Python Base64 encoding with a non-standard alphabet - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 03-19-2014, 08:12 PM - Thread Starter
Terrere's Avatar
Rep: 59 (Unique: 39)
One of my classes requires that I write a command and control server for a piece of malware that accepts commands that are Base64 encoded with a non-standard alphabet. It's not anything special really.
ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/
This is the standard Base64 alphabet.
0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ+/
This is the non-standard alphabet.
I know that Python has a built-in library that handles Base64 conversion, but I can't seem to make it use the non-standard library. Any ideas?
UPDATE: Would replacing the characters after the Base64 coversion is run work? In theory, each character represents a specific numerical value 0-63. If I were to replace the character with the corresponding character, would that work?
Yeahh... that idea won't work...
If you can keep your head about you, when all about you are losing theirs... It's quite possible that you haven't fully grasped the situation.
Terrere is offline
post #2 of 3 (permalink) Old 03-19-2014, 11:41 PM
jvolkman's Avatar
Rep: 32 (Unique: 22)
Your idea of replacing the characters should work. Use string.maketrans to create a translation table, and then use str.translate to use it.
import string
import base64
STANDARD_ALPHABET = 'ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/'
CUSTOM_ALPHABET = '0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ+/'
ENCODE_TRANS = string.maketrans(STANDARD_ALPHABET, CUSTOM_ALPHABET)
DECODE_TRANS = string.maketrans(CUSTOM_ALPHABET, STANDARD_ALPHABET)
def encode(input):
  return base64.b64encode(input).translate(ENCODE_TRANS)
def decode(input):
  return base64.b64decode(input.translate(DECODE_TRANS))
jvolkman is offline
post #3 of 3 (permalink) Old 03-20-2014, 11:41 AM - Thread Starter
Terrere's Avatar
import string
import base64
def encode(input):
def decode(input):
Wow, thanks for the reply. I figured out last night that I could create a for loop to do the translations. When I was doing the conversions, I was using documentation from a report on the malware to compare my conversions. The tail end of the command was correct, but the conversion of the 6 "#" symbols didn't convert well. Your version is actually cleaner and more efficient than my loop.
import base64
import string
custom = "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ+/"
Base64 = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/"
s = ""
encode = "######pslist"
result = base64.b64encode(encode);
for ch in result:
    if (ch in custom):
        s = s+custom[string.find(Base64,str(ch))]
    elif (ch == '='):
            s += "="
The loop also handles all of the padding. I came up with the base loop, but on checking for algorithms I had forgotten the presence of "=" paddings in Base64 and had to steal the idea from someone else.
Thanks again for affirming my thought of substitution.
Terrere is offline
