Full WC Loop Takedown For Sale - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 01-07-2019, 04:09 AM - Thread Starter
Bluemustang's Avatar
Rep: 56 (Unique: 51)
Hi all. Had fun in water cooling for years but I'm simplifying my setup now and selling my water cooling gear. I'm also selling my system that I'm upgrading from (you can also find my system here https://www.overclock.net/forum/1468...l#post27792416 ). All parts will ship in original packaging with insurance to continental 48 United States only, sorry no international. Shipping will be very hard to figure out for so many little items before hand so I will give you a quote and round the price down. Not finding pricing for everything so I'll try to price as fairly as I can for those I can't find. Prices reasonably negotiable.
I only ever ran Mayhems Pastel White and I rinsed the loop out very well running about 5 gallons of distilled through it. Then set it out to dry with a fan on them. The blocks are in very good condition. The GPU block is perfect and that copper look you see is only a reflection from the overhead lights not the copper coming through. Without further ado.
Reeven RFC-02 Six Eyes II Fan Controller - Black $30
Bitspower G 1/4" Temperature Sensor Stop Fitting - Matte Black (BP-MBWP-CT) $5
Bitspower Dual G1/4" High Flow Fitting - Male to Male Thread - Black Matte Finish Model: BP-MBWP-C08 $4
6x Bitspower IG1/4" Extender - Black Matte Finish BP-MBWP-C40 7.5mm $3 each
EK-FC Terminal Dual Parallel 3-Slot $15
Phobya 2-Way Ball Valve G1/4 - Knurled (handle is loose but it worked fine) $5
Alphacool HF L-connector G1/4 outer thread to G1/4 inner thread - Deep Black Model: AC-17045 (New never used) $4
x2 Bitspower BP-WTT-70ML Bitspower Fill Syringe BP-WTT-70ML $2 each
4x G1/4" Plugs (Appear to be black sparkle) $5 all - *SOLD*
2x Bitspower D5 / MCP655 Mod Kit V2 - Black Sparkle Finish BP-D5MA-BK2 (few scratches as shown from trying to line up with with vario speed hole) $35 each - *SOLD*
Bitspower BP-2D5TOPAC-UVBL Dual D5 Mod Top (Acrylic Version) - UV Blue BP-2D5TOPAC-UVBL $70 - *SOLD*
2x (UN)Designs 360 Pump Bracket (for Laing D4/D5 pump) Version 2 - Deep Blue UN-PUMPBKT-360-R2-BL-D $10 each - *SOLD*
6x Bitspower G 1/4" Matte Black Rotary 90 Degree IG 1/4" Adapter BP-MB90R $8 each - *SOLD*
Bitspower G1/4" Matte Black Male to Male Rotary Adapter BP-MBRG 14mm (minor installation scratches) $6 - *SOLD*
3x Bits Power O-ring set II (BP-WTP-O502-BK) 10 Pack (new unopened) $3 each - *SOLD*
14x Gentle Typhoon AP-15 Fans $15 each (shipping savings for multiple) - *SOLD*
Alphacool NexXxoS XT45 Full Copper 480mm Radiator $90 (For both rads i used 30mm screws with a couple washers to connect the push pull fan setup and had to use a few of the original screws. the original screws were horrible and stripped easily, barely managed to remove them. So i'm including 24 of the 30mm better screws i purchased and 32x 30mm + 16x 35mm originals for each rad (i wouldnt use the original, really mushy metal)). The ones i bought needed a couple washers(included) as according to my calipers they actually are 30mm while the originals are a bit undersized. *SOLD*
Alphacool NexXxoS UT60 Full Copper 480mm Radiator (Missing 1 copper plug on the end so put 1 of the blackish sparkle ones on it, blends well) $110 - *SOLD*
MCP655 D5 Vario Pump $60 - *SOLD*
