Hydroplane's 2019 Chiller Conversion Build - Page 2 - Overclock.net - An Overclocking Community
post #11 of 42 (permalink) Old 02-23-2019, 07:53 PM
wyattneill's Avatar
Rep: 7 (Unique: 7)
Very nice, well when you get around to testing that please pay an update.
wyattneill is offline
post #12 of 42 (permalink) Old 03-17-2019, 06:52 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Rep: 22 (Unique: 20)
Finally bought a real tube cutter today, instead of just using scissors which doesn't work well lol. Also some polyethylene tubing which is safe to use with ethanol. It doesn't bend too well, almost like hard tubing. The hose clamps did seem to compress it though, so hopefully it will seal well on barbs. I think I'll use the EK barbs. Just need to find a pump/res that would work.
I also need a new PSU, think I'll buy a used EVGA 1200 P2 off ebay for ~$110. It's amazing how quickly PSUs depreciated, that one's $250+ new. My 10+ year old Silverstone 1200 has like 4.8V on the 5V rail and 3.2V on the 3.3V rail, I think it's shot.
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.4v
EVGA Z390 Dark
Titan RTX 2085/7256
None
OCZ Vertex 4 256GB
EVGA 1300 G2
Dehumidifier
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
Trident Z 32GB (4x8GB) 3200C14 @ 3800C16 1.50V
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #13 of 42 (permalink) Old 03-17-2019, 08:37 PM
white owl's Avatar
Rep: 134 (Unique: 101)
The clamp over a barb should do the trick if the fit is tight, the picture you posted looks like it would be more than enough.
Did you finally settle on isopropyl and water or something else?
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #14 of 42 (permalink) Old 03-17-2019, 10:27 PM
Invalid Media
J7SC's Avatar
Rep: 6 (Unique: 5)
I've used a heat gun (low setting, safe distance) on polyethylene before to help tighten hose clamps...obviously, first try it out on a separate piece of your polyethylene tubing stock.
J7SC is offline
post #15 of 42 (permalink) Old 03-18-2019, 03:47 AM - Thread Starter
Hardware Princess
Hydroplane's Avatar
I am looking to use ethanol, just need to find a way to source it at a reasonable cost. The denatured stuff tends to have nasty additives that I don't want to breathe in. I suppose I could use 4 gallons of cheap vodka, for $100 or so lol.
The heat gun is good advice. I need to choose a pump/res so I can do some testing here. Think I'm also gonna get the Bykski full metal waterblock, since it's usable on my ancient LGA 775 parts, then I can test my insulation skills there. Much cheaper if I lose something to condensation.
CHILLER DESTRUCTION
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.4v
EVGA Z390 Dark
Titan RTX 2085/7256
None
OCZ Vertex 4 256GB
EVGA 1300 G2
Dehumidifier
Audio
Samsung 960 Evo 1TB
EVGA 1600 T2
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
Keyboard
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #16 of 42 (permalink) Old 03-24-2019, 09:14 AM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Just ordered the following:
EVGA Z390 Dark
Trident Z 4133 19-19-19-39 1.35V 2x8GB
Dimastech Test Bench (in red!)
XSPC X4 Photon 170 (glass res, the pump is plastic so may disagree with ethanol/cold temps, but pretty much all PC watercooling pumps are plastic too, so I'll see how it does. No reason to spend more on a d5 that might melt just the same lol)
EK Supremacy EVO Full Nickel waterblock
EK Barb fittings 3/8"
EVGA 1300 G2 psu
Some other stuff I'm probably forgetting
I also picked up a HWLabs 360GTX (also in red) and some EK Vardar fans for the test bench, for when I don't feel like insulating stuff. Forgot to buy a hard drive, gonna get a 250GB 970 evo at some point (don't need more space than that) for now the OCZ Vertex is fine. Considering their reliability, I must have the last functioning Vertex on earth lol.
CHILLER DESTRUCTION
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.4v
EVGA Z390 Dark
Titan RTX 2085/7256
None
OCZ Vertex 4 256GB
EVGA 1300 G2
Dehumidifier
Audio
Samsung 960 Evo 1TB
EVGA 1600 T2
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
Keyboard
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #17 of 42 (permalink) Old 03-25-2019, 04:20 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Looks like everything will be here Thursday! Well, everything except the motherboard which will show up next week when I'm in Houston lol. I can try the chiller on my ancient Q9550, though. I think the waterblock will fit that far back? Maybe. I'm thinking just put water in the tank this time, and run the temp down to the dew point. It would be a good test.
I'm looking for a way to reduce the volume of the tank so I don't need to buy $75 of Vodka lol. ROCKS maybe?
CHILLER DESTRUCTION
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.4v
EVGA Z390 Dark
Titan RTX 2085/7256
None
OCZ Vertex 4 256GB
EVGA 1300 G2
Dehumidifier
Audio
Samsung 960 Evo 1TB
EVGA 1600 T2
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
Keyboard
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #18 of 42 (permalink) Old 03-26-2019, 05:05 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Got some goodies in today from Frozen central processing unit. The polyethylene tubing wouldn't fit onto the barbs at all at first, until I hit it with the hair dryer. It's on there so tight that it doesn't even need hose clamps to not leak! It also formed into a nice romantic heart shape automatically lol. Pump is the XSPC X4 Photon 170. It has a glass res. Pretty tough to fill since there isn't an easy way for the air to escape. The top lid doesn't come off for filling like an EK D5.
I think I will get some regular PVC tubing instead. This stuff works, but will be a pain everytime I need to change something. The barbs have to be removed with pliers, and the tubing is not very flexible. PVC has an "acceptable" resistance to ethanol which is probably fine for test bench use.
Interestingly the water in the pump has warmed up to 86F just from the friction of being pumped in a loop. A good reason not to bother with two pumps in a system - it adds heat!
CHILLER DESTRUCTION
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.4v
EVGA Z390 Dark
Titan RTX 2085/7256
None
OCZ Vertex 4 256GB
EVGA 1300 G2
Dehumidifier
Audio
Samsung 960 Evo 1TB
EVGA 1600 T2
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
Keyboard
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #19 of 42 (permalink) Old 03-27-2019, 12:03 AM
white owl's Avatar
Can't you just use something else as the reservoir? Maybe like a modified cooler?
I'm pretty sure you're going to run into problems with any normal water cooling pump but I can't remember the exact sort of pump used for this, I've seen it in the 24/7 chill box thread but I can't find it...it's a pretty big thread to read through.
Either way I'm glad to see it's coming together.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #20 of 42 (permalink) Old 03-27-2019, 04:09 AM - Thread Starter
Hardware Princess
Hydroplane's Avatar
I have a 4 gallon igloo cooler to house the evaporator. Only wanted a res on the pump so I could use it to prime the pump (i.e. not run it dry), and/or reuse it later in a regular watercooled computer. The glass res should be okay, but there is a risk of the seals in the pump leaking and possibly plastic cracking. Will find out, the pump in this thing is pretty cheap lol
CHILLER DESTRUCTION
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.4v
EVGA Z390 Dark
Titan RTX 2085/7256
None
OCZ Vertex 4 256GB
EVGA 1300 G2
Dehumidifier
Audio
Samsung 960 Evo 1TB
EVGA 1600 T2
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
Keyboard
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
