Heat from CPU (W) - Overclock.net - An Overclocking Community
Heat from CPU (W)
post #1 of 18 (permalink) Old 10-24-2006, 07:14 PM - Thread Starter
jrs
Rep: 40 (Unique: 33)
I wrote a simple C++ program to find out how many watts of power an overclocked cpu produces.
It is based on this formula
OC Wattage = TDP * ( OC MHz / Stock MHz) * ( OC Vcore / Stock Vcore )^2
The text "^2" means "squared".
This formula is fairly self-evident. The stock/OC MHz is just how fast the processor is meant to run, and how fast you are in fact running it. Same with the vcore, which to any new people is the voltage that is run through the processor. Higher voltage means more stability, but also can lead to much higher power consumption, and if excessive, and early demise.
The only term that needs explanation is the TDP, or Thermal Design Power. The TDP is meant to be the wattage of the processor at load. I say "wattage" because it is unclear if this is meant to corrospond most immediately to how much power is consumed in watts, or how much heat is produced in watts, but as near as I can tell the TDP is pretty much meant to indicate both.
To get your processor's TDP, you must depend on AMD or Intel's own figures. In the case of AMD's XP line both maximum and typical are listed, and typical is what you want. Maximum is apparently if every single transistor were powered at the same time, which will never happen. Typical is meant to be the realistic maximum wattage.
source
here is the program and source code if anyone wants to see it. Its an easy program, but my math is kind of wierd at some points in the program so feel free to make suggestions. Attachment 33782
via aqua 1300, bonnie heatercore, and Apogee
jrs is offline
post #2 of 18 (permalink) Old 10-24-2006, 07:26 PM
sweet
ThaWaxShop is offline
post #3 of 18 (permalink) Old 11-03-2006, 06:10 PM
Retired Staff
Burn's Avatar
Rep: 520 (Unique: 309)
...Java...
Mine comes out to 102.44W- Does that sound right?
My CNC Mill Project
Originally Posted by CyberDruid
Burn + Electricty + Water =
But the man has the patience of a saint...
We cannot change the cards we are dealt, just how we play the hand.
--Randy Pausch
Current Best Benchmark
Burn is offline
post #4 of 18 (permalink) Old 11-03-2006, 06:15 PM
Retired Staff
Rep: 1192 (Unique: 550)
Hey Buddy, Thanks I just down loaded and tried it...Very Nice.......
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #5 of 18 (permalink) Old 11-03-2006, 06:46 PM - Thread Starter
jrs
Originally Posted by Burn View Post
...Java...
depends it should be right but you could do it out by hand to make sure it works
I know I checked the prgram using sdumpers numbers for his conroe and it worked so.
Edit: whats your overclock and vcore?
jrs is offline
post #6 of 18 (permalink) Old 11-03-2006, 06:49 PM
Retired Staff
Burn's Avatar
I did it through my calculator- The equation seems right, I cross-checked it on another site's CPU wattage calculator, same spec.
My CNC Mill Project
--Randy Pausch
Burn is offline
post #7 of 18 (permalink) Old 11-03-2006, 06:49 PM - Thread Starter
jrs
ok good some of the math is a bit messed up as I said. It comes out with the right answer just some of the steps to get to it are odd.
jrs is offline
post #8 of 18 (permalink) Old 11-03-2006, 06:54 PM
Retired Staff
Burn's Avatar
I screwed the math up the first time- I accidentally switched around speeds (stock speed/overclocked).
My CNC Mill Project
--Randy Pausch
Burn is offline
post #9 of 18 (permalink) Old 01-13-2007, 10:20 PM
pauldovi's Avatar
Rep: 923 (Unique: 529)
Nice program however it is not very accurate. The problem is, the voltage you set in BIOS never reaches your CPU. This is caused by Vdroop. Also, your formula will not produce an accurate value because:
A. The TPD is not the amount of heat that a C2D puts out, however, it is the amount of heat the cooler is expected to dispell. The C2D may really put out 40 watts or even less.
B. The processors Mhz has no correlation to heat output, as far as I am aware.
Now if you could measure the Amps and voltage going to the CPU, you could calculate CPU wattage.
pauldovi is offline
post #10 of 18 (permalink) Old 01-13-2007, 10:46 PM - Thread Starter
jrs
The program may not be extremely accurate, but it isn't bad for approximations.
A. TDP represents the maximum amount of heat the cooling solution is expected to dissipate(as you said). The figure is high by default from the manufacture because the processor will never reach that heat level? So I guess the program doesn't calculate the total amount of heat, but maybe just how much the heatsink will have to dissipate in order to keep the chip in an acceptable temp range.
B. Raising the clock speed of a chip will increase its thermal output even if there is no increase in the voltage. I have seen an explanation for it but at the moment I can't find one .
Thanks for the input
~jrs
jrs is offline