Another D5 Vario Pump (Can't find in my purchase history but it's the same one just in a plain white box) $60 - *SOLD*
EK Supremacy EVO Universal CPU Liquid Cooling Block - Plexi (EK-Supremacy EVO) $55 - *SOLD*
2x EK Gigabyte GTX 970 WF3 Backplate - Black (EK-FC970 GTX WF3 Backplate - Black) (Thermal pads are in place but there are also some extras) $20 each *SOLD*
2x EK Gigabyte GTX 970 WF3 VGA Liquid Cooling Block - Nickel (EK-FC970 GTX WF3 - Nickel) (will need new thermal pads but I have some extra fujipoly pads i can add in for free) $70 each *SOLD*
Bitspower Water Tank Z-Multi 150 - Full Clear Acrylic Version BP-WTZM150AC-CL (As you can see in the pictures this one had some staining near the top, tried to clean off but it wouldnt come out). Based on where it is it must have been from the liquid line of the mayhems pastel white coolant. I never even noticed it until i drained the loop. If using solid colored coolant it shouldnt be noticeable) $20 - *SOLD*
Bitspower Z-Multi 250mm (POM Version) reservoir Product Code: BP-WTZM250P-BK (Never ended up using it as it was too tall) $30 - *SOLD*
Primochill Rigid Revolver Compression Fitting 3/8" x 1/2" Straigh Knurled 10 Pack - Anodized Black (As shown in pictures there are a few with some scratches) $50 - *SOLD*
2x PrimoChill Rigid Revolver Removal/installation Tool (1 unopened 1 used, i will include these for free with the above compression fitting set) - *SOLD*
PrimoChill Rigid Compression Fitting - Fitting O-Ring - 10 Pack Model: F-RCO-10 (8 extra in pack, included free with compression fittings) - *SOLD*
PrimoChill Rigid Compression Fitting – O-ring Packs Of 10 Model: F-RCTO-10 (4 extras in pack, also included for free with compression fittings) - *SOLD*
Bag full of misc used but seemingly fine shape O-Rings (could be for compression fittings but i think likely the bitspower fittings, will include with bitspower fittings purchase)
Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm) MON-PRO-BEND-KIT-3812 $50 *SOLD*
Monsoon Hardline Pro Cutting Kit 3/8 x 1/2 (13mm) $20 *SOLD*
Measuring Kit for the hardline tubing to measure the perfect shapes and lengths (with extra mandrel) $15 *SOLD*
I started out taking pictures of all the items outside of their boxes but it was taking forever so I just finished as shown. Everything is in good shape unless otherwise noted.
I7 4790k 4.7ghz
Asrock Z97 Extreme4
Gigabyte G1 GTX 970 SLI @ 1590Mhz
16gb GSkill Sniper 2200mhz
Crucial MX100 256gb
Samsung F3 1TB
Samsung F3 1TB
Seagate 3TB
Seasonic Platinum 1200w
EK Supremacy Evo
EK Nickel VGA Block x2 w/ Backplates
Alphacool UT60 480mm Rad
Alphacool XT45 480mm Rad
Dual D5 Pump w/ Dual Pump Top
Gentle Typhoon AP-15s x18
Corsair 900D
Operating System
Win 7 64 bit
Qnix QX2710 1440P + 1080P IPS secondary
Benq W1070 Projector on 120" Screen
Mouse
Logitech G9X
Mouse
Mionix Propus 380
Audio
ATH AD700
Audio
Creative X-Fi Titanium
Audio
Logitech X-530
Bluemustang is offline
post #2 of 13 (permalink) Old 01-07-2019, 02:23 PM
PM'ed
Nuka Cola
(0 items)
Eusbwoa18 is offline
post #3 of 13 (permalink) Old 01-07-2019, 02:36 PM
LTSC Consiglieri
skupples's Avatar
Rep: 658 (Unique: 351)
interested in pumps, dual top, large res. PM'd.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #4 of 13 (permalink) Old 02-17-2019, 10:35 AM
Rep: 0
Looks like there hasn't been much action in here for a bit, is this stuff still for sale?
