PC sometimes posts but mostly dosn't - Overclock.net - An Overclocking Community
post #1 of 27 (permalink) Old 03-28-2020, 10:37 AM - Thread Starter
AMD boy's Avatar
Rep: 0
So I've had an issue for the past few weeks where my pc will not boot the fans will speed up but not rev down the LEDs on the motherboard will someone but no after that nothing happens no display and when I turn it off bu holding the power button the red LEDs on my motherboard stay on. One workaround I found was to turn off the system fully unplug the PSU remove all charge from the computer and then go do something for a few mins and when I come back and plug everything back in it boots up perfectly normal. One odd thing I found is that when it does boot the system is flawless everything works perfectly fine.
Here are my specs
CPU-AMD ryzen 7 1700 (no OC)
GPU-Nvidia RTX 2060
Motherboard-B450 Aorus Pro Wifi mini itx from gigabyte
Ram-2x8 Corsair Vengence
PSU-Corsair VS550
I have 2 storage devices a Kingston 480gb SSD and a Seagate 7.2k rpm 2tb hard drive
AMD boy is offline
post #2 of 27 (permalink) Old 03-28-2020, 11:25 AM
Rep: 0
If it helps I had a similar problem a couple years ago. For clarification...
1. Turn PC on, fans spin, lights come on, doesn't post.
2. Reboot a few times, ends up posting, works fine.
Later on it developed symptom #3.
3. #2 doesn't work, unplug PSU, hold power switch for about 30s or wait 5-10 mins, replug it up and retry, boots fine.
It did this intermittently for about 6 months. Eventually it shut off on it's own. Upon trying to reboot fans wouldn't spin up, lights wouldn't turn on and the system wouldn't even attempt to power on. #3 above provided zero results. In the end swapping in another PSU fixed the problem. This lead me to believe the 6 month period was due to some component in the PSU starting to fail. Eventually it went from it's last leg to dead.
Basically, I'd rule out the PSU. I won't say it definitely is your problem because these type of issues can be tricky to troubleshoot. I do find the PSU is often a good option to rule out though. They're relatively cheap compared to a lot of components, at least to swap out, and they don't tend to have a lot in the way of compatibility concerns. Not like various other components anyway (chips, boards, ram, etc.).
The other option would be to ensure it's not the board. Faulty boards can lead to some very interesting behavior.
Before swapping out components removing all non-essential components and trying to boot/check behavior is a good starting point. You should be able to rule out most stuff by taking this step. Unfortunately, this isn't often helpful when a system is behaving normally sometimes but not others. Ruling out other obvious suspects like over-heating, doing a visual inspection of components and things of this nature goes without saying.
Iridium31 is offline
post #3 of 27 (permalink) Old 03-28-2020, 11:38 AM - Thread Starter
AMD boy's Avatar
Rep: 0
Yeah, that sounds exactly like the problem I have been having. I did do the minimalistic approach when testing and the same issue I also reseated all the cables so I think it may be similar to the issue to yours. The only problem is that I don't have a spare PSU and with the whole coronavirus it may be difficult to get a new one so I will probably order a better one asap and just use the workaround until the new one arrives. I have heard bad things about my PSU and running occt it has really bad coil whine and there is a weird clicking bumping sound so I was probably gonna buy a new one anyway. Any recommendations for a good quality PSU? Thanks for the response
AMD boy is offline
post #4 of 27 (permalink) Old 03-28-2020, 11:41 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Sory to tell you but your PSU pretty much sucks and its not very good to say the least
The Seasonic Focus GX or Prime Ultra are both good options and a 550 watt is more than enough power for the parts you have you need much better quality not more wattage
Edit: this is what you have right?
https://www.overclock.net/forum/31-p...fenix-bpa.html
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #5 of 27 (permalink) Old 03-28-2020, 12:11 PM
deepor's Avatar
Rep: 483 (Unique: 328)
What's the RAM speed you are using? Are you running your RAM at its rated speed? Did you enable XMP in the BIOS menus?
What happens if you reset everything about RAM settings in the BIOS to default. The system's default RAM speed will be something slow like 2400MHz. Are things booting fine if you run the RAM at that slow speed?
If things run fine at the slow default memory speed, and sometimes boot and run fine at a fast speed, then you will be able to fix your problem using the "ProcODT" and "RTT" and "CAD" resistance settings in the BIOS menus. There's a thread somewhere about Ryzen memory overclocking somewhere that should help.
deepor is offline
post #6 of 27 (permalink) Old 03-28-2020, 12:47 PM - Thread Starter
AMD boy's Avatar
Rep: 0
I reset the bios multiple times and tested for bad memory both sticks are functioning ok and the bios are currently at its stock state. The fact that my pc runs fine and I'm even able to play VR is tempting me that this is a psu or motherboard issue. It seems like even at the default settings I still have this issue but I've run my ram at default for almost a year now with no issues. But I will probably tinker a little bit with my ram just to be positive it isn't it.
AMD boy is offline
post #7 of 27 (permalink) Old 03-28-2020, 12:52 PM - Thread Starter
AMD boy's Avatar
Rep: 0
Oh my god that PSU isn't even really meant for American power. Yep, that's the PSU I have and I have beat this thing to death I never turn off my computer until I go to bed and I turn it back on when I wake up. I've heard this PSU is crap from the moment I got it and it failing after around 3/4 of a year doesn't surprise me now thanks for your recommendations I will definitely be spending more than I did on this one and making sure I buy quality. This build was on a tight budget for the parts I wanted so I cheaped on the PSU. Thanks for the input I will check out those power supplies you recommended.
AMD boy is offline
post #8 of 27 (permalink) Old 03-28-2020, 01:04 PM
Senior OCN Member
shilka's Avatar
If you are on a budget the Corsair CX550M is a decent option its not great but its far better than the VS
But if you can buy a Focus GX or Prime Ultra you should buy one of those
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #9 of 27 (permalink) Old 03-28-2020, 01:29 PM - Thread Starter
AMD boy's Avatar
Rep: 0
I will most likely buy the Focus GX it seems like the best option and money is not a huge issue for me right now as there are no steam sales upcoming. Anyway, thanks for the help once I pop in the new PSU I will tell you if it fixed the problem which I am 99% sure it will.
AMD boy is offline
post #10 of 27 (permalink) Old 03-28-2020, 02:27 PM
Senior OCN Member
shilka's Avatar
Just a note there is both a V1 and a V2 of the VS series the thread i linked was to the V1
The V2 is slightly less crap but its still not very good
You can tell the difference by the 80 plus rating the V1 is just 80 plus and the V2 is 80 plus bronze rated
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
