Hybrid CPU Air / Water block - Page 8 - Overclock.net - An Overclocking Community
post #71 of 80 (permalink) Old 05-16-2012, 06:53 AM - Thread Starter
Magi8800's Avatar
Rep: 2 (Unique: 2)
Originally Posted by warpuck View Post
Looking the OEM coolers off my 960t & 555BE that I never used, ,,,. fitting 6 3/16 copper tubes through the outer sides (5/16 thick) is possible and you could still use the stock clamp.
I have thought using one of these Z7UH40Q001-1610
http://www.ebay.com/itm/AMD-AVC-Z7UH40Q001-AM3-Quad-Heatpipe-CPU-Cooler-Z7UH40Q001-1610-/190677494714?pt=US_CPU_Fans_Heatsinks&hash=item2c6543abba
and just pumping coolant through them after wacking off the fins and flaring the tubes.
Of course I would end up with anther fan I don't use.
I have a new heater core off a 88 Lincoln that I could also use. I could probably get by just sitting it on top of the case with no fan.
I find it odd that I can by a rebuilt water pump for a 302 Ford for less than water pump for PC cooling system.
That would probably work well. I was thinking of trying that as well. Wait till you see the new one, Ill try to remeber to post some pictures finally. Had a bit of an issue with Drill bits breaking, so I got a little excited with the hammer. She's a little beat up but everything that matters is where it needs to be.
Nothing over 50 degrees allowed.
Magi8800 is offline
post #72 of 80 (permalink) Old 05-16-2012, 06:56 AM - Thread Starter
Magi8800's Avatar
Rep: 2 (Unique: 2)
Oh also, If your looking for a cheap water pump. Use a pond one from a hardware store, I found one for 13 dollars at home hardware. You just need a container to submerge it in which can double as your resevoir.
Just use a power bar with your comp and pump hooked to it, that way you cant turn on PC without powering pump. Thats what I have to do with my Zalman Reserator anyways.
Magi8800 is offline
post #73 of 80 (permalink) Old 05-18-2012, 10:16 PM
J-Key's Avatar
Rep: 1 (Unique: 1)
Wow.. DIY heatsink look cool MAGI... thumb.gifbiggrin.gif:thumb:
J-Key is offline
post #74 of 80 (permalink) Old 05-20-2012, 09:53 AM - Thread Starter
Magi8800's Avatar
Rep: 2 (Unique: 2)
Finally some new photos, sorry 'bout the delay.
450
Had a bit of trouble with bits breaking off so its not as pretty as I though it would be.
Got the issue solved now I think, cutting fluid is great.
450
Going to cap off these collars and put a nipple in at 90 degrees so they stick straight up when mounted.
450
450
Magi8800 is offline
post #75 of 80 (permalink) Old 05-20-2012, 09:55 AM - Thread Starter
Magi8800's Avatar
Rep: 2 (Unique: 2)
I think using some JB weld or similar will work perfect for sealing it all up.
Magi8800 is offline
post #76 of 80 (permalink) Old 06-17-2012, 12:03 AM
juneau78's Avatar
Rep: 2 (Unique: 2)
juneau78 is offline
post #77 of 80 (permalink) Old 06-17-2012, 09:11 PM
Drewmeister's Avatar
Rep: 18 (Unique: 16)
Hey Magi.. looking good, how are things coming with this?
I see you went through some drill bits there. Cobalt drill bits work best for alum and copper.. drill at slow speed and as you know.. use lots of cutting oil.
Hey juneau78, yes you're at the right thread. Thanks for the link.. great mod on that heat pipe! thumb.gif
Drewmeister is offline
post #78 of 80 (permalink) Old 06-17-2012, 09:24 PM
Stealin Yer Sammich!
Erick Silver's Avatar
Rep: 302 (Unique: 254)
Oh wow! I just looked at that link to the foreign site. I have a Xiggy DK that I am not using. I wonder how effective doing something like that would be? My mind is racing now!
"I REJECT YOUR REALITY, AND SUBSITUTE MY OWN!" - Adam Savage
I FOLD FOR: MY MOTHER IN LAW. A 2X BREAST CANCER SURVIVOR.~MY SISTER IN LAW. A LUNG CANCER SURVIVOR~MY SISTER TAKEN AT AGE 25 BY OVARIAN CANCER.~MY MOTHER TAKEN AT AGE 50 BY OVARIAN CANCER~MY GRANDMOTHER TAKEN BY CANCER AND ALZHEIMERS DISEASE.
PLEASE. DON'T TRY AND PERSUADE ME NOT TO FOLD, IT WILL FALL ON DEAF EARS
Red Steel
(19 items)
Blue Butterfly
(12 items)
AMD Phenom II X6 1090T >STOCK<
Asus CROSSHAIR V FORMULA-Z
ASUS Geforce GTX 1050 Ti ROG STRIX
Avexir Core Series 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Memory Kit Model AVD3U16001108G-1CIR
Seagate 250GB SATA III MLC Internal Solid State Drive
Seagate Barracuda 7200.10 ST3250310AS 250GB 7200 RPM 8MB Cache SATA
SAMSUNG SpinPoint T Series HD320KJ 320GB 7200 RPM 8MB Cache SATA
Seagate Barracuda 7200.10 ST3500630AS 500GB 7200 RPM 16MB Cache SATA
Optical Drive
Lightscribe DVD/RW
Seasonic Focus+ 750FX
Cooler Master Hyper 212+ in Push/Pull
HAF 922 Custom Painted
Operating System
Windows 10 Pro 64 bit
Phillips 32" LCD Flatscreen @ 1920x1080
Keyboard
Ducky DK1008 w/ Cherry MX Bkack Switches
Mouse
Logitech G502 Proteus Core
Mouse
Ratpadz XT
Audio
EACH G2000
Other
Lamptron FC6 Fan Controller
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
ASUS M4A79T Deluxe AM3
Asus R7 260X OC 2GB
G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 1600MHZ
>>320GB with a 1TB External<<
Optical Drive
>>DVD/RW<<
Xigmatek Dark Night
>>Antec 902 w/ Blue LED Fans<<
Operating System
>>Windows 7 Ultimate 64bit<<
>>22" Westinghouse WS<<
Keyboard
CM Storm Devastator MB24
Mouse
CM Storm Devastator MS2K
Erick Silver is offline
post #79 of 80 (permalink) Old 06-18-2012, 12:47 PM - Thread Starter
Magi8800's Avatar
Rep: 2 (Unique: 2)
Hey, sorry for the lack of updates, its been sitting half finished for a month. Stuff keeps coming up, hopefully I get a few hours free to work on it soon.
Cobalt is the best? I figured the HSS would be good since its harder then copper/aluminum, Ill try some cobalt bits.
Lack of a power supply is putting a damper on things, I don't want to experiment on my main system.
I was thinking of trying the heatpipe one but I gave/sold all my coolers that were like that.
Magi8800 is offline
post #80 of 80 (permalink) Old 11-28-2016, 08:58 AM
Unnerup's Avatar
Rep: 0
On your first prototype. How did you get the copper pipe bend so cleanly so close to the heatsink?
Unnerup is offline
