EDC = 1, PBO TURBO BOOST - Page 91 - Overclock.net - An Overclocking Community
post #901 of 915 (permalink) Old 05-22-2020, 10:49 AM
Intel in 2020 LOL
Rep: 37 (Unique: 19)
Quote: Originally Posted by Dash8Q4 View Post
Did you ever test these settings? Or any others for that matter?
cheers
I did.
AMD Bliss
(16 items)
AMD Ryzen 7 3700X
MSI X470 Gaming Pro - 1.0.0.4B
Sapphire RX 5700 XT Pulse
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-12-28-40 1T 1.52V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
2x Crucial MX500 1TB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
Sapphire RX 580 Nitro+ 8GB
2x8GB Kingston HyperX Fury @1600 CL10
Samsung 860 EVO 500GB
WD Blue 1TB
Super Flower Golden King Pro SF-500P14PE 500W 80+ Platinum
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Asus VG245HE TN 1080p 75hz
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Intel Core 2 Quad Q6600
Gigabyte P43-ES3G
Asus R9 270X Top 2GB
2x2048MB Kingston DDR2 800mhz
Samsung 840 EVO 120GB
WD Blue 1TB
Sirtec High-Power 80+ 400W
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Several LG/BenQ 17" 1280x1024 75hz
Keyboard
Logitech G710+ MX Brown
Mouse
Mouse
Razer DeathAdder 2013
Mousepad
Mousepad
Razer Goliathus Speed WoT Edition
rares495 is offline
post #902 of 915 (permalink) Old 05-22-2020, 11:04 AM
jimpsar's Avatar
Rep: 0
Quote: Originally Posted by R-Type! View Post
I basically gave up on the EDC bug bec. i never could get it to work. Always had huge performance drops no matter what settings i used (didn't spent too much time but tried quite a few combinations).
Today i woke up early and my coffee told me to try again -> success!
System specs:
3900x
Gigabyte x570 master bios F11
BCLK 100.3 (100.4 causes SATA to act up )
G.Skill F4-3600C16-16GTZNC [email protected]/1900 1:1:1
RTX gfx
Settings that worked for me:
PPT/TDC/EDC 1200/540/18 (PPT and TDC are Board limits)
Scalar x10
AutoOC +200MHz
1usmus recommended settings except Global C-States: Disabled (with C-States enabled SingleCore performance drops significantly)
Dram 3800 with 1900 synced FCLK/UCLK and Ryzen Dram Calc 1.7.3 Fast timings @1.39V
Everything else (VCore/LLC/SoC etc.) at auto.
Now for some scores:
CB20 MT/ST: 7745/542
CB15 MT/ST: 3402/220
CPU-Z MT/ST: 8786/568
Intel-Burn-Test v2.54 High, 4run average: 154.3
Blender BMW: 1m48s
Blender Classroom: 5m24s
While it was fun finally getting the EDC bug to work for me I'm not comfortable with the Voltages/Power draw with these settings (see HWInfo screen during CB20 run).
HWInfo reports 174W max. CPU Package power during CB20 run.
Thanks to a custom loop the temps are fine
For Comparison my "daily" settings:
PPT/TDC/EDC: 300/230/230 (BuildZoid settings)
-0.125V Vcore offset
C-States enabled
CB20: 7541/535
CPU-Z: 8557/563
max CPU Package Power during CB20: 143W
Interestingly enough my CPU likes negative offset with BuildZoid settings, i get the the best scores at -0.125V.
Using the EDC bug the situation is reversed and any neg. offset lowers the scores (higher neg. offset ->even lower scores, tested from -0.025 to -0.100)
CB20 and HWInfo during CB20-MT Screenshots:
Great scores mate!!
Thanks for sharing.
I will try them out to check if I have any luck. Ofc you a beast mobo , used to have Aorus z390
Wanted to ask you, in windows which power plan do u use? 1usmus Ryzen or something else?
jimpsar is offline
post #903 of 915 (permalink) Old 05-22-2020, 11:07 AM
dansi's Avatar
Rep: 32 (Unique: 22)
System specs:
3900x
RTX gfx
Scalar x10
AutoOC +200MHz
Blender BMW: 1m48s
C-States enabled
CB20: 7541/535
CPU-Z: 8557/563
My gigabyte board also love negative offset. I guess it really depends if the vendor implement the proper pbo codes wrt to their vrm.
