CPU block with integrated IHS? Silver IHS? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 02-25-2017, 09:57 AM - Thread Starter
paskowitz's Avatar
Rep: 58 (Unique: 45)
Question 1:
I was thinking today while deliding my CPU... what if there was a CPU block that didn't have a traditional cold plate but instead had one that was the exact shape of the IHS. The CPU block/IHS, would then mount directly to the die/chip. Essentially like a direct or naked die mount, with the advantage of using the integrated IHS for better contact. So with that said... obviously, this would provide better cooling than traditional mounting, but would it be better thermally than direct/naked mounting? Yes, I understand why this doesn't exist, I'm just curious. biggrin.gif
Question 2:
Obviously, it is obvious that that silver is much more expensive than copper. Would a silver IHS provide any substantial thermal benefit over a copper IHS?
Bonus questions:
What would perform better thermally, a thinner IHS or a thicker IHS? We are talking die to cold plate thickness/height here. I am assuming thinner, since we are talking heat transfer, not dissipation or capacity?
Would there be any negative reaction (corrosion, bonding/adhesion, etc) between gallium (CLU) and silver?
Phanteks Enthoo Evolv Tempered Glass: Anthracite | i7 4790K: 4.8Ghz/1.33v | EVGA GTX 980 Ti Classified: 1535/8100Mhz | KLEVV Genuine: 2666Mhz 16Gb DDR3 | Asus Maximus VII Formula | EVGA G2 850W | Samsung 950 PRO 256Gb NVMe SSD | Samsung 850 EVO: 500Gb SSD | HGST Deskstar NAS: 6Tb | Acer Predator X34 | CPU Delid w/CLU on die&IHS | CLU and Fujipoly pads on GPU | Watercool Heakiller IV Pro | EK-FC780 GTX Classy | Hardware Labs Nemesis 280 GTS Xflow | Hardware Labs Nemesis 360 GTR | 6x Corsair ML Pro 120 | 2x Corsair ML Pro 140 | 17995 3DMark Firestrike (Top 100 WW w/4790K&980 Ti) | NZXT HUE+ | Phanteks RGB LED strips | MNPCTech metal cable combs | Primochill carbon fiber sleeving | Viviid Vinyl Epoxy carbon fiber vinyl wrap
paskowitz is offline
post #2 of 8 (permalink) Old 02-25-2017, 11:49 AM
I Love this Hobby!
Gunderman456's Avatar
Rep: 592 (Unique: 492)
1. If it did exist it would be better I would think.
2. Same, silver coolers don't exist, but I would say copper would cool better anyway.
3. As in #1, the thinner the things are between transfers the better I would think. That is why naked cooling is even better.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ 1160GHz Core/1350GHz Mem
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Open Water Loop
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Nixeus EDG 27" Freesync 1440p 144Hz
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Microsoft Sidewinder X5
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Intel Core i5-3570K @ 4.5GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990
G.SKILL Ripjaws X DDR3 8GB 1600MHz
Crucial SSD 128GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Corsair Vengeance MM200
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
AMD Athlon II X4 640
ASRock N68C-GS
NVIDIA 6600GT
G. Skill Ripjaws DDR3 1600MHz
WD Caviar Blue 500GB 16MB Cache 7200RPM
Optical Drive
LG Optical Drive
Thermaltake TR2 600W
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Viewsonic 19” Flatscreen CRT
Keyboard
Gigabyte GK-K6800 103
Mouse
Zalman ZM-M300
Mouse
Gunderman456 is offline
post #3 of 8 (permalink) Old 02-26-2017, 04:18 PM
RnRollie's Avatar
Rep: 160 (Unique: 125)
Silver coldplate standard on the top line of Aquacomputer Kryos Next
https://shop.aquacomputer.de/product_info.php?products_id=3573&XTCsid=6hsu3alk3rk1l7u5tm74vvcfs5gha6gq
on some of their older models also, btw.
Also, if you would take an IHS to a silversmith , and tell him you want the same thing made out of as pure silver as possible (while still strong enough) , i am pretty sure (s)he can do that for you
However, price will most likely exceed the above waterblock. Not because silver is "soo expensive", because it really isn't that much different in pricing as copper (have you seen copper prices recently?) ... but because of the hours which will go into handcrafting a silver IHS.
And in the end, all that for a net gain of 2 to 5°C
You see, the copper IHS is not the barrier here.. the thermal barrier is the TIM. You'll gain more from eliminating the TIM as from using "exotic" metals.
Lap both the CPU and the Waterblock to such a perfect finish that they stick to each other and you can do away with TIM. Or just apply TIM and wipe it off so there is only a film so thin that its only a sheen.
All that being said.. delid and go for direct/naked. Although in reality this requires a shim between die & block. But you can get a shim of the right thickness made out of silver also.. after all its only a square piece of silver 0.8 or 0.5mm thick. And guess what.. silversmiths have things like that laying around, only needs to be cut to the correct size smile.gif
One more thing... silver is a far/high as you can go. Gold is to "soft" and diamond is too "irregular". That said, diamond can be "grown" with its cells oriented such that thermal conductivity is optimal; just like Graphene can be constructed as such... one drawback thou to "grown" diamond & graphene... the pricetag.
footnote: the vials of graphene floating in water on ebay... snake oil, a scam. They have no practical application unless you posses very very very tiny tweezers and an electro-microscope to correctly orient the particles by hand. And IF you do have that equipment.. please present yourself to Marvel Studio and apply for the role of evil mastermind in the next Avengers movie. smile.gif
Reality is futile, you will be assimilated by (your) perception.
Golden Rule(s) for Fans: CHEAP + SILENT = NO PERFORMANCE ▼ CHEAP + PERFORMANCE = NOT SILENT ▼ SILENT + PERFORMANCE = NOT CHEAP
+Most SILENT Case Fans are not well suited for CPU-HS-Towers or Radiators
+Most SILENT Case Fans are not well suited for cases, especially if they have filters. (added by doyll on 23/04/2014)
RnRollie is offline
post #4 of 8 (permalink) Old 02-26-2017, 04:38 PM
I Love this Hobby!
Hah, a silver block does exist, wonder on the purity and that price. eek.gif
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Optical Drive
Open Water Loop
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Mousepad
Audio
Crucial SSD 128GB
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
ASRock N68C-GS
NVIDIA 6600GT
Optical Drive
LG Optical Drive
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Keyboard
Mouse
Zalman ZM-M300
Mouse
post #5 of 8 (permalink) Old 02-26-2017, 04:55 PM
RnRollie's Avatar
.925 Stirling Silver
You cant get much higher as that without it becoming too "soft" and too easily tarnished
RnRollie is offline
post #6 of 8 (permalink) Old 02-26-2017, 05:41 PM - Thread Starter
paskowitz's Avatar
Jesus, dat Kryos price tag. Ouch. Thanks for the detailed reply!
post #7 of 8 (permalink) Old 02-26-2017, 05:58 PM
Iconoclast
Blameless's Avatar
Rep: 3135 (Unique: 1869)
Originally Posted by RnRollie View Post
Gold is to "soft"
Gold also has worse thermal conductivity than silver or copper.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #8 of 8 (permalink) Old 02-27-2017, 04:02 AM
RnRollie's Avatar
Gold is to "soft"
true, i shouldn't have it mentioned
RnRollie is offline
