Cable burnt plz help - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 05-01-2020, 12:46 PM - Thread Starter
Rep: 1 (Unique: 1)
Bought my Corsair 460x case second hand, seems the 2nd case fan has heated up? Can see the copper wire showing, can I replace the cable or do I need to replace the whole fan?
I am a first time builder...
Rhysc is offline
post #2 of 5 (permalink) Old 05-02-2020, 06:17 AM
Rep: 0
I wold replace the whole fan since there obviously is some issue that overheated that wire enough to do that. I would not think LED's could even draw that much. Or was the wire pinched somewhere and shorting out? If that is the case you could try to replace the wire. I would personally just buy a new fan.
MSI MEG X570 Ace
AMD Ryzen 9 3900x
Corsair H115i Platinum, Corsair Crystal 570x RGB Case
32GB Corsair Vengence RGB Pro 3600 @3800
MSI Geforce RTX 2080 Super Ventus SX OC w/ Acer Predator X34P
jamie1073 is offline
post #3 of 5 (permalink) Old 05-02-2020, 07:11 AM
On the way out
iamjanco's Avatar
Rep: 141 (Unique: 66)
Please delete.
iamjanco is offline
post #4 of 5 (permalink) Old 05-02-2020, 07:12 AM - Thread Starter
Rep: 1 (Unique: 1)
Thanks mate, I’ve ordered a new hd120..there’s two connections on the new fan? Does one go into the rgb supply labeled 2 in my photos and the other end into motherboard?
Rhysc is offline
post #5 of 5 (permalink) Old 05-02-2020, 08:12 AM
TheBDK's Avatar
Rep: 25 (Unique: 21)
Yeah that looks dangerous not only for you, but also for you expensive components. New power supply please, and not the cheap garbage.
TheBDK is offline
