Does python have networking? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 09-05-2015, 08:54 PM - Thread Starter
Higgins909's Avatar
Rep: 1 (Unique: 1)
I'm trying to learn python from learnpythonthehardway.org and I'm about half way through.
I've looked at the index or whatever its called (don't know book terms) and it never mentions anything about networking. Only at the end does it say something like move onto ruby..
Does python have networking... Like I could make a game and have people connect over lan/wan?
Does ruby?
Thanks,
Higgins909
Higgins909 is offline
post #2 of 7 (permalink) Old 09-05-2015, 09:04 PM
Retired Staff
Rep: 4426 (Unique: 2045)
Sure... python has network libraries/modules natively....
http://www.tutorialspoint.com/python/python_networking.htm
Just learning to networked gaming is quite a big jump....
To answer most of your questions: (1) a fridge cannot cool a PC (2) 64-bit OS for over 3.4GB (3) If a PCIe card fits, it should work (4) Resolution, not screen size (5) Report, not respond to Spam (6) Single-Rail/Non-Modular PSUs are not always better than Multi-Rail/Modular (7) Sequential does not matter as much as random for OS drives (8) Requirements come before hardware for servers
DuckieHo is offline
post #3 of 7 (permalink) Old 09-10-2015, 06:32 PM - Thread Starter
Higgins909's Avatar
Rep: 1 (Unique: 1)
... rather confused with the word native attached to libraries. Does that mean I've got to learn another language? as that answer mentions c/c++ and normal dll and libs.
This is a example I was able to find that at least made some sense, but confused me on other parts.
This was in a java area.
"Native Library" generally means a non-Java library that's used by the system (so C/C++, etc). Think normal DLLs or libs.
What about graphics? Would it be called a gui in this case? I know linux has cli and gui versions... in a game is it called a gui still?
post #4 of 7 (permalink) Old 09-10-2015, 06:58 PM
aldfig0's Avatar
Rep: 69 (Unique: 66)
It means that by virtue of installing Python you've already got the standard library included. All you have to do is type "import socket" in your .py file and you can use everything in the socket module by typing socket. and the function name and arguments after the dot.
If you're clicking at things in your game instead of just typing in commands then your game uses a graphical user interface. If you want to do this note that Python has Tkinter built in its standard library which will easily allow you do create a GUI. You can also use third-party ones like PyQt, wxPython, or PyGame (which should have game-specific features but I've never used it so I can't be too sure).
aldfig0 is offline
post #5 of 7 (permalink) Old 09-15-2015, 11:26 AM
Mrzev's Avatar
Rep: 96 (Unique: 76)
Whenever i need to listen to a port for data and do something with it, I tend to go with python because it's pretty quick and easy. This script listens to port 5555 and writes the data into an SQL db.
#!/usr/bin/python
import socket
import sys
import json
import mysql.connector
from datetime import datetime
# Create a TCP/IP socket
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
# Bind the socket to the port
server_address = ('', 5555)
print >>sys.stderr, 'starting up on %s port %s' % server_address
sock.bind(server_address)
# Listen for incoming connections
sock.listen(1)
print >>sys.stderr, 'Started - Listening'
while True:
        # Wait for a connection
        message = ""
        connection, client_address = sock.accept()
        try:
                print >>sys.stderr, 'connection from', client_address
                while True:
                        #Loops trough 1KB at a time until it received all the data.
                        data = connection.recv(1024)
                        message += data
                        if not data:
                                print message
                                print " "
                                jdata = json.loads(message)
                                cnx = mysql.connector.connect(user='', password='',
        host='127.0.0.1',
        database='test')
                                cursor = cnx.cursor()
                                type= jdata["MovementForward"][0]["Device"]["type"]
                                name = jdata["MovementForward"][0]["Device"]["name"]
                                x= jdata["MovementForward"][0]["Device"]["movements"][0]["Movement"]["points"][3]["PointLoc"]["x"]
                                y= jdata["MovementForward"][0]["Device"]["movements"][0]["Movement"]["points"][3]["PointLoc"]["y"]
                                date_object = datetime.strptime(jdata["MovementForward"][0]["Device"]["movements"][0]["Movement"]["date"], '%Y-%m-%dT%H:%M:%S+0000')
                                cursor.execute("INSERT INTO locations (type,name,x,y,dateReceived) VALUES (%s, %s, %s, %s, %s)",(type, name,x,y,date_object))
                                cnx.close()
                                break
        finally:
                connection.close()
Mrzev is offline
post #6 of 7 (permalink) Old 12-09-2018, 11:03 PM
Rep: 0
Python Networking
Python Networking Programs..
http://net-informations.com/python/iq/default.htm
markgeven is offline
post #7 of 7 (permalink) Old 12-11-2018, 01:47 PM
PhotonFanatic's Avatar
Rep: 18 (Unique: 17)
A bit off topic, but it looks like learnpythonthehardway.org is just a site that sells a book. Am I missing anything here?
"Executing execution.exe"
Bang for the buck
(12 items)
3570k @ 4.6Ghz @1.35v
Gigabyte Z77x UD3H
evga GTX 970 SSC
16Gb Gskill Ripjaws 2133Mhz @ 9-11-10-28
Samsung Evo 850
Silverstone 900 watt
Thermalright Ultra 120 Extreme
Silverstone Raven (1st edition)
Operating System
Windows 10 Spy Delux
Xstar 27" PLS 1440p
Keyboard
Wireless ergonomic
Mouse
Logisys Wireless trackball
PhotonFanatic is offline
