Java Programming Help - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 11-04-2010, 03:46 PM - Thread Starter
BGP is my favorite
-Inferno's Avatar
Rep: 83 (Unique: 78)
I have a problem figuring out this question
Write an application that estimated the value of the mathematical constant e by using the following formula. Allow the user to enter the number of terms to calculate.
e = 1 + (1/1!) + (1/2!) + (1/3!) + ...
I figured out how to get just the factorial part, but I cannot figure out how to do this part.
This is the code I have for just the factorial part
import java.util.Scanner;
public class factorial {
public static void main(String[] args) {
Scanner input = new Scanner(System.in);
int n;
int result = 1;
System.out.print("Enter Number: ");
n = input.nextInt();
while ( n >= 1){
result = result * n;
n--;
System.out.printf("Answer is: %d", result );
I believe I have to use a while loop, so if anyone can help me I would greatly appreciate it.
-Inferno is offline
post #2 of 4 (permalink) Old 11-04-2010, 04:38 PM
nevets1219's Avatar
Rep: 13 (Unique: 12)
I would keep a variable that keeps track of the factorial instead of re-calculating it each time around.
Without just giving you the answer the process would look something like:
  // keep track of the current factorial
  // keep track of the current sum
  // let n be the user input
  // for n times do:
  //   0 is a special cases - handle it
  //   if >= 1 then do
  //     add 1/factorial to the sum AND
  //     find new factorial
A couple of things to be aware of:
- numeric type
- 0 is a special case because of 0! = 1
nevets1219 is offline
post #3 of 4 (permalink) Old 11-04-2010, 06:46 PM - Thread Starter
BGP is my favorite
-Inferno's Avatar
public class proj3 {
double fact = 1;
double sum = 0;
int n;
System.out.print("Enter # of Terms: ");
while ( n >= 1){
fact = fact * n;
sum = (1/fact) + sum;
n--;
System.out.printf("Sum: %f", sum);
I got that and my output was:
Enter # of Terms: 5
Sum: 0.283333
Not sure if I did it right..
-Inferno is offline
post #4 of 4 (permalink) Old 11-05-2010, 10:52 AM
nevets1219's Avatar
You should be able to add those numbers up and determine if that's right or not. You can tell that your answer is not right from the equation.
Something you may want to verify is that valid input should be greater than 0. An input of zero should return 1.
As your inputs gets larger you should be approaching "2.71828". Look at the wiki for more information about "e".
This is what I got, hopefully it's correct:
0 => 1.0
1 => 2.0
2 => 2.5
3 => 2.6666666666666665
4 => 2.6904761904761902
5 => 2.6910299003322256
