Set variable equal to a method return in Java - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 06-09-2011, 01:06 PM - Thread Starter
E_man's Avatar
Rep: 386 (Unique: 304)
I'm very new to java, so this may seem very basic. I'm trying to set a variable in my main method equal to a value returned from a method in a separate class. However, Eclipse is giving me an error.
Cannot make static reference to non-static method
The offered quick fix is to make the method that I'm refering to static. I'm not 100% sure what this means.
Main method class
public class StartProject
public static void main(String[] args)
int sum3;
int sum5;
sum3 = Add3.run();
sum5 = Add5.run();
System.out.println(sum3 + sum5);
Add3 class (same as Add5 class, except i=5 instead of 3. I know, inefficient, but I'll fix that later)
public class Add3
int result;
int run()
int i=3;
while(i<1000)
result = result+i;
i=i+3;
return result;
So it's asking me to make run() static. Will this harm anything? Is this good or bad practice? Is there a better way? Like I said, I'm super new to java. I keep starting, and not having the time to continue, so I stop.
Google Chrome Club
Laptop: Asus Transformer w/ Dock
Upgrades to come:, Water cooling 0/7, New IPS setup 3/3, Better Sound Setup 7/8, better PSU 1/1
E_man is offline
post #2 of 18 (permalink) Old 06-09-2011, 01:25 PM
Rep: 30 (Unique: 28)
Java is object oriented. That means that whatever methods you call on have to be from an instance of an object. You can get past that by making a method static. This means that the method will be the same for every instance of that class.
int sum3;
int sum5;
                Add3 addthree = new Add3();
                Add5 addfive = new Add5();
sum3 = addthree.run();
sum5 = addfive.run();
Here, we create instances of the Add3 and Add5 class, then we call those methods through the objects we created.
Jtvd78 is offline
post #3 of 18 (permalink) Old 06-09-2011, 01:36 PM
CovertCover's Avatar
Rep: 89 (Unique: 69)
Originally Posted by E_man;13812308
I'm very new to java, so this may seem very basic. I'm trying to set a variable in my main method equal to a value returned from a method in a separate class. However, Eclipse is giving me an error. The offered quick fix is to make the method that I'm refering to static. I'm not 100% sure what this means.
Main method class
int sum3;
int sum5;
sum3 = Add3.run();
sum5 = Add5.run();
public class Add3
int result;
int run()
int i=3;
while(i<1000)
result = result+i;
i=i+3;
return result;
Simple fix, either make the method a static method. Or insantiate an instance of your class where you're calling your method.
When you make a method or variable static, it means that it can be used without creating an object; meaning you can use that method or variable without having to go through the trouble of creating an entire class. It's a decent space saving technique; and many of the Java core libraries require the use of the 'static' modifier.
For such a simple program, making the method static would be ok, but it is generally perfered that you create the object using something like:
MyObject myObject = new MyObject();
I'm on my phone but that would be the general way to create a new object of type MyObject. Then to call a method from your object, and assign it to a variable you could use:
myVariable = myObject.myMethod();
CovertCover is offline
post #4 of 18 (permalink) Old 06-09-2011, 02:06 PM - Thread Starter
E_man's Avatar
Thanks. Definitely some work getting used to this. All my experience has been in C. Nothing I've done is objects like this. This worked great.
Google Chrome Club
E_man is offline
post #5 of 18 (permalink) Old 06-11-2011, 08:31 PM
Rep: 215 (Unique: 151)
+1
ALUCARDVPR is offline
post #6 of 18 (permalink) Old 06-13-2011, 11:16 AM
Sin Cities Sin's Avatar
Rep: 1 (Unique: 1)
Im learning java as well and ive only seen the run() as a static or instance method for threads in games developed in java. in this case the int run() what does that actually do? Im going to print it lol and see what it gives me, also what are the Addn = new Addn() is this a built in class that will add n to another number? I have never seen this before, if you dont mind can someone please explain this to me.
Sin Cities Sin is offline
post #7 of 18 (permalink) Old 06-13-2011, 03:23 PM
surfbumb's Avatar
Rep: 97 (Unique: 79)
ok, c++ and java are object-oriented, but are slightly different in the syntax in terms of creating an object.
For java...lets say the class name is Dog
Dog scruffy = new Dog();
now you just made a Dog object called scruffy. You can now call all of the methods from the Dog class like this...in main or other classes.
scruffy.weight();
scruffy.breed();
scruffy.gender();
in c++ it is slightly different...but the same concept is applied.
int run(){
this is just a method that returns an integer data type. You must have the keyword "return" followed by an integer or variable that holds an integer inside the method.
surfbumb is offline
post #8 of 18 (permalink) Old 06-13-2011, 03:29 PM
Rep: 1 (Unique: 1)
i know all about oop in java how do you create and destroy an object in c++? now that i think of it how can you manually destroy scruffy? I know you can remove all pointers to scruffy and let the garbage collector pick him up but there must be a manual way is there not?
post #9 of 18 (permalink) Old 06-13-2011, 04:07 PM
surfbumb's Avatar
java has automatic garbage collection...c++ is in the hands of the programmer.
Everytime you use the word "new" you want to have a corresponding delete.
for deallocating memory in conjunction with an object
Dog* scruffy = new Dog;
// use scruffy
delete scruffy;
deallocating memory for a dynamic array...look at where the brackets are...
int* set = new int[100];
//use set[]
delete [] set;
check out destructors and how they are used...and also when to use them...as they are very important with handling the "freeing" of memory.
surfbumb is offline
post #10 of 18 (permalink) Old 06-13-2011, 04:38 PM
Rep: 1 (Unique: 1)
this is very good i plan on learning c++ when i am done with c im trying to do it all at once, Java and C i mean, In C++ just delete scruffy and he is gone. Can you not call the garbage collector on an object in java to remove it like the delete function in C++?
