Need Assistance! OC settings and considerations? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 26 (permalink) Old 02-03-2020, 07:15 AM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by shilka View Post
The fail safes on cheap PSU´s dont always work the first EVGA B3´s that came on the market would blow up when going out of specs instead of shutting down because fail safes where not working
At least they seem to be working on yours
https://www.youtube.com/watch?v=QG0GUdNizs0
Oohhhh fancy, now you just mean let the smoke out right? The misses won't be so happy if I replaster the room with computer bits...
K1ll3rGreen is offline
post #22 of 26 (permalink) Old 02-03-2020, 07:19 AM - Thread Starter
Rep: 1 (Unique: 1)
Can anyone tell me how simultaneous hyperthreading affects a systems performance when just running basic OS, Game//Launcher and maybe Discord? Would I be better to leave this option disabled if only doing basic things? Currently running OCCT burn with it disabled and performance seems to be the same but 10c less on thermals?
post #23 of 26 (permalink) Old 02-11-2020, 09:57 PM
Schmuckley's Avatar
Rep: 705 (Unique: 564)
Not the auto stuff! Manual straightforward OCing.
That auto stuff is too crashy!
I prefer to disable "SMT" ..aka "HT" on AMD. YMMV
Clock higher and stays cooler? Gimme! Gimme!
Schmuckley is offline
post #24 of 26 (permalink) Old 02-13-2020, 02:31 PM
PhillyB's Avatar
Rep: 26 (Unique: 25)
Smt is perfect for your use case. It just fills in the empty clock cycles in a physical core with the tasks from a secondary process, like discord.
Its will run warmer because the core is being more effectively used. 100% on a core just means a task is using every time slot on the core, not necessarily 100% of the time slot. Smt takes a seconary task and fills in the time slot leftovers.
Performance in games is dependent on the programming optimization for higher core counts. Old games were optimized for 4 or less. New ones 8.
I recommend just leaving it on. Temps are good, core speed is good. Toggling it on and off for specific tasks would be annoying. After a psu improvement to something in the 550w range, you will be set for a ling time. A little overkill on the psu is good for the efficiency of the psu and your power bill.
PhillyB is offline
post #25 of 26 (permalink) Old 02-13-2020, 08:37 PM
Schmuckley's Avatar
WAIT, YOU DIDN'T TELL ME THE MISTAKES!!! Do tell what the worst is tho, so far it just shuts down upon reaching power limits and I am pushing nothing ( voltage wise anyways ) beyond rated specs. Take for instance the ram, board is QVL'd to push some sticks @1.45 volts and near 4000mhz so I should be plenty safe running 1.35v @ 3200 for everyday use right? What exactly is this PSU possibly going to do beyond losing the ability to send enough electrical pixies and shutting itself down?
Well, tbh, I just suffered reboots with the POC PSU. I used it to build a semi-gaming comp and sold it off.
It would not run an 1100T + 5870 at the same time, but it would run an OC'd Phenom II X2 550 Oc'd + a 5850 well.
And that's how I sold it..with Crysis included. With a 5850 1gb.
post #26 of 26 (permalink) Old 02-19-2020, 09:11 AM - Thread Starter
Rep: 1 (Unique: 1)
Thanks boss, definitely prefer running w/ smt on as the experience is more smooth and with current 4ghz OC thermals don't go much over 40c at full load.
Currently testing specs: 4Ghz OC, 3200 on ram 16-16-16-28-46 [email protected] Also disabled some windows based timers that may have been crashing previous OC attempts, so far so good..
