Need some java help - Overclock.net - An Overclocking Community
Need some java help
post #1 of 6 (permalink) Old 06-14-2011, 09:48 AM - Thread Starter
JCarney's Avatar
Rep: 0
I cannot for the life of me figure out how to put 3 different user inputs into 3 different panels of a primary panel. Any help/guidance is appreciated!
JCarney is offline
post #2 of 6 (permalink) Old 06-14-2011, 10:04 AM
travesty's Avatar
Rep: 144 (Unique: 126)
i think what you need is a structure like this
JPanel parent = new JPanel(new FlowLayout());
JPanel child1 = new JPanel();
JPanel child2 = new JPanel();
JPanel child3 = new JPanel();
JTextField input1 = new JTextField();
JTextField input2 = new JTextField();
JTextField input3 = new JTextField();
child1.add(input1);
child2.add(input2);
child3.add(input3);
parent.add(child1);
parent.add(child2);
parent.add(child3);
travesty is offline
post #3 of 6 (permalink) Old 06-14-2011, 10:17 AM - Thread Starter
JCarney's Avatar
Rep: 0
import java.awt.*;
import javax.swing.*;
public class Triathlon
public static void main (String[] args)
Triathlete one = new Triathlete ("Smith", "Andrea", 3605, 3600);
Triathlete two = new Triathlete();
Triathlete three = new Triathlete();
JFrame frame = new JFrame ("FiveK Run Display");
frame.setDefaultCloseOperation (JFrame.EXIT_ON_CLOSE);
JPanel subPanel1 = new JPanel();
subPanel1.setPreferredSize (new Dimension(300, 200));
subPanel1.setBackground(Color.green);
JLabel label1 = new JLabel();
subPanel1.add(label1);
JPanel subPanel2 = new JPanel();
subPanel2.setPreferredSize (new Dimension(300,200));
subPanel2.setBackground(Color.blue);
JLabel label2 = new JLabel();
subPanel1.add(label2);
JPanel subPanel3 = new JPanel();
subPanel3.setPreferredSize (new Dimension(300,200));
subPanel3.setBackground(Color.red);
JLabel label3 = new JLabel ();
subPanel1.add (label3);
JPanel primary = new JPanel();
primary.setBackground(Color.yellow);
primary.add (subPanel1);
primary.add (subPanel2);
primary.add (subPanel3);
frame.getContentPane().add(primary);
frame.pack();
frame.setVisible(true);
import java.text.DecimalFormat;
import java.util.Scanner;
public class Triathlete
private String last;
private String first;
private int seconds;
private int personalRecord;
private double kph;
DecimalFormat dfmt = new DecimalFormat("0.##");
Scanner scan = new Scanner(System.in);
public Triathlete()
public Triathlete (String last, String first, int seconds, int personalRecord)
this.last = last;
this.first = first;
this.seconds = seconds;
this.personalRecord = personalRecord;
kph = 25.75 / (seconds / 3600d);
public String getLast()
return last;
public String getFirst()
return first;
public int getSeconds()
return seconds;
public int getPersonalRecord()
return personalRecord;
public double getKph()
return kph;
public void setLast(String last)
this.last = last;
public void setFirst(String first)
this.first = first;
public void setSeconds(int seconds)
public void setPersonalRecord(int personalRecord)
public void setKph(double kph)
this.kph = kph;
public String toString()
if (seconds == 0){
System.out.println("Enter last name: " );
String last = scan.next();
System.out.println("Enter first name: ");
String first = scan.next();
System.out.println("Enter seconds: ");
seconds = scan.nextInt();
System.out.println("Enter personal record: ");
personalRecord = scan.nextInt();
return "Name: " + last + ", " + first + "\nTime in seconds: " + seconds + "\nPR Time in seconds: "
+ personalRecord + "\nAverage KM per hour: " + dfmt.format(25.75 / (seconds / 3600d))
+ "\nAverage miles per hour: " + dfmt.format((25.75 / (seconds / 3600d)) * 0.621371192);
+ personalRecord + "\nAverage KM per hour: " + dfmt.format(kph) + "\nAverage miles per hour: "
I have to get three objects from Triathlete into separate panels. I have the panels set up and as you can see my one object has specific parameters while the others accept input. How can I get each object into it's own subpanel?
JCarney is offline
post #4 of 6 (permalink) Old 06-14-2011, 10:49 AM - Thread Starter
JCarney's Avatar
Rep: 0
I could seriously use some help!
JCarney is offline
post #5 of 6 (permalink) Old 06-14-2011, 11:13 AM
travesty's Avatar
to gather input for the other 2 triathletes you can put text fields in the subpanels. then get the info from the text fields and pass it onto the constructor for triathlete.
on submit button click:
Triathlete one = new Triathlete (textfield1.getText(), textfield2.getText(), ...);
travesty is offline
post #6 of 6 (permalink) Old 06-14-2011, 03:39 PM
Why don't you just come out and say you want someone to do it? He gave you more than enough information to go off of. Also, if you want anyone to bother looking at your code, consider placing
 and
tags around it.
iPoop is offline
