Direct Die 9900K cooling with an AIO - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 05-19-2019, 09:16 PM - Thread Starter
weztmarch's Avatar
Rep: 0
Hello, this is my first post here on overclock.net. I have been browsing this forum for months and learned lots of useful stuff, but I have not found enough concrete info on the Internet for my particular needs and so here I am. I hope that a more knowledgeable individual regarding water cooling can help me out.
I have decided to delid my 9900K because I am very close to thermal limits in Cinebench and stress tests. A Rockit 89 awaits me in the next room. I have also placed an order for the Der8auer Direct Die guard, which is something I am not 100% certain how to go about using. I do not have a custom loop nor the funds to build one at this time, so I will attempt direct die cooling with an AIO. In his YT video about the 9th Gen Delid Die Guard, Der8auer explained that the frame is compatible with Asetek AIO (he specifically says Corsair/NZXT) with minimal difficulties/mods required! However, I have been told that I might need some M3 screws cut to size for this to work. Before I do that I am wondering if someone out there has already successfully done direct die cooling on the 9900K/1151 socket with an AIO without any mods. I own a Corsair H150i Pro and an EVGA CLC 280, both of which are Asetek Gen6 with slightly different blocks. The problem is that I am unsure if any of the standoffs included with the AIO (e.g. LGA 115x, 2066, AM4) will provide enough clamping pressure for the CPU minus IHS. Has anyone had any success direct die cooling with an AIO, and if so, what did you do? Thanks for any input.
Edit: Grammar
weztmarch is offline
post #2 of 8 (permalink) Old 05-19-2019, 09:26 PM
RIP OCN
Rep: 25 (Unique: 19)
If you are just worried about pressure on the die due to the included standoffs, just replace them with plastic washers.
anti-clockwize is offline
post #3 of 8 (permalink) Old 05-20-2019, 08:21 AM - Thread Starter
weztmarch's Avatar
Rep: 0
I am worried that my AIO will not work in stock config. Hoping someone has actually done 9900K direct die with an Asetek AIO to lend some perspective. Do you think I will have everything I need to do it out of the box or will I need to go to the store and buy some m3 screws and cut them down to size?
post #4 of 8 (permalink) Old 05-20-2019, 08:30 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1019 (Unique: 614)
Yes, you need longer M3. You can just buy M3 threaded rod and just cut to the length you need.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #5 of 8 (permalink) Old 05-20-2019, 10:32 AM - Thread Starter
weztmarch's Avatar
Rep: 0
Damn I was worried you were gonna say that. That is a bit beyond my comfort level, but I suppose I will have to learn. Thanks
post #6 of 8 (permalink) Old 05-20-2019, 11:03 AM - Thread Starter
weztmarch's Avatar
Rep: 0
So do I just replace the AIO stand-offs for the backplate with M3 screws? Do the screws go through from front of motherboard to the back, or from back to front (same as included standoffs)?
i9-9900K
EVGA RTX 2080 FTW3
G.SKILL ROYAL 32GB 3200C16
MSI MEG Z390 ACE
CORSAIR H150i PRO
ALIENWARE 3418DW
FRACTAL DEFINE S2
post #7 of 8 (permalink) Old 05-20-2019, 11:08 AM
Martin778's Avatar
Rep: 15 (Unique: 15)
What were your temps? 5.0-5.1 is about the absolute max to keep under Tjmax on the H150i.
Core i9 9900K @ 5.2 || EVGA Z390 DARK || 2x8GB G.Skill TridentZ RGB 4600 C18 @ 4266 C17 || GPU: EVGA Kingpin RTX2080Ti @ 2130MHz || Samsung 970PRO 1TB + 860EVO 2TB || Lian Li O11 Dynamic White || Corsair AX1600i || Screen: LG B8 OLED 55 and LG 34GK950F
Corsair H150i PRO + Noctua NF-A12x25
Martin778 is offline
post #8 of 8 (permalink) Old 05-20-2019, 11:14 AM
Overclocker in training
ThrashZone's Avatar
Rep: 62 (Unique: 48)
Hi,
I'm sure you'd have to remove the mounting plate off the board so the aio will go past that point to make contact with the die.
Direct die mounting plate
Vaper
(4 items)
i9-9940x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Audio
Built in realtek with Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Samsung 970 Evo 500gb M.2 for os/ Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
Tags
9900k , aio , Asetek , der8auer , direct die