My findings here
https://www.overclock.net/forum/10-a...0-part-ii.html
dansi is offline
post #904 of 915 (permalink) Old 05-22-2020, 02:15 PM
jimpsar's Avatar
Rep: 0
Hello tried the above but did not got so large numbers. It seems more like manual oc numbers though and not like edc bug ones.
jimpsar is offline
post #905 of 915 (permalink) Old 05-22-2020, 09:44 PM
Rep: 0
Quote: Originally Posted by jimpsar View Post
Great scores mate!!
Thanks for sharing.
I use 1usmus universal Power Plan
In the Hwinfo screenshot i posted you can see the core speed fluctuating a bit so no, not a fixed OC
Maybe I'm lucky with my Silicon. My Chip likes lower Voltages under "normal" conditions so if you supply higher auto voltages in this no-limits scenario it can boost higher.
Since PBO tries to boost all cores equally under multithreaded loads the limiting factor seems to be the 2nd CCD. A per-CCD (or CCX) PBO would be interesting to play with
R-Type! is offline
post #906 of 915 (permalink) Old 05-23-2020, 08:13 AM
Rep: 0
Been trying to use higher EDC values than 12 on my 3900x just for the sake of it but results would not be "better" than 12 in terms of max boost clock that is.
The only thing I have not touched at all is voltage. I'm on a X470 Prime pro.
At idle, it's using around 4.6 to 4.8 average
In game, around 1.41 to 1.45 average sometimes a bit lower, depends on the game.
push pull (6 fans) on a 360 aio, get around 60°C/65°C in use (was with 28°C room temp)
It's high but does not look worrying?
Would trying some offest bring anything in regards to this edc behavior like higher clocks? or lower temps maybe?
I'm just unsure what offset/voltage to touch (theres tons in this damn bios) and what to try (I don't wanna lower my ST boosts, very happy with them)
thanks for your input, very appreciated on all the work and feedback in this thread!
zbug is offline
post #907 of 915 (permalink) Old 05-24-2020, 09:02 AM
highdude702's Avatar
Rep: 1 (Unique: 1)
MCM = Multi Chip Module. Almost every cpu in the last 15 years have been "Multi core modules" just to help clear any confusion up
highdude702 is offline
post #908 of 915 (permalink) Old 05-24-2020, 09:52 AM
Old crazy guy
ManniX-ITA's Avatar
Rep: 8 (Unique: 8)
To look for better clocks you can try with scalar at 10 and higher max boost clock.
To lower the temps a negative CPU vCore offset; if the bench scores are dropping you can compensate with the above or try a higher LLC setting.
The CPU vCore should be VDDCR CPU Voltage on you ASUS but I'm not sure how you can set an offset.
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
post #909 of 915 (permalink) Old 05-24-2020, 01:29 PM
Rep: 961 (Unique: 706)
after much playin with settings on pbo pretty decent 300 254 16 llc 3 -0.056 offset its + or -1 1-2% tops of my all core 4300 overclock and hits 4.65 on single core Voltages range between 1.275-1.437.
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
ASUS AMD AM4 ROG Strix X570-E
EVGA GTX 1080 FTW Hydro Copper
G.SKILL TridentZ Series
Samsung EVO 850 500
SeaSonic M12D SS-850 850W
EK-SBAY Dual DDC 3.2 PWM Serial
Alphacool NexXxoS ST30 Full Copper Radiator 360
Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
EKWB EK-Velocity Strike CPU
EK-CoolStream RAD XTC 420
Thermaltake core x71
Operating System
Windows 10 Pro
ASUS VW246H Black 24" 2ms
Keyboard
Rosewill NEON K75 V2 BR
Mouse
CM Storm Sentinel Advance II
Audio
Corsair Void
Bal3Wolf is offline
post #910 of 915 (permalink) Old 05-25-2020, 02:24 AM - Thread Starter
Rep: 44 (Unique: 37)
The question remains are you happy with the results? Gonna keep using it or go back to manual OC?
There is quite a difference between the CCD's on your 3900X. one does 4.400Ghz and the other 4.600Ghz in boost behaviour. We have seen it quite often for the 3900X & 3950X.
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X PBO boost, 3800/1900 MEM/FCLK, 13.23.17.30.66.tRFC 600 1T 1.700V
4x8Gb Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron Rev.E 16nm [D9VPP])
Nighthog is offline
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
