Need Java Assignment help Asap - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 11-30-2016, 05:56 PM - Thread Starter
Zalas's Avatar
Rep: 0
Your mission should you choose to accept it.
Write a Java program that allows the teacher to calculate the grade for a student. The teacher will first enter the
Student ID number, first name, and last name. This will be followed by entering in the score for each of the following
categories: Assignments, Quizzes, Midterm Exam, & Final Exam
The weights for each category are as follows:
Assignments - 50%
Quizzes – 20%
Midterm – 10%
Final – 20%
Once you have the scores for each individual category, calculate a total score for the course. Then assign a letter grade
to the student based on the following grade scale:
90 – 100 = A
80 – 90 = B
70 – 80 = C
60 – 70 = D
< 60 = E
Print the results in exactly the following format:
[Last Name], [First Name]
Student ID: [Student ID]
Homework: [Homework Score]
Quizzes: [Quizzes Score]
Midterm: [Midterm Score]
Final: [Final Score]
Total Score: [Total Score] Grade: [Letter Grade]
Then ask the user if they would like to enter another student or quit. Continue the process until the user chooses to
quit.
This is what I have so far
import java.util.*;
public class StudentGrades {
public static void main (String[] args) {
Scanner console = new Scanner (System.in);
String sSID = "";
String sInputF = "";
String sInputL = "";
String sGrade = "";
double dWeightAssign = 50;
double dWeightQuiz = 20;
double dWeightMidE = 10;
double dWeightFinalE = 20;
double dStudentAssign = 0;
double dStudentQuiz = 0;
double dStudentMidE = 0;
double dStudentFinalE = 0;
double dTotalAssign = 0;
double dTotalQuiz = 0;
double dTotalMidE = 0;
double dTotalFinalE = 0;
double dTotalScore = 0;
//Preform calculation
dTotalAssign = dWeightAssign * dStudentAssign;
dTotalQuiz = dWeightQuiz * dStudentQuiz;
dTotalMidE = dWeightMidE * dStudentMidE;
dTotalFinalE = dWeightFinalE * dStudentFinalE;
dTotalScore = (dWeightAssign * dStudentAssign) + (dWeightQuiz * dStudentQuiz) +
(dWeightMidE * dStudentMidE) + (dWeightFinalE * dStudentFinalE);
//Get user input
System.out.println("Please enter student's ID Number.");
sSID = console.nextLine();
System.out.println("Please enter student's First Name.");
sInputF = console.nextLine();
System.out.println("Please enter student's Last Name.");
sInputL = console.nextLine();
System.out.println("Please enter student's score for Assignments");
dStudentAssign = console.nextDouble ();
System.out.println("Please enter student's score for Quizes");
dStudentQuiz = console.nextDouble ();
System.out.println("Please enter student's score for Midterm Exam");
dStudentMidE = console.nextDouble ();
System.out.println("Please enter student's score for Final Exam");
dStudentFinalE = console.nextDouble ();
if (dTotalScore >= 90) {
sGrade = "A";
else if (dTotalScore >= 80) {
sGrade = "B";
else if (dTotalScore >= 70) {
sGrade = "C";
else if (dTotalScore >= 60) {
sGrade = "D";
else {
sGrade = "F";
System.out.println(sGrade);
I have also tried the following for the letter grade
System.out.println("A");
System.out.println("B");
System.out.println("C");
System.out.println("D");
else
System.out.println("F");
Neither way has worked
Zalas is offline
post #2 of 2 (permalink) Old 12-01-2016, 09:51 PM
Retired Staff
XAslanX's Avatar
Rep: 292 (Unique: 219)
Try this:
 * The mark calculation class.
 * @author Numbers
import java.io.*;
public class MarkCalc {
    static String studentId;
    static String firstName;
    static String lastName;
    static double assignments;
    static double quizzes;
    static double midterm;
    static double finals;
    static int repeat = 1;
    static double finalPercent;
    private static double weightedAve(int weight, double mark) {
        return (weight * mark / 100);
    private static String finalGrade(double assignments, double quizzes, double midterm, double finals) {
        if (finalPercent >= 90) {
            return "A";
        } else if (finalPercent >= 80 && finalPercent <= 89) {
            return "B";
        } else if (finalPercent >= 70 && finalPercent <= 79) {
            return "C";
        } else if (finalPercent >= 60 && finalPercent <= 69) {
            return "D";
        } else {
            return "E";
    private static boolean newStudent(int repeat) {
        return (repeat == 1);
    public static void main(String[] args) throws IOException {
        BufferedReader input = new BufferedReader (new InputStreamReader(System.in)); // Initializes the reader to allow for user input.
        while (newStudent (repeat))
            System.out.print("Please enter the student number: ");
            studentId = input.readLine ();
            System.out.println();
            System.out.print("Please enter the student's last name: ");
            lastName = input.readLine ();
            System.out.print("Please enter the student's first name: ");
            firstName = input.readLine ();
            System.out.print("Please enter the overall mark for assignments: ");
            assignments = Double.parseDouble (input.readLine ());
            System.out.print("Please enter the overall mark for quizzes: ");
            quizzes = Double.parseDouble (input.readLine ());
            System.out.print("Please enter the overall mark for midterm: ");
            midterm = Double.parseDouble (input.readLine ());
            System.out.print("Please enter the overall mark for finals: ");
            finals = Double.parseDouble (input.readLine ());
            assignments = weightedAve(50, assignments);
            quizzes = weightedAve(20, quizzes);
            midterm = weightedAve(10, midterm);
            finals = weightedAve(20, finals);
            finalPercent = (assignments + quizzes + midterm + finals);
            System.out.println(lastName + ", " + firstName);
            System.out.println("Student ID: " + studentId);
            System.out.println("Homework: " + assignments);
            System.out.println("Quizzes: " + quizzes);
            System.out.println("Midterm: " + midterm);
            System.out.println("Final: " + finals);
            System.out.println("Total Score: " + finalPercent + "% Grade: " + finalGrade (assignments, quizzes, midterm, finals));
            System.out.print("Enter 1 for new student. Enter any other value to exit: ");
            repeat = Integer.parseInt(input.readLine ());
            newStudent (repeat);
    } // main method
I don't reply to trolls.
RIP SyrillianWarning: Spoiler! (Click to show)
Woohoo!
Well done you zombie stompin', Best Buy dissin' Lion Man!
XAslanX is offline
