x
LLC auto
Vcore: Normal/Auto
I am definitely getting not only amazing boost on all of my cores but the benchmarks to back them up. My findings are that if I use negative vcore offset up to about -0.04 then single core boost scores increase even a bit more, but multi-core suffers. When I apply positive offset up to 0.05 then multi-core keeps increasing but single core suffers a bit.
post #18 of 1345 (permalink) Old 01-24-2020, 09:06 AM
MikeS3000's Avatar
Rep: 2 (Unique: 2)
Just for fun here is a CPU-Z single thread only bench mark with all of the same settings except a -0.04375 offset. Over 560!
post #19 of 1345 (permalink) Old 01-24-2020, 09:28 AM - Thread Starter
@MikeS3000
I could recommend you use LLC and negative offset.
Seems multi-core wants more voltage when single core doesn't. It will increase the overall voltage minimums but not reach up and beyond the 1.500V limit.
You will have too see which LLC setting is best at each voltage offset.
Nighthog is offline
post #20 of 1345 (permalink) Old 01-24-2020, 10:17 AM
Yuke's Avatar
Rep: 1 (Unique: 1)
wow, even my trash 3800x is godlike now lol
good find.
PewPew Rig
(12 items)
Ryzen 7 3800x
Gigabyte x570 Aorus Master
RTX™ 2080 Ti GAMING OC 11G
G.SKill Trident Z Neo
ADATA XPG SX8200 Pro
be quite! Straight Power 11
Noctua NH-D15S
Dark Base Pro 900
ViewSonic ELITE XG270QG
Mouse
Roccat Kone Pure Ultra
Mousepad
ZOWIE G-SR- SE Deep Blue
Audio
Creative Soundblaster AE5
Yuke is offline
