Heat from CPU (W) - Page 2 - Overclock.net - An Overclocking Community
Heat from CPU (W)
post #11 of 18 (permalink) Old 01-14-2007, 11:16 AM
Fishie36's Avatar
Rep: 751 (Unique: 473)
Hmm... so supposedly my CPU is drawing/pumping out 157 watts of heat. I'm surprised my little Arctic freezer 64 can keep it at 48C.
Fishie36 is offline
post #12 of 18 (permalink) Old 01-14-2007, 09:01 PM - Thread Starter
jrs
Rep: 40 (Unique: 33)
Unfortunately that number is much higher than what it is really going to put out. AMD's TDP of 89w represents a value that is way over the top, and is a power consumption level that will never be reached at stock. I'll pm burn and see what he used when he calculated his, because his number came out to be around 100w......which means he used something lower and more realistic.
~jrs
via aqua 1300, bonnie heatercore, and Apogee
jrs is offline
post #13 of 18 (permalink) Old 01-14-2007, 09:05 PM
Retired Staff
Mootsfox's Avatar
Rep: 693 (Unique: 434)
Mine is about 4 watts less overclocked than stock!
Certs:
A+
ACMT
Dell ASP; Desktop, Laptop, PowerConnect, PowerEdge, PowerVault
Mootsfox is offline
post #14 of 18 (permalink) Old 01-14-2007, 09:07 PM
pauldovi's Avatar
Rep: 923 (Unique: 529)
This should give you an idea of CPU heat production:
From this thread. The results come from a test I was doing on flow rate vs. heat transfer. The Vcore was at 1.55V, which was intentional to produce more heat. Actual CPU Vcores will be lower, and thus heat production as well.
pauldovi is offline
post #15 of 18 (permalink) Old 01-14-2007, 09:08 PM - Thread Starter
jrs
Haha....I assume because you have your vcore set below 1.4v?
jrs is offline
post #16 of 18 (permalink) Old 01-14-2007, 09:09 PM
Fishie36's Avatar
What if you have air cooling?
Fishie36 is offline
post #17 of 18 (permalink) Old 01-14-2007, 09:10 PM
pauldovi's Avatar
Clearly it doesn't do a good job of showing performance with air blocks. But it should show you how much heat the CPU is making.
pauldovi is offline
post #18 of 18 (permalink) Old 01-14-2007, 09:10 PM
Retired Staff
Mootsfox's Avatar
Yup! 220mhz increase, .1v decrease.
Certs:
A+
ACMT
Mootsfox is offline
