[Problem]Double Click Open Properties/Keyboard Malfunction - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 03-01-2011, 12:52 AM - Thread Starter
sulphur's Avatar
Rep: 2 (Unique: 1)
First Sorry If it is a repeated thread but,i tried searching but found nothing.
I'm having a problem since one week,which makes me kinda furious.
Problem is:
  • When I double click on an icon,it opens Properties Windows.
  • Keyboard not working,when i press anykey it sometimes open random tabs(File,View,Edit).
  • When I press right click on an icon,the menu disapears so fast that I can't even read/press anything.
I've tried to use:
  • Registry Mechanic.
    1. Custom Controls: (HKEY_Classes_Root\TypeLib\{CEF63746-AD34-42D0-9138-39D83ECB77CB}\1.0\HELPDIR
    2. Software\Microsoft\Windows\CurrentVersion\Explorer\Startpage\NewShortcuts
  • Regcure.(Results:Nothing)
  • AVG internet security.(Results:No Viruses.)
  • Reboot.[Nothing]
  • System Restore.[Same Problem]
  • New Keyboard/Mouse.[Same Problem]
Computer Specification:
  • CPU:Intel i7 930
  • Motherboard:Asus P6T Deluxe
  • Graphics Card:Ati 4850X2
  • HDD:1TB WD Black,500GB WD.
  • OS:Windows 7 x64
Thanks in advance,
Omar.
sulphur is offline
post #2 of 6 (permalink) Old 03-01-2011, 12:57 AM
t0adphr0g's Avatar
Rep: 63 (Unique: 57)
try rebooting?
t0adphr0g is offline
post #3 of 6 (permalink) Old 03-01-2011, 01:03 AM
Retired Staff
Transhour's Avatar
Rep: 368 (Unique: 230)
honestly sounds like you got a stuck key on the keyboard, have you tried unplugging the keyboard, and see if clicking on a icon does what it is suppose to do, and if the context menu will appear correctly when right clicking?
I follow the Sociopath less travelled.
Linux going mainstream, Great, now I gotta use BSD.
Customize a Ubuntu Kernel
Transhour is offline
post #4 of 6 (permalink) Old 03-01-2011, 02:11 AM - Thread Starter
sulphur's Avatar
Rep: 2 (Unique: 1)
Tried new Keyboard,same problem,then now replugged old one, works well till now.
Edit:not working again.
sulphur is offline
post #5 of 6 (permalink) Old 07-26-2012, 05:18 PM
qfsxs's Avatar
Rep: 0
I had a similar problem recently, there is a mouse/keyboard reset command. All you have to do is press and hold Left Shift + Left Ctrl + Left Alt and Right Shift + Right Ctrl + Right Alt.
qfsxs is offline
post #6 of 6 (permalink) Old 09-14-2018, 08:27 PM
Rep: 0
That worked dude...thanks a bunch
NecromancEby is offline
