I need Help with bios - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 05-15-2020, 08:16 PM - Thread Starter
caleb's Avatar
Rep: 19 (Unique: 19)
I did a new build with 3600x and a 370 chipset crosshair vi. I know the bios needs to be flashed I tried it once. The mobo shows 8x on the Qled screen as in 8 and nothing behind it no light in the second character space. I plugged in a speaker and no boot sounds are made, it just sits and idles....I did try to flash the bios the lights did everything right but I am getting no boot. Tried some more times, hopefully I didn't just brick this.
Thanks for help and suggestions.
95.567% of people make up the stats in their sig. If you are part of the 4.433% who uses real stats, put this in your sig....errr, or is that made up??? confused.gif
caleb is offline
post #2 of 4 (permalink) Old 05-15-2020, 08:32 PM - Thread Starter
caleb's Avatar
So Ive never done this before and was told it would be done after the flashing. Well mine flashed 3 times then went solid. If you know what this means let me know im assuming it didn't work....
Edit: apparently it flashes slow then fast then turns off. Mine only flashed a couple times then stayed solid..
caleb is offline
post #3 of 4 (permalink) Old 05-17-2020, 11:52 AM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 3 (Unique: 3)
Don't u need another CPU to flash the bios with such old motherboards?
Sent from my ONEPLUS A6003 using Tapatalk
  • Ryzen 3600x @4490mhz, Mugen Rev.B, v1.46, 3rd position at HWBOT
  • Gigabyte Aorus Elite x570
  • G-SkillLL F4-3200C15D-16GTZ Trident Z Series CL15 Bdies @3733 15-14-13-1T 1.46v
Official Ryzen 5 3600x Owner!
rastaviper is offline
post #4 of 4 (permalink) Old 05-21-2020, 03:03 PM
Rep: 1 (Unique: 1)
You need to make sure the USB drive is FAT32 and is plugged into the correct USB port on the back of the MB, and the BIOS file is named correctly. Your manual should indicate the correct USB port. From what you have described the issue is one of the 3 things I mentioned.
Ryzen 3950X Build
(18 items)
3950X
Gigabyte X570 Aorus Extreme
PowerColor RX 5700XT Liquid Devil
MSI RX 5700 XT Water cooled
GSkill F4-3600C16D-32GTZN
Samsung NVMe EVO 970
Samsung SSD 850 Pro
GB Aorus NVMe Gen4 SSD
Optical Drive
LG BDDVDRW
Seasonic
Optimus Foundation water block/custome loop with 360 rad.
Lian Li 011 Dynamic XL
Operating System
MS Win10 Pro
Samsung LC27HG70QQNXZA
Keyboard
Logitech G815
Mouse
Logitech G502
Other
Liquid Metal Conductonaut used on CPU and GPU
jfrob75 is offline
