Best coolant for -40c ? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 25 (permalink) Old 02-15-2019, 05:37 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Rep: 38 (Unique: 30)
Quote: Originally Posted by white owl View Post
I'd go for the cheapest between methanol and alcohl You can look up the fluid in question and find exactly what the freezing point is to eliminate guess work. Methanol is -140. Alcohol is -120ish. You should be able to add distilled water to either to make it cheaper.
Rain-X De-icer is around 35% methanol so it's a start If that still freezes, I'll locate some ethanol and cut it 50/50 with water.
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #22 of 25 (permalink) Old 02-15-2019, 07:26 PM
Overclocking Enthusiast
ozlay's Avatar
Rep: 288 (Unique: 227)
Hmm get some E85 at the gas station....
Rikka
(9 items)
Intel I5-7600k
Asrock Z270M Extreme 4
Titan X
Gskill Royal
970 Evo
Optane 900p
Seasonic Prime Snow
enthoo evolv matx tempered glass
Operating System
windows 10 pro
ozlay is offline
post #23 of 25 (permalink) Old 02-21-2019, 04:43 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Decided to try METH last night. Methanol, that is
And we have success! I saw as low as -23F / -31C on the liquid, with NO ICE. (Well, other than the frost in the picture below, but that's from the water in the air, not the methanol. Only problem is this stuff is toxic. I didn't feel safe with it in my house, so I moved it out to the garage. Even if I could seal the reservoir well enough, I don't feel like it would be safe to keep indoors. Methanol just evaporates too readily.
Based on the chemical properties, it looks like ethanol is the final ticket. It should stay liquid and flow easily at these temps in a 50/50 mix, plus be safe to have indoors in a big open top vat. Absolute worst case, might feel a little drunk lol, but that is fairly easy to detect and deal with. Not so much with methanol. Just trying to find a good place to buy the stuff, maybe as E85 or denatured alcohol. Something safe, excluding flammability - which shouldn't be too bad, considering the temperature and that it would be half (or more) water.
CHILLER DESTRUCTION
basic linux pc
(15 items)
Z390 Station
(11 items)
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #24 of 25 (permalink) Old 02-21-2019, 04:49 PM
What goes here?
speed_demon's Avatar
Rep: 142 (Unique: 101)
Happy to hear you're progressing. Just wanted to add that ethanol/methanol in the air is incredibly flammable and could easily be ignited by a small spark off your clothing or an open pilot light from your furnace. Just something to be mindful of but you probably knew this already judging by the project.
Looks good though. This is the kind of project I usually do haha.
EDIT: E85 changes gasoline percentage during the winter season. It is more like E55 or E60 at the present time IIRC. I used to run it in my drag racing cars for the higher octane and had to adjust for this.
Ryzen 3900X
MSI X470 Gaming Plus
MSI R9 390 8GB
16GB DDR4-3000
120GB HP M700 SSD
Samsung Spintpoint M9T 2TB
Seagate Barracuda 500GB
Corsair HX1200 (2017)
Thermalright True Spirit 140
Fractal Define S
Operating System
Windows 10 LTSC
Keyboard
Alienware W/Cherry MX Switches
Mouse
Logitech G5
speed_demon is offline
post #25 of 25 (permalink) Old 02-21-2019, 06:09 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Mixing ethanol or methanol with enough water should bring the flash point to slightly above room temperature
https://engage.aiche.org/HigherLogic...c5132b&ssopc=1
I will probably try to seal the system once I know it works. Otherwise, I'd lose ethanol to evaporation and have to add some regularly. Probably not more dangerous than the hydrogen I deal with on a daily basis (or the booze in my fridge, lol)
CHILLER DESTRUCTION
basic linux pc
(15 items)
Z390 Station
(11 items)
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
