Errors in memtest86 using stock settings (2700X) - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 05-08-2020, 09:30 PM - Thread Starter
Rep: 0
Hey all, my computer is crashing using stock settings and I'm hoping someone can help me troubleshoot what's going on with my build. I was using a 1700 in this build previously and don't recall coming across any issues.
Specs:
CPU: R7 2700X
Mobo: X370 Crosshair 6 Hero
Memory: Corsair 2x8GB 3200Mhz CL16
PSU: EVGA G2 750W PSU
GPU: 1080 Ti
What prompted me to start troubleshooting the memory is when I tried running it at it's XMP profile (3200Mhz) and it started rebooting & crashing. I played around with the timings for a few days. Nothing worked, so I kept reducing the memory clock until I went back down to stock, using memtest86 to check errors.
Decided to clear the CMOS and run memtest86 using stock settings.
- Seeing 0-50 errors on each pass (error logs attached).
- All errors are on one CPU thread (10)
- Tried each stick in each DIMM slot, no errors encountered at all (no errors in single channel)
- Changed BIOS from 7704 to 6401, no change.
I don't have spare parts that I can use to determine exactly which part is causing the errors, though I suspect it is the CPU as I don't recall noticing any issues when an R7 1700 was in the same build and all memtest86 errors are shown on only one thread.
Is there anything else I could try? And if not, should I RMA the CPU or memory first?
Aim is for least down time as possible.
Thanks in advance
Alex
alox is offline
post #2 of 6 (permalink) Old 05-09-2020, 01:28 AM - Thread Starter
Rep: 0
So I've been running memtest86 non-stop since posting this, and no errors have been found.
This has happened a few times over the past few days, but after playing some games and going back to memtest, I'll see the same errors...
Just thought this might be worth adding...
alox is offline
post #3 of 6 (permalink) Old 05-11-2020, 03:02 AM - Thread Starter
Rep: 0
Bump. Still seeing errors in newest version of memtest86.
Hasn't crashed in game for a few days, but do see crashes as soon as I even apply a 2666Mhz RAM OC at 1.36v and really loose timings which is a huge pain given I paid extra for fast RAM as well as an open loop through the CPU & VRM.
Any advice is appreciated.
alox is offline
post #4 of 6 (permalink) Old 05-11-2020, 03:11 AM
rdr09's Avatar
Rep: 886 (Unique: 640)
Two things.
1. I'm not sure if Memtest is a good test to run on Ryzen. Not sure if it has been updated for newer architecture. I suggest using something else. Follow this thread . . .
https://www.overclock.net/forum/13-a...ram-bench.html
2. Is that RAM kit Vengeance? I've seen other having issues with Corsair RAM on Ryzens but with the help of the DRAM Calculator you might get it to run the manufacturer's spec.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #5 of 6 (permalink) Old 05-11-2020, 04:38 AM - Thread Starter
Rep: 0
Quote: Originally Posted by rdr09 View Post
Two things.
Thanks for the response.
Judging by the change logs, looks like memtest has been updates for Ryzen, but I'll absolutely try other options.
Yes, the kit is Samsung E-Die Vengeance 3200 C16. I can boot with "safe" timings but crashes 5 min into a game even when I raise voltages.
alox is offline
post #6 of 6 (permalink) Old 05-11-2020, 04:46 AM
rdr09's Avatar
You can try setting DOCP 3200 MHz but raise the voltage a bit. Say 1.37v? If still no go, then go use the Calculator again. There is a new version of the DRAM Calculator out. When you use it, try all the recommended inputs and their alternates.
Check post #7400. Use the TM5 included by Kedarwolf. Run as Administrator.
https://www.overclock.net/forum/13-a...bench-740.html
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
Tags
2700x , am4 , Crosshair , hero
