Need Assistance! OC settings and considerations? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 26 (permalink) Old 01-31-2020, 02:27 PM
Senior OCN Member
shilka's Avatar
Rep: 2784 (Unique: 1646)
Quote: Originally Posted by K1ll3rGreen View Post
Thank you for the tip on power supply, looking at current draw numbers are concerning if this ps really only puts out 300w-ish after being heat soaked and running all day.
40 minutes into the burn test, 68c on package 51c/28c on other nodes. Should I be concerned?
Like i said its only rated for its wattage at 30c where almost everything on the market is rated for 50c with some lower end models rated at 40c
30c is what bargain bin super budget units are rated for so yes its not a 450 watt
Around 70c on the CPU is just meh its not dangerous but its not all that fantastic either
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
EVGA SuperNova G2 750 Watt
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is online now
post #12 of 26 (permalink) Old 01-31-2020, 03:30 PM
High IQ Person
DAM20's Avatar
Rep: 1 (Unique: 1)
My ram is micron e-die 2x8 1R, it's stable at 3200 running cl16-18-18-36 factory timings and i ran 3400 at the same clocks past few days off a fresh cmos with only 1 issue(mouse randomly disconnected shut off, took some fiddling to get it back not sure if that was software errors but it has only done this once before and while OC'ing ram.)
Can you tell me what the sweet spot is to lock my cpu and ram mhz at? The other sticks i have are hynix and were purchased over a year later, will not post past 2933 mhz but "sometimes" runs way tighter timings.
E die? I think it's better than trash b die, maybe you can hit c16 3466, my tip is to download and use Ryzen Dram Calculator. For the cpu idk, 4.1/4.2 should be top.
Yeetus
(10 items)
Brother's heater
(10 items)
Ryzen 2700X (10x -0.106)
Crosshair VII Hero (WiFi)
Sapphire RX 5700XT Nitro+ SE
G.Skill 3466 C14
Crucial P1
Seagate Barracuda
XFX XTR P1-750B-BEFX
NH-D15 AM4
Dark Base 900 Pro
Operating System
Windows 10 Pro
Ryzen 2600X (10x -0.05)
ROG STRIX X470-F GAMING
XFX RX480 GTR (580 BIOS) 1430/2020
Corsair Vengeance LPX 3200Mhz
Crucial P1
Seagate Barracuda
ANTEC HCG-750-GOLD
Corsair H100i
NZXT H510i
Operating System
Windows 10 Pro
DAM20 is offline
post #13 of 26 (permalink) Old 02-01-2020, 09:55 AM - Thread Starter
Rep: 1 (Unique: 1)
Where the smarties at.....? I feel like my questions are simple enough, tired of 'googling' and reading the same copy and paste filth on every single site. Can anyone help?
Update: Started messing around with the FID//DID settings this morning for overclocking, as much as I've research the matter still really not understanding what's going on here. I've achieved a higher boost OC on cpu up to 4.3 ghz, averaging around 4ghz and temps have been stable, 3-5c cooler, also voltage on cpu is sitting around 1.31v on full load so that's pretty neat. Using the auto settings and bumping clock to same speed(4ghz) yielded much higher temps, not properly idling and 1.35+v on the core also randomly would boost as high as 4.6ghz.
TLDR:
Anyways.... Cpu mhz to ram mhz ratio? bios options I may need to check or change?
K1ll3rGreen is offline
post #14 of 26 (permalink) Old 02-01-2020, 10:01 AM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by shilka View Post
Like i said its only rated for its wattage at 30c where almost everything on the market is rated for 50c with a some lower end models rated at 40c
How about 65c? That's full load temp after an hour tho, won't really be a factor for what I do hopefully.
Thanks again, as said you are definitely right on the power supply. Found the limit this morning when I added a slight OC on gfx card and it shut down the system right after starting OCCT burn test. Guess that'll be the first upgrade..
post #15 of 26 (permalink) Old 02-01-2020, 10:08 AM - Thread Starter
Rep: 1 (Unique: 1)
There's something wrong with that calculator, for my system anyways the numbers being spit out are not stable. Sticking with XMP timings of my ram at 3000mhz, I've pushed to 3466 but didn't run it long as I could clearly see it was bottlenecking my cpu at its auto setting of 3400mhz.
Yea it's E-die, purchased back in 2018 when I got the pc. Silicon lottery or whatever bs they call it. I tried to push it to 3600 earlier, wouldn't post at 1.35v but that's all good. no extra power to spare anyways,
post #16 of 26 (permalink) Old 02-01-2020, 10:22 AM
Senior OCN Member
shilka's Avatar
65c is around what i get with a non overclocked 3700x and a NH-U12S that has run all day doing work
Its not a super high temp but its not great either just meh could be better but also worse
As for the PSU yes replace that either with a Seasonc Focus Plus GX or a Fractal Design Ion+
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
post #17 of 26 (permalink) Old 02-02-2020, 07:45 PM - Thread Starter
Rep: 1 (Unique: 1)
Might just keep the system as is and build something new around a good supply like those, quite pleased with current performance right now and having such a terrible psu keeps the power bill lower right? haha..
Currently working on undervolting//overclocking the gpu, maybe more gains can be had by reducing its draw on the system.
post #18 of 26 (permalink) Old 02-02-2020, 07:53 PM
Schmuckley's Avatar
Rep: 705 (Unique: 564)
Doh! OCing that GPU and CPU with that PSU be scary! I say don't do it! At best it will shut down. We won't mention the worst..
I learned that the hard way. Learn from my mistakes!
Schmuckley is online now
post #19 of 26 (permalink) Old 02-03-2020, 06:27 AM - Thread Starter
Rep: 1 (Unique: 1)
WAIT, YOU DIDN'T TELL ME THE MISTAKES!!! Do tell what the worst is tho, so far it just shuts down upon reaching power limits and I am pushing nothing ( voltage wise anyways ) beyond rated specs. Take for instance the ram, board is QVL'd to push some sticks @1.45 volts and near 4000mhz so I should be plenty safe running 1.35v @ 3200 for everyday use right? What exactly is this PSU possibly going to do beyond losing the ability to send enough electrical pixies and shutting itself down?
post #20 of 26 (permalink) Old 02-03-2020, 06:52 AM
Senior OCN Member
shilka's Avatar
The fail safes on cheap PSU´s dont always work the first EVGA B3´s that came on the market would blow up when going out of specs instead of shutting down because fail safes where not working
At least they seem to be working on yours
https://www.youtube.com/watch?v=QG0GUdNizs0
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
