How to optimize this SQL query - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 11-28-2018, 09:42 AM - Thread Starter
Mrzev's Avatar
Rep: 96 (Unique: 76)
I have this query where it basically looks for all the items in my table that has metadata and list all the unique combinations and how many times they appear. I ran this on a database that had 50,000 items, with 280,000 metadata values with 1756 unique combinations. It took 11 seconds. How can i optimize this? How can i write an index for this? The where clause will also change where i may want to list the results of items in the year 2018. I hate optimizing things....
This is the C# code\query i wrote.
            var qq = from a in db.Assets
                     where a.Metadatas.Count() > 0
                     join b in db.Metadatas on a.Id equals b.AssetId
                     group b by new { b.MetadataLookupField, b.MetadataLookupValue } into g
                     orderby g.Key.MetadataLookupField, g.Key.MetadataLookupValue
                     select new
                         key = g.Key,
                         value = g.Count()
Mrzev is offline
post #2 of 4 (permalink) Old 12-03-2018, 04:47 AM - Thread Starter
Mrzev's Avatar
I gave up and went back to Azure Search. =( I had no idea how long it would take me to replace the functionality and how well it would scale, so i had to give up.
Mrzev is offline
post #3 of 4 (permalink) Old 12-03-2018, 05:04 AM
Manual breath enabled
Streetdragon's Avatar
Rep: 26 (Unique: 22)
this is SQL? ok new form for me.
where is the select, or do you need all data?
headdata = db.Assets or so
metadata = main table i think nothing new for you
Select count(headdata.id) AS counter,headdata.id,metadata.a,metadata.b
FROM metadatta
left outer join headdata on headdata.id = metadata.id
group by headdata.id,metadata.a,metadata.b
edit: where metadatta.year = 2018
and if you need: and headdata.id is not null
something like that
Gameingcube
(18 items)
Ryzen 3900X
Aorus X570 Master
1080 TI Founders Edition
F4-3600C16Q-32GTZR
2000GB Seagate Barracuda Compute ST2000DM008 256MB
samsung m2 970 evo
Leadex 80 Plus Platinum Netzteil, schwarz - 1200 Watt
heatkiller IV pro
EK-FC1080 GTX Ti - Nickel
Alphacool Eisbecher D5 250mm Plexi
Alphacool NexXxoS XT45 Full Copper 480mm
XSPC Multiport Radiator EX240
Scythe Grand Flex 4Pin PWM
thermaltake core x9
Operating System
Windows 10
Streetdragon is offline
post #4 of 4 (permalink) Old 12-04-2018, 02:38 PM - Thread Starter
Mrzev's Avatar
No, its C# code using entity framework that is querying a SQL db. There are a few ways to query it, and this style is very close to SQL. ( i would also need to lookup how to do a join using the other style)
Here is a couple examples from the other style I tend to use more.
  var userPermissions = db.ApplicationUserSourcePermissions.Where(a => a.ApplicationUserId == new Guid(User.Identity.GetUserId()));
            if (!userPermissions.Where(a => a.SourceId == myAsset.SourceId).Any())  // If User does not have permission
                return null;
                    var grouped = data
                    .GroupBy(u => u.Item1)
                    .Select(grp => grp.ToList())
                    .ToList();
                    //construct filter
                    foreach (var itemGroup in grouped)
Mrzev is offline
