Positive vs negative pressure - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 11-21-2019, 02:15 AM
8051's Avatar
Rep: 25 (Unique: 19)
Quote: Originally Posted by cezzey View Post
No components will be water-cooled so im asking on opinions and advices. The case will be airtight so no dust will get in through any cracks if i decide on negative pressure with passive filtered intake.
Sent from my Mi A1 using Tapatalk
An airtight mass produced computer case is practically a fantasy. There are no seals, no gaskets, loose tolerances and insufficient mating pressure between surfaces to create an airtight environment. Industrial computer enclosures are another matter entirely.
8051 is offline
post #12 of 20 (permalink) Old 11-21-2019, 02:56 AM
Cyberats's Avatar
Rep: 0
My advice, ignore any and all fancy, name brand, fashion fans (especially Noctua) that are "silent", fans have only one function - cooling. Look for [email protected] only, I found a pretty good industrial one I installed as negative pressure, though liquid cooled CPU, to vent off some of the crossfire dual GPU heat primarily. GPUs idle at 30C won't pass 65C on load, CPU idle reports 20C but I think it's erroneous somehow.
Like this one:
https://www.amazon.com/HIGHFINE-4000...4330097&sr=8-1
Cyberats is offline
post #13 of 20 (permalink) Old 11-22-2019, 01:11 AM
8051's Avatar
Like this one:
Loud and proud always works for cooling fans.
8051 is offline
post #14 of 20 (permalink) Old 11-23-2019, 01:54 AM - Thread Starter
Rep: 0
I'll be making a custom case from the scratch, intend to seal it well if i go for negative pressure
cezzey is offline
post #15 of 20 (permalink) Old 11-27-2019, 03:45 AM
8051's Avatar
I'd love to see anyone prove they actually have positive case pressure inside any non-custom-built-industrial PC case. As Doyll has pointed out numerous times before even the most powerful 12V axial fans have very little static pressure -- and static pressure is what you would need to pressurize a case. Even if a case were sealed w/gaskets and the necessary mating pressure to make the gaskets work, I doubt 12V DC axial fans have the necessary static pressure to raise the interior pressure to anything measurable.
8051 is offline
post #16 of 20 (permalink) Old 11-27-2019, 04:31 AM
Hardware Princess
Hydroplane's Avatar
Rep: 31 (Unique: 26)
In theory negative pressure ensures that the air in your case is always at room temp
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #17 of 20 (permalink) Old 11-27-2019, 01:00 PM
TeslaHUN's Avatar
Rep: 20 (Unique: 18)
Here ,positive pressure proof with smoke You can try the same at home , and bonus your room will smell good xd
TeslaHUN is offline
post #18 of 20 (permalink) Old 11-27-2019, 04:22 PM
drewafx's Avatar
Rep: 5 (Unique: 5)
Computer axial fans don't really generate pressure (especially at quiet noise level)
Negative pressure pulls in air at a low speed, so dust settles inside pc a lot faster, but flow is mostly laminar and air spends the least amount of time in the case since it's extracted out like magnet
Positive pressure pulls in air at high speed, but flow inside case is turbulent and can be stagnant (formation of hot spots)
So the best case scenario is balanced in/out for fast air intake flow to reduce dust settlement and exhaust fans that pulls those out of the case asap for better case temperature.
I'd use a centrifugal fan for high positive intake pressure to overcome intake filter resistance and turbulent mixing of fresh/stale air within the case, blower fan for overcoming heatsink/radiators resistance, and axial fan for high exhaust flow
but this is just ideal theory and requires custom power/pwm module as well...
drewafx is online now
post #19 of 20 (permalink) Old 11-29-2019, 01:08 PM
8051's Avatar
https://www.youtube.com/watch?v=a12aDCxrcts
That proves nothing. Air flow is not pressure. You measure pressure w/a barometer or manometer not smoke.
8051 is offline
post #20 of 20 (permalink) Old 12-02-2019, 12:40 PM
StAndrew's Avatar
Rep: 13 (Unique: 9)
You'll have to explain this theory to me...
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
