EDC = 1, PBO TURBO BOOST - Page 38 - Overclock.net - An Overclocking Community
post #371 of 396 (permalink) Old 02-14-2020, 09:13 AM
Rep: 0
Quote: Originally Posted by IXICALIBUR View Post
i have the same setup, 1.5v is fine for single threads. i remember a reddit post or yt vid that said CnQ is tied to pstates setting on some boards. my CCD0 cores each hit 4.6 if i open my window at night to lower ambiant (australia/summer) and CCD1 cores hit 4.4ghz.
Thanks cuz; thats pretty
EDIT: DAAANG; I just realized that mine is doing the exact same as yours mate. I'm concerned about the voltage though =/
EDIT2: holy OC heaven; one hit 4.7 all by itself!! - -- ahh cores, they grow up so fast. Seems like I was teaching them to walk just yesterday
DO OR B-DIE -- 3800C14-16GTZN
3900X
AsRock x570 Taichi
MSI 1080 Ti Gaming X
Trident Z Neo F43800C14D-16GTZN Samsung B-Die
Seagate FireCuda 520 PCI-e 4.0 NVME
Samsung 860 Pro SATA
NZXT HALE90 Fully Modular
NZXT Kraken 72X 380mm Radiator
Corsair RGB Fans x3
Corsair Crystal 570x Mirrrored Black Finish
Operating System
Windows 10 Pro
Monoprice Zero-G 35" Curved Ultra-Wide
Keyboard
Logitech G15
Mouse
Logitech Trackball
Greatli is offline
post #372 of 396 (permalink) Old 02-15-2020, 01:20 AM
Rep: 1 (Unique: 1)
boosttester
my set
ppt 175
tdc 130
edc 25
scalar x8
max boost 200 mhz
llc 3 vcore
llc 3 vsoc
Giuseppe Io is offline
post #373 of 396 (permalink) Old 02-15-2020, 09:08 AM
Rep: 0
My voltage is going APE - It wasn't like this before.
I turned on all-core OC earlier; ran some tests; then went back to our EDC feature here; and now HwInfo reports that voltage is going crazy - Like; 1.5v ALL THE TIME crazy- what the heck is going on? Am I going to die?
The heat output doesn't look like it is really @ 1.5v because its not even breaking 45c and RM reports 1.3v average instead of 1.5v? Is it just HWinfo giving me bs numbers err?
3900X
AsRock x570 Taichi
Corsair RGB Fans x3
Operating System
Windows 10 Pro
Keyboard
Logitech G15
Mouse
Logitech Trackball
Greatli is offline
post #374 of 396 (permalink) Old 02-16-2020, 08:17 AM
Rep: 0
i just tested EDC 999->25, PPT 999, TDC 999 on X570 Aorus Master F11 and 3950X, NH-D15, LLC High, Scalar 5X. I get CB20 from 9524->9872 Cpu-Z single 556.8->560.4 multi 10986->11467, P95 162-174W 80oC -> 200-220W 95oC.
CnQ as C-states are enabled, i hit 4.7ghz in some cores.
However it seems to keep the low load voltages that exceed the 25 EDC limit high (aka 1.45-1.5V) as well as the clocks of the cores which might not be safe for continuous use. Temps stay low because the cores don't do much work, but this is not the normal behavior. Only when a core sleeps it goes down to low voltage. But basically i think voltages just follow the boost multiplier set. So this way PBO basically breaks since it's over the limit and boosts the hell out of any load other than 0%/sleep.
St0RM53 is offline
post #375 of 396 (permalink) Old 02-16-2020, 09:50 AM
gerardfraser's Avatar
Rep: 94 (Unique: 73)
The voltage that you showed is requesting that voltage.AMD CPU's almost think for themselves and change their operating parameters several (hundreds/thousands between 0.2v - 1.5v ) of times per second on default settings.It is almost impossible to get 100% accurate reading at a particular time with polling rates on third party software.
