mega basic c++ problem help mee lol - Overclock.net - An Overclocking Community
post #1 of 53 (permalink) Old 03-19-2009, 01:59 PM - Thread Starter
smokey888's Avatar
Rep: 3 (Unique: 3)
can anyone tel me whats wrong with what i just did i followed it out of a e book? i dont know anything about programming so ye.
an interactive program that computes
the area of a rectangle
#include <iostream>
using namespace std;
int main()
int length; // this declares a variable
int width; // this declares another variable
cout <<*Enter the length: ";
cin >> length; // input the length
cout << *Enter the width: ";
cin >> width; //input the width
cout << *The area is ";
cout << length * width; // display the area
return 0;
smokey888 is offline
post #2 of 53 (permalink) Old 03-19-2009, 02:08 PM - Thread Starter
smokey888's Avatar
Rep: 3 (Unique: 3)
anyone?
post #3 of 53 (permalink) Old 03-19-2009, 02:10 PM
[KOD[Redfox's Avatar
Rep: 9 (Unique: 9)
Hi,
I think it might be because youi ahve used a * after the cout command.
You have written cout <<* Enter the width: ";
It should be cout << "Enter the width: ";
Hope this helps,
Matt
[KOD[Redfox is offline
post #4 of 53 (permalink) Old 03-19-2009, 02:11 PM - Thread Starter
smokey888's Avatar
Rep: 3 (Unique: 3)
okies ill try tht lol thankss
post #5 of 53 (permalink) Old 03-19-2009, 02:12 PM - Thread Starter
smokey888's Avatar
Rep: 3 (Unique: 3)
#include <iostream>
int main()
cout << "Enter the length: ";
cin >> "length; // input the length
cout << "The area is ";
return 0;
That better? when i debug it ways there are build errors?
post #6 of 53 (permalink) Old 03-19-2009, 02:15 PM
Rep: 206 (Unique: 178)
I just started C++ too, I'll have a look at that.
Edit:
#include <iostream>
int main()
cin >> length ;
system ("pause");
return 0;
This compiles and works, found a mistake where I bolded, and something was messed up in your commenting, worked after I deleted the comments.
system ("pause"); is just so the window did not just close on me right when I entered the last value.
Would be nice to add some units too...
Proud owner of a GPH GP2x Wiz and OpenPandora
"Fast, cheap, and good -- pick any two."
Darkknight512 is offline
post #7 of 53 (permalink) Old 03-19-2009, 02:16 PM
66gto's Avatar
Rep: 5 (Unique: 5)
The comment at the beginning....the "/*" at the end should be reversed to "*/"
/*comment*/
like that ^
You might want to get a new eBook if it has errors like that. Unless you copied wrong
66gto is offline
post #8 of 53 (permalink) Old 03-19-2009, 02:16 PM - Thread Starter
smokey888's Avatar
Rep: 3 (Unique: 3)
nice one if u figure it u get a +rep
and u have 666 posts dude
post #9 of 53 (permalink) Old 03-19-2009, 02:18 PM - Thread Starter
smokey888's Avatar
Rep: 3 (Unique: 3)
hmm that changed somthing... now the debug now says
1>.\\area.cpp(6) : warning C4627: '#include <iostream>': skipped when looking for precompiled header use
1> Add directive to 'stdafx.h' or rebuild precompiled header
1>.\\area.cpp(25) : fatal error C1010: unexpected end of file while looking for precompiled header. Did you forget to add '#include "stdafx.h"' to your source?
post #10 of 53 (permalink) Old 03-19-2009, 02:20 PM
66gto's Avatar
Rep: 5 (Unique: 5)
remove the " before cin >> length.
66gto is offline
