Extreme Cooled Raspberry Pi - Page 3 - Overclock.net - An Overclocking Community
post #21 of 117 (permalink) Old 06-26-2013, 06:44 PM
100LB Rig Club
RussianJ's Avatar
Rep: 93 (Unique: 86)
RussianJ is offline
post #22 of 117 (permalink) Old 06-26-2013, 07:12 PM - Thread Starter
neo565's Avatar
Rep: 32 (Unique: 23)
Tried setting multiplier anywhere from 11-21. Still didn't work.
neo565 is offline
post #23 of 117 (permalink) Old 06-27-2013, 07:15 AM - Thread Starter
neo565's Avatar
Please don't ask me to overclock further because I don't want to fry my Raspberry Pi.
neo565 is offline
post #24 of 117 (permalink) Old 06-27-2013, 07:34 AM
hawkeye071292's Avatar
Rep: 58 (Unique: 48)
hawkeye071292 is offline
post #25 of 117 (permalink) Old 06-27-2013, 07:37 AM
You may need to find a firmware that will remove those "safety" restrictions.
post #26 of 117 (permalink) Old 06-27-2013, 07:38 AM
Operant's Avatar
Rep: 1 (Unique: 1)
I have one being shipped to my house right now so I'll get a chance to start playing with it. Unfortunately I don't have a dewar for LN2 though I might go the spray can route. Could something similar to the "zombie mods" for GPUs work here? I'm wondering if the power delivery bits aren't providing a stable voltage to the SoC.
Feel free to ask about circuits or code and I'll do what I can to help!
Operant is offline
post #27 of 117 (permalink) Old 06-27-2013, 07:41 AM
Yea I bet thats what it is. May need to be soldered again with better materials. I mean the unit itself is cheap, so you can assume it is made cheap as well. Maybe add a little to it to make the bus wider? Not a soldering fanatic, but shouldn't that provide more stable power?
post #28 of 117 (permalink) Old 06-27-2013, 07:45 AM
ivanlabrie's Avatar
Location: Buenos Aires, Argentina. Land of the obscenely expensive hardware
Rep: 350 (Unique: 189)
Epic stuff!
What's that gas and where do you find it? is it cheaper than ln2?
ivanlabrie is offline
post #29 of 117 (permalink) Old 06-27-2013, 07:47 AM
Originally Posted by ivanlabrie View Post
Epic stuff!
Its just basic dust remover. Just compressed canned air right? I am sure it is cheaper than ln2 but how long does 1 can last?
post #30 of 117 (permalink) Old 06-27-2013, 08:29 AM
Operant's Avatar
Rep: 1 (Unique: 1)
Well, that would contribute more to heat than anything, which can contribute to instability on it's own. You do need a big enough trace for whatever current and voltage you want to run through it. My guess for the culprit is whatever ICs are actually handling the power delivery on the board. Bypassing those with an external setup that is normally overkill allows for a much more stable voltage (less ripple should increase stability to a point). PSU reviews from sites like johnnyGURU.com or overclockers.com (specifically Bobnova) (also note Mods I'm merely pointing to reviews and not advertising here) are excellent examples of how this is tested and shown. There are other sites as well but those are the two that popped into my head first. It all depends on what components are used to get the power that is required. I can explain more if you want.
However, I should point out that I could be completely wrong here. These SoC do have limits just like CPUs and you'll hit them eventually. I haven't used a raspberrypi nor have I seen what the voltage line looks like under a scope (while it is running) so I can't say anything definitive.
Operant is offline
