Window AC Loop Chiller - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 03-07-2018, 09:09 AM - Thread Starter
External VRM FTW
mllrkllr88's Avatar
I am starting a project which I have wanted to do for years. The idea is to take a window AC unit, and dunk the condenser (cold radiator) in a cooler of water, then run the loop through the water. I have been keeping my eye on used window AC units for a while and this weekend one popped up in my neighborhood for $35.
10k BTU window AC with 1HP compressor
Time to rip and tear!! I had to disassemble most of it to free up the condenser.
There is only one tricky part to this whole project. The thermal sensor will stop the compressor from running 24/7, this is obviously bad since it needs to run constantly. Here is what I did to trick it:
-Find the thermal sensor, mine was right in front of the condenser
-My thermal sensor was a little devices called a thermistor, which changes resistance with temperature.
-I cut the thermistor, read the resistance at ambient and then warmed it up to 110f and read resistance again. The 55f ambient resistance was 11k ish and 110F resistance was 6.8k ohm.
-In place of the cut thermistor, I soldered on equivalent 6.8k of resistors to force the AC unit into thinking it is 110f degrees
Here is what it looks like after just 5 minutes running 24/7
That's all for now...next up I need to drop it in a bucket of water and run the loop through it. I am obviously going to need some anti-freeze of some sort and likely a submersible pump since the large reviver will be located under the bench rig.
24/7 BENCH
(9 items)
[LGA115x] 8700k, 7700K, 7350k, G3258
[LGA2066] 7940X, 7740X
[OCF FTW] X299 OCF, Z170M OCF, Z97 OCF
E-Power, G-Power, H-Power, A-Power
B-DIE, HYKO, PSC, MFR
Seasonic Prime Platinum 1200W
Kingpin Cooling: Venom & T-REX
2x360 RAD Custom Loop
Dimastech Easy V3.0
mllrkllr88 is offline
post #2 of 8 (permalink) Old 07-11-2018, 08:58 AM
Linux Lobbyist
Rep: 0
Have you thought about insulating the Glycol supply and return lines to allow the system to run more continuously and balance out for the duration of use instead of cycling on and off? Not sure what your demand is for the unit, but extending the life of that compressor is always a great idea. seen from TubeMate Psiphon Test DPC Cheers..
matador86 is offline
post #3 of 8 (permalink) Old 07-11-2018, 09:17 AM - Thread Starter
External VRM FTW
mllrkllr88's Avatar
@matador86 That is good advice, I will certainly do this going forward.
My chiller project has been a bit of a struggle. The problem I am having is that the system is too powerful and freezes any solution I submerge the evap in. Currently, the solution is 4 gallons de-icer and 1 gallon water, and it still freezes over.
I am using one extremely powerful submersible pump for the cooling loop, and one lesser powerful submersible pump to move the coolant in the res. If I remove the smaller submersible pump, then the coolant freezes over extremely quickly.
Here you can see it frozen. Note: normally the fluid level is near the top of the evap, but that has no change on the freezing over effect.
Regardless of the problems, I am still able to achieve -10c water about 35 minutes after I turn on the AC. The overclocking results depend greatly on equipment and weather or not it scales with temp. With some modern gen CPU's like 8700k, the scaling from -10c water is about +150mhz
24/7 BENCH
(9 items)
Dimastech Easy V3.0
post #4 of 8 (permalink) Old 07-15-2018, 09:59 AM
SolarNova's Avatar
Rep: 11 (Unique: 11)
Consider using Mayhem XT-1 Nuke.
Mixture 60:40 (XT-1:water) for -50c. (R22 boils at -41c so should be fine)
£50 for 5ltr concentrate.
Also, make sure you have a good flow in the container with the evap. i would get a container that allows the evap to fit snug to sides and have a pump pushing coolant through from 1 side to ther other to ensure the fluid doesnt just sit on the evap.
The likely reason its icing up is just down to the refrigerent used, not necceserily the "power" of the AC itself. Modern AC's use r134a which has a higher boiling point of -26c which most anti freeze solution can handle. R22 on the other hand boils at -41c so your average antifreeze isnt going to cut it. For the purpose of building a sub zero chiller, R22 is what you want.
SolarNova is offline
post #5 of 8 (permalink) Old 07-15-2018, 10:08 AM
I have been using Prestone Red anticongelant antifreeze in my chiller, and it works great I have had my coolant down to -18C with no issues, I use a 60% antifreeze, 40% distilled water mix. have you considered getting this build into a chillbox?
https://www.overclock.net/forum/133-...lbox-club.html
it is a lot of work, but well worth the effort.
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #6 of 8 (permalink) Old 07-15-2018, 10:20 AM
white owl's Avatar
Rep: 136 (Unique: 103)
A sealed chillbox has always been something I've wanted to build as well. Not because I want a big box sitting in my house but because I feel like without one I'd be chasing condensation everywhere vs filling a box with argon. It's just too expensive for me lol.
OP, can't wait to see what you do. Good luck!
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #7 of 8 (permalink) Old 09-13-2019, 12:50 PM - Thread Starter
External VRM FTW
mllrkllr88's Avatar
I would like to update this thread for posterity sake. The chiller project turned out to be a great success after many rebuilds. There proved to be several critical aspects to making this work correctly. Firstly, I needed a massively overrated pump for the waterblock loop and also a smaller pump for water circulation. Second was the use of 100% windshield de-icer. 5 gallons of Prestone De-Icer However, by far, the most important aspect is that the evaporator was 100% submerged with all of the connection pipes submerged too.
With everything in place, I could turn on the AC unit and within 30 minutes I would have -35c coolant. This proved to be quite useful for benching. For most heat loads, the sustainable temperature of the coolant was about -30c.
My bench room (pre-child hahah)
24/7 BENCH
(9 items)
Dimastech Easy V3.0
post #8 of 8 (permalink) Old 09-13-2019, 02:09 PM
HWBot Bencher
Noxinite's Avatar
Strong chiller! I've considered chillers in the past as they would be super useful for benching single (and multi) legacy GPUs with a bit of cold as well as phase on CPU, but no space for them. D:
Edit: is that an unpopulated Epower V PCB on the wall?
DDR2 Frequency 1st Place = 910.1MHz DDR (1820.2MHz) - http://hwbot.org/submission/3589779
Reference Frequency 10th Place = 711.18MHz - https://hwbot.org/submission/3978447_
Noxinite is offline
