Regex Pattern Help for Logs - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 07-06-2016, 03:57 PM - Thread Starter
Buster's Avatar
Rep: 4 (Unique: 4)
Hi,
I am trying to create a regex pattern to capture the different fields from logs.
Sample log entries:
2016-07-06 19:09:15,408 UTC WARN [] () [de.hybris.platform.acceleratorcms.context.ContextInformationLoader] Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!
2016-07-06 19:09:15,408 UTC WARN [[33.33.333.333] ] () [de.hybris.platform.acceleratorcms.context.ContextInformationLoader] Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!
2016-07-06 19:09:15,408 UTC WARN [[33.33.333.333] [33.33.333.333] ] () [de.hybris.platform.acceleratorcms.context.ContextInformationLoader] Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!
2016-07-06 19:09:15,408 UTC WARN [[33.33.333.333] [33.33.333.333] [33.33.333.333] or more ] () [de.hybris.platform.acceleratorcms.context.ContextInformationLoader] Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!
I have gotten this far: http://rubular.com/r/RWhUNnRjQj.
I need to capture all the IPs only within the [], the java class only, de.hybris.platform.acceleratorcms.context.ContextInformationLoader, within the [], and the rest of the message only, Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!.
The capture should be something like so:
1. 2016-07-06 19:09:15,408 UTC
2. WARN
3. 33.33.333.333
4. 33.33.333.333
5. de.hybris.platform.acceleratorcms.context.ContextInformationLoader
6. Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!
Please help. Thanks.
Buster is offline
post #2 of 3 (permalink) Old 07-06-2016, 04:30 PM
mykah89's Avatar
Rep: 39 (Unique: 28)
^(.*\d UTC) (.*?) \[(.*)\].*?\(\) \[(.*?)\] (.*?!)$
global and multiline flags
Gets you most of the way there i think, you will probably need to do further processing on the ip string as a match group regardless.
https://regex101.com/
mykah89 is offline
post #3 of 3 (permalink) Old 07-19-2016, 04:02 AM
stolemyowncar's Avatar
Rep: 20 (Unique: 17)
Well this is kind of late, but one thing to remember is that you always have split available as well. You don't just have to do straight regex and capture groups, as inclined as I usually am towards that solution. Depending on the setup of the data, just keep in mind that regex isn't always the answer. Sometimes it's like hitting a small nail with a sledgehammer.
ie, in Javascript:
var str='2016-07-06 19:09:15,408 UTC WARN [[33.33.333.333] [33.33.333.333] ] () [de.hybris.platform.acceleratorcms.context.ContextInformationLoader] Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!';
var arr=str.split(/[\[\]]\s*/).filter(function(v)
    return v!==''&&!v.match(/\(\)\s*/)
console.log(arr);
Will give you
["2016-07-06 19:09:15,408 UTC WARN ", "33.33.333.333", "33.33.333.333", "de.hybris.platform.acceleratorcms.context.ContextInformationLoader", "Cannot find CMSSite associated with current URL (http://example.somewhere.local/favicon.ico)!"]
Unfortunately the indices of the matches will be ambiguous thanks to the ip addresses, but they would be in most regex solutions as well. You would have to use something like perl grammar for more clarity:
http://search.cpan.org/~dconway/Regexp-Grammars-1.045/lib/Regexp/Grammars.pm
But honestly this is more trouble than it is worth. It would be easier to just do postprocessing on the array to prune out the ip addresses.
stolemyowncar is offline
