Building subzero Glycol Chiller from 2 ton window AC unit??? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 03-19-2019, 07:09 AM - Thread Starter
Rep: 0
Im looking to take a 2 ton window AC unit and build a glycol recirculating chiller. Most AC unit evaporators will not get below sub zero temps. is there a refrigerant type change or modification that can be made to a 230v 2600watt 2-ton window ac to get the evap coil temps lower? the colder the better for my needs. this sized unit is typically 40-45oz of R410a refrigerant with 450psig high side and 250psig low side pressures.
p0opstlnksal0t is offline
post #2 of 3 (permalink) Old 03-24-2019, 05:01 PM
Hardware Princess
Hydroplane's Avatar
Rep: 22 (Unique: 20)
The evaporator can get below subzero, it's just that the controls generally don't let it. They can be rewired to run continuously. Glycol does not work well at these temps since it turns into a 7-11 slushee lol. I recommend an ethanol/water half and half mix. Basically cheap Vodka would work well. Alcohols flow much better at low temps. Go with a refrigerant with a low boiling point like R22, if you can find it. My R22 1/2HP chiller (former dehumidifier) can bring the liquid down to -30C.
Adding more capacity will not lower the temp much - a 2HP compressor is more than enough (~1600W)
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.4v
EVGA Z390 Dark
Titan RTX 2085/7256
None
OCZ Vertex 4 256GB
EVGA 1300 G2
Dehumidifier
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
Trident Z 32GB (4x8GB) 3200C14 @ 3800C16 1.50V
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #3 of 3 (permalink) Old 03-24-2019, 05:11 PM
white owl's Avatar
Rep: 134 (Unique: 101)
Exactly this.
You need to wire the pump so it's always running or use a different thermostat so it can cool to a desired temp.
As @Hydroplane said antifreeze/glycol aren't good enough, you need something volatile like alcohol because it's freezing to boiling scale is much lower than glycol. Isopropyl alcohol freezes at -89°.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
