Help modifying program.. - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 12-13-2009, 11:54 AM - Thread Starter
Hey guys, I need help modifying this Java program. I need to modify it to allow the user to enter the number of tests and amount of students. Must be restricted to 1 and 20 inclusive for the amount of students, and for the amount of Tests, 3 and 7 inclusive.
This is my code:
import java.util.*;
public class Grades {
public static void main(String[] args) {
Scanner Input = new Scanner(System.in);
double average, grade = 0;
String Continue;
int total = 0, count = 0;
String[] Names = new String[20];
double[][] Grades = new double[20][3];
double[] Average = new double[20];
char[] Letter = new char[20];
for(int x = 0; x < Names.length; x++){{
System.out.print("Enter the Students Name: ");
Names[x] = Input.nextLine();
for(int y = 0; y < 3; y++){
System.out.print("Enter the Grade Value for Test" + (y + 1) + ": ");
Grades[x][y] = Input.nextDouble();
count++;
total += Grades[x][y];
Average[x] = (total/3);
if (Average[x] >= 89.5)
Letter[x] = 'A';
else if (Average[x] >= 79.5)
Letter[x] = 'B';
else if (Average[x] >= 69.5)
Letter[x] = 'C';
else if (Average[x] >= 59.5)
Letter[x] = 'D';
else
Letter[x] = 'F';
count = 0;
total = 0;
Input.nextLine();
System.out.print("Would you like to continue? (Y/N)");
Continue = Input.nextLine();
if((Continue.charAt(0) == 'N')||( Continue.charAt(0) == 'n'))
break;
System.out.println();
System.out.println(" Name Test 1 Test 2 Test 3 Average Letter");
if(Names[x] != null){
System.out.print(Names[x] + " ");
System.out.print(Average[x] + " ");
System.out.print(Letter[x]);
Help will be rewarded with rep.
[Teh Root] is offline
post #2 of 2 (permalink) Old 12-13-2009, 06:34 PM
usmcz's Avatar
Rep: 54 (Unique: 47)
I'm not sure if I completely understand (and I'm rusty with java) but here goes...
Here is where you are setting the number of students or "names" at 20. (0-19 actually, i think).
You could do:
System.out.println("Enter the total number of students: ");
int numStudents = Input.nextInt();
before you create the array Names, and then change the creation of the array to:
String[] Names = new String[numStudents];
Just make sure you initialize your scanner before you call it, and that you set the variable before.
replace the 3 with a variable that you earlier set with the amount of tests:
System.out.println("Enter the total number of tests: ");
int numTest = Input.nextInt();
then Average[x] = (total/numtest);
I think that is right -- but I may have completely missed the point.. if so just let me know and I can try to help again
usmcz is offline
