EDC = 1, PBO TURBO BOOST - Page 44 - Overclock.net - An Overclocking Community
post #431 of 615 (permalink) Old 02-26-2020, 02:16 PM
Super Noob
Delphi's Avatar
Rep: 91 (Unique: 83)
Quote: Originally Posted by rastaviper View Post
Do u have 3600x too?
I wonder how your performance is.
Because it seems that in my case it's not so much about the clocks, but that this method is really slower then the manual oc of all cores.
Sent from my ONEPLUS A6003 using Tapatalk
I do in my Wife's PC. She has my old B350-F Strix with a 3600x in it. I used the exact settings I posted the first time and it gets 4.35ghz all core and 4.45 single threaded. Eventually I want to work on the ram OC but she uses it everyday haha. Maybe I will tell her to go on shopping trip one of these weekends
Jack all Trades
(9 items)
Ryzen 3800x
Gigabyte x570 Aorus Elite
Giagbyte Windforce OC RTX 2080 Super
4 x 8GB Adata 3600mhz Ram
Samsung 860 Evo 1TB
Silverstone Strider 1000w
Fractal Celsius S36
Corsair 570x
Operating System
Windows 10 Pro
Delphi is offline
post #432 of 615 (permalink) Old 02-26-2020, 09:26 PM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 3 (Unique: 3)
When you get the time, can you run a CB20 and geekbench 3?
  • Ryzen 3600x @4490mhz, Mugen Rev.B, v1.46, 3rd position at HWBOT
  • Gigabyte Aorus Elite x570
  • G-SkillLL F4-3200C15D-16GTZ Trident Z Series CL15 Bdies @3733 15-14-13-1T 1.46v
Official Ryzen 5 3600x Owner!
rastaviper is offline
post #433 of 615 (permalink) Old 02-27-2020, 03:07 AM
Rep: 0
could you share the link where you mentioned the settings you used?
jcpq is offline
post #434 of 615 (permalink) Old 02-27-2020, 04:53 AM
Rep: 0
EDC=4
jcpq is offline
post #435 of 615 (permalink) Old 02-27-2020, 06:51 AM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by jcpq View Post
EDC=4
So this is I believe the difference with the manual OC.
All core OCing at 4.4Ghz with your Ram timings should bring u a score around 4000.
post #436 of 615 (permalink) Old 02-27-2020, 08:39 AM
mongoled's Avatar
Rep: 19 (Unique: 15)
Hi!
Im pretty sure that 4.4Ghz fixed CPU core frequencies are not going to equal '4.4Ghz' CB20 score achieved through PBO, even with the use of the EDC bug.
The EDC bug will raise the 'auto' all core frequency of the CPU, while at the same time providing higher single core boost speeds.
If you have work loads that use all you cores and are not bothered about the lower single core boost clocks then there is really no reason to be using the EDC PBO bug.
Now for those who dont mind slightly lower all core boost frequencies compared to static frequency overclock (EDC bug is definitely better compared to 'regular' PBO) but would like nice single core boost speeds this bug is great.
Though alot of work is needed to find a balance on achievable boost speeds as the cores all differ with regards to max frequencies .....
Myself personally, the highest ive hit in CB20 (using EDC bug) is 3927 and the all core frequency according to HWinfo64 was alternating between 4280-4300 mhz.
To confirm my theory, can you run a 4.3Ghz CB20 and post back you score.
Im guessing it will be more than the 3927 I achieved....
SeaSonic X750 Gold 750W
MSI X370 XPOWER Gaming Titanium | Ryzen 5 3600X 1924SUT | BCLK 100.625 | 6X | 75 mhz
GSkill TridentZ F4-3600C15D-16GTZ @ 3760/1880 mhz | 1.50v | 14-15-14-14-42-26-266-16-1T
Asus GTX 780 DCII OC @ 1332/3522 mhz | 1.3v | Samsung 960 EVO 500GB
EK-FB MSI X370 XPower RGB Monoblock 1/2" ID | Swiftech D5 MCP655 | EK-XRES 100
Alphacool NexXxoS UT60 280 | 4 x Scythe GT AP-15 @ 5v
Thermochill PA120.3 | 1 x NF-A12x15 | 2 x ML120 | PWM
mongoled is offline
post #437 of 615 (permalink) Old 02-27-2020, 08:42 AM
Rep: 0
Quote: Originally Posted by mongoled View Post
Hi!
What settings do you use on your 3600x?
jcpq is offline
post #438 of 615 (permalink) Old 02-27-2020, 08:49 AM
mongoled's Avatar
Exact setting in my sig, which does NOT use EDC bug.
For EDC bug testing, I used.
EDC: 3 or 4
TDC: Auto
PPT: Auto
C-States: Disabled
CnQ: Disabled
Spread Spectrum: Disabled
CPU Scaler: 4x
CPU max frequency boost: 75 mhz (edit, had a missing 7, not 5 mhz)
CPU Offset: +0.0250
CPU LLC: 5
BCLK: 100 mhz
But I could not get this stable under intense and long duration stress tests !
mongoled is offline
post #439 of 615 (permalink) Old 02-27-2020, 08:53 AM
Rep: 0
EDC: 3 or 4
TDC: Auto
PPT: Auto
C-States: Disabled
CnQ: Disabled
CPU Scaler: 4x
CPU max frequency boost: 5 mhz
CPU Offset: +0.0250
CPU LLC: 5
BCLK: 100 mhz
Ok thanks
jcpq is offline
post #440 of 615 (permalink) Old 02-27-2020, 08:57 AM
mongoled's Avatar
Ok thanks
Also I run all test by changing CPU affinity for CB20 to realtime.
This make sure you get consistent scores without being effected by other processes.
It will look like it has frozen, but it has not
mongoled is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