I would suggest for the most accurate temperature I would look at CPU (Tctl/Tdie)
I would suggest for the most accurate voltage I would look at CPU CPU Core Voltage (SVI2 TFN) and a lesser accurate vcore voltage.JMO
gerardfraser is offline
post #376 of 396 (permalink) Old 02-16-2020, 11:24 AM
Rep: 0
thanks mate; good suggestions
3900X
AsRock x570 Taichi
Corsair RGB Fans x3
Operating System
Windows 10 Pro
Keyboard
Logitech G15
Mouse
Logitech Trackball
Greatli is offline
post #377 of 396 (permalink) Old 02-16-2020, 04:03 PM
Rep: 0
Can anyone with 3600x share settings? I was trying EDC from 1 to 10 but my system randomly throttle. Both MC and SC.
hadonbg is offline
post #378 of 396 (permalink) Old 02-17-2020, 10:15 AM
Supra
MadSupra354's Avatar
Rep: 0
No matter what I do, PBO Advanced just makes my system unstable, and PBO disabled makes no difference compared to it enabled with stock settings.
My 3600 boosts all cores to 4.2GHz with PBO disabled, on moderate workloads but still. Hangs around 3.9-4.05GHz on heavy workloads. Then, after some tweaking [91 PPT, 57 TDC, 75 EDC 1X +100MHz] got an extra 18 pts on CB R20 - 3622>3640. Single core then went up - 484>499. Then even if I run Aida for 10 minutes, I'll BSOD when web browsing or doing something irrelevant.
Should I just leave PBO alone?
Greyscale
(16 items)
Ryzen 5 3600
Gigabyte Aorus AX370 GAMING-K5Q
Radeon RX Vega 64 NITRO+
Corsair Dominator LPX
Corsair Force GS
WD Caviar Blue
WD Caviar Black
EVGA SuperNOVA 650 P2
Silverstone Raven 3
Operating System
Windows 10 Home
Acer Predator XB271HU
Acer H236HLbmjd
Keyboard
Topre Realforce 104UG HiPro
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
MadSupra354 is offline
post #379 of 396 (permalink) Old 02-17-2020, 02:10 PM
No u
savagebunny's Avatar
Rep: 350 (Unique: 292)
Users struggling with SC in CB15/20 Geekbench once you set EDC of 0/1/10/16 varying CPU or whatever you do.
I was able to repeat this with CB15/CB20 so far. Makes sense with my other data which I'll post later looking into this "bug" whatever you wanna call it.
Parameters: 420 ppt/tdc 16 edc 10x scalar, 7/8/9x react the same. Ambient 18-19c. Noctua D15, GB Ultra BIOS F12b. Cool'n'Quiet is DISABLED. Only way for my chip to boost to 4.6 in Window if CNQ is disabled. Linux isn't broken and I can keep is enabled, but gotta love Windows. Someone probably mentioned it but doesn't work on ABBA.
cb15 211 / 3386 w/ ryzen master open v1472
190 RM closed
211 again RM open
cb20 477 / 7670 RM closed
521 / 7637 RM open
Geekbench5 responds the same way. low single score if Ryzen Master is closed. If I have Ryzen Master open, I gain score. I'm honestly confused. https://browser.geekbench.com/v5/cpu...seline=1244762
tl;dr Open Ryzen Master, HWiNFO. Have a program polling. Certain programs need this since it wont boost properly I'm assuming? Your SC scores should go up. YMMV.
My Build
GB Ultra F12b
3900x
GSkill 3200C14 @ 3733CL16 tuned sub timings.
Semper Fi Daniel
savagebunny is offline
post #380 of 396 (permalink) Old 02-18-2020, 01:41 AM
ManniX-ITA's Avatar
Rep: 0
Did you try a lower EDC value to profit from the boost bug?
My 3800x too is unstable unless using EDC at 0.
I had to struggle a bit to find the right settings to run with EDC at 1.
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
