Random Reboots - CPU or motherboard? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 04-28-2020, 12:30 PM - Thread Starter
Supra
MadSupra354's Avatar
Rep: 0
Quote: Originally Posted by rdr09 View Post
Third party apps like Afterburner, iCue, etc.
I have Afterburner, only because I have a (stable) undervolt on my RTX 2070 Super. Crashes happen without it though.
A member a few days ago had a similar issue and it turned out a loose connection of a cable on the psu end. Here is how you check the driver for the drive or other components.
Copy that, I'll resecure all cables. I have the exact same driver version/signer for my drives too.
Greyscale
(16 items)
Ryzen 5 3600
Gigabyte Aorus AX370 GAMING-K5Q
Radeon RX Vega 64 NITRO+
Corsair Dominator LPX
Corsair Force GS
WD Caviar Blue
WD Caviar Black
EVGA SuperNOVA 650 P2
Silverstone Raven 3
Operating System
Windows 10 Home
Acer Predator XB271HU
Acer H236HLbmjd
Keyboard
Topre Realforce 104UG HiPro
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
MadSupra354 is offline
post #12 of 20 (permalink) Old 04-28-2020, 12:40 PM
rdr09's Avatar
Rep: 886 (Unique: 640)
You sure that uv is stable? You might want to reset while troubleshooting.
Also, have you updated your chipset driver? Don't worry - it is stable contrary to what's in the news.
https://www.amd.com/en/support/chips...ocket-am4/x370
Only issue i had was installing. rares told me to uninstall old chipset driver first before installing new one. Go to add and remove programs it should be labeled just that AMD chipset driver.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #13 of 20 (permalink) Old 04-28-2020, 12:46 PM - Thread Starter
Supra
Rep: 0
Stable with Firestrike and Timespy. Like I said, this happens without the undervolt. It happened with a Vega 64 and a RX 5700 XT as well.
Yep, I'm aware of the chipset driver problems. I have to uninstall the newer ones regardless, otherwise the installation will fail. I've got the latest, reinstalled it once because I had vcore issues but it's fine.
Greyscale
(16 items)
Ryzen 5 3600
Corsair Force GS
WD Caviar Blue
WD Caviar Black
Silverstone Raven 3
Operating System
Windows 10 Home
Acer H236HLbmjd
Keyboard
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
post #14 of 20 (permalink) Old 04-29-2020, 11:15 AM - Thread Starter
Supra
Rep: 0
It is not the PSU cables' connection and it isn't my 1TB WD Black drive.
My FCLK is currently at 1333MHz, if this fails, I'll try an older BIOS. If that fails, then there's no way this isn't defective hardware.
Greyscale
(16 items)
Ryzen 5 3600
Corsair Force GS
WD Caviar Blue
WD Caviar Black
Silverstone Raven 3
Operating System
Windows 10 Home
Acer H236HLbmjd
Keyboard
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
post #15 of 20 (permalink) Old 04-30-2020, 11:09 AM - Thread Starter
Supra
Rep: 0
By the way, is it anything to worry about that my RAM voltage will fluctuate between these two voltages when it's set at 1.35v in the BIOS?
Greyscale
(16 items)
Ryzen 5 3600
Corsair Force GS
WD Caviar Blue
WD Caviar Black
Silverstone Raven 3
Operating System
Windows 10 Home
Acer H236HLbmjd
Keyboard
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
post #16 of 20 (permalink) Old 05-01-2020, 01:34 AM
amin12345's Avatar
Rep: 4 (Unique: 4)
Attachment 342610
That is normal.
Download AIDA64 go in Tools/system stability test/ tick only (stress system memory) let it run for 15mins if there is an problem with your RAM you will get an error red warning! if no errors now try tick, stress CPU, stress FPU, stress cache let it run for 15mins. and lately stress test the GPU for 15mins.
amin12345 is offline
post #17 of 20 (permalink) Old 05-01-2020, 07:50 AM - Thread Starter
Supra
Rep: 0
Quote: Originally Posted by amin12345 View Post
That is normal.
Nothing. Stressed the CPU for 30 minutes even. I have Karhu and 3DMark btw, Did Karhu with FPU for 1000% with no errors. Maybe I need to stress the CPU and memory for longer? Right now it seems like only MemTest86 is showing errors after 2 runs for 8 passes.
An issue as difficult as this can only happen to me smh.
Greyscale
(16 items)
Ryzen 5 3600
Corsair Force GS
WD Caviar Blue
WD Caviar Black
Silverstone Raven 3
Operating System
Windows 10 Home
Acer H236HLbmjd
Keyboard
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
post #18 of 20 (permalink) Old 05-02-2020, 09:58 AM
amin12345's Avatar
Rep: 4 (Unique: 4)
[QUOTE=MadSupra354;28433218]
That is normal.
Download AIDA64 go in Tools/system stability test/ tick only (stress system memory) let it run for 15mins if there is an problem with your RAM you will get an error red warning! if no errors now try tick, stress CPU, stress FPU, stress cache let it run for 15mins. and lately stress test the GPU for 15mins.[/quote
If all your components are stable then I could come to one conclusion and that is software related like drivers and ryzen master and such if you have ryzen master uninstall it.
post #19 of 20 (permalink) Old 05-03-2020, 11:52 AM - Thread Starter
Supra
Rep: 0
Reading about this guy who had the exact same problem, and he bought his 3600 in July as well.
I had a look at the VRMs the best I could and they look fine. They never get above 63° anyway.
Don't get WHEA errors.
Plugged two separate cables into my 2070S.
Greyscale
(16 items)
Ryzen 5 3600
Corsair Force GS
WD Caviar Blue
WD Caviar Black
Silverstone Raven 3
Operating System
Windows 10 Home
Acer H236HLbmjd
Keyboard
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
post #20 of 20 (permalink) Old 05-03-2020, 11:54 AM - Thread Starter
Supra
Rep: 0
I don't have it. This is a fresh install of Windows. It's kind of impossible that it's drivers. No one in my TenForums thread has indicated that it could be drivers.
Here's a pastebin of drivers.
Greyscale
(16 items)
Ryzen 5 3600
Corsair Force GS
WD Caviar Blue
WD Caviar Black
Silverstone Raven 3
Operating System
Windows 10 Home
Acer H236HLbmjd
Keyboard
Mouse
Mionix Naos 7000
Mousepad
Mionix Alioth XL
Audio
Hifiman HE-500