LRAStart is offline
post #5 of 13 (permalink) Old 02-18-2019, 08:58 AM
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
Interested as well....
OneFunGenesis is offline
post #6 of 13 (permalink) Old 02-18-2019, 04:33 PM
Master of Black Snow
Ceadderman's Avatar
Rep: 700 (Unique: 519)
Just Message him fellas. So far as I know, the end of last month communications with him, he was.
~Ceadder
Black snow
(17 items)
Ryzen 7 1800x
ASUS Crosshair VII Hero
XFX RX 480 Black Edition 8GB
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z370 Platform Desktop Memory Model F4-3200C14D-16GTZSK
Western Digital Black
Samsung 750 EVO
Samsung 850 EVO
Samsung 850 EVO
Adata m.2
EVGA Supernova
EKWB Crosshair VI Acetyl Monoblock
Lian Li O11 Dynamic
Operating System
Windows 10 Home 64bit USB
Samsung NU6900
Keyboard
Corsair K55
Mouse
Corsair M65
Other
Xbox Wireless Controller: Winter Forces Special Edition - Xbox One/Xbox One S/Windows 10
AMD Phenom II X6 1100T
Crosshair IV Formula
Corsair Dominator
x2 HITACHI 1TB Deskstars 1TB RAID0
Samsun 750 EVO
EVGA
EK D5 Vario
EK x3 250 RGB
Yate Loon 120x20 (D12SM-12C) Medium Speed Silent Fans
EK Supreme HF Classified
Monsoon 1/2"x5/8" PETG White Hardline tubing.
Monsoon Economy Hardline fittings
EK x3 CSQ Clean Acrylic
EK RX 480 Copper/Acetyl
HAF 932
Operating System
Win7 64 bit Ultimate OEM
Asus VH222H Black HDMI Widescreen
Keyboard
Logitech the OCZ went buhbye adios. Don't know what I'm going to replace it with.
Mouse
Logitech g9x
Mouse
COOLER MASTER Weapon of Choice: M4 Duramesh Pad
Audio
Logitech X-240 2.1 speakers
Other
Creative X-Fi
Other
Sunbeam Rheosmart 3
Ceadderman is offline
post #7 of 13 (permalink) Old 02-18-2019, 11:57 PM - Thread Starter
I see I got a couple messages. For some reason messages to this thread aren't updating me to my email but private messages are so please send me private messages. Thanks for your interest.
PS: If the thread is still open there are still items for sale. I list everything as *SOLD* as soon as I sell it and close the thread when it's all gone. Which reminds me I'd like to leave a note for other sellers, please leave your pricing on sold items listed and only add the word *SOLD* next to the price. This way everyone can get an idea of what similar items are going for.
I7 4790k 4.7ghz
Asrock Z97 Extreme4
Crucial MX100 256gb
Samsung F3 1TB
Samsung F3 1TB
Seagate 3TB
EK Supremacy Evo
Corsair 900D
Operating System
Win 7 64 bit
Mouse
Logitech G9X
Mouse
Mionix Propus 380
Audio
ATH AD700
Audio
Audio
Logitech X-530
post #8 of 13 (permalink) Old 02-19-2019, 07:23 AM
Sent PM. Thanks! Also, this new forum engine is not great at alerting for different things....
post #9 of 13 (permalink) Old 03-01-2019, 02:33 PM - Thread Starter
Sold a few more items as well as the fans. Reorganized remaining items above and sold items below for easier viewing.
I7 4790k 4.7ghz
Asrock Z97 Extreme4
Crucial MX100 256gb
Samsung F3 1TB
Samsung F3 1TB
Seagate 3TB
EK Supremacy Evo
Corsair 900D
Operating System
Win 7 64 bit
Mouse
Logitech G9X
Mouse
Mionix Propus 380
Audio
ATH AD700
Audio
Audio
Logitech X-530
post #10 of 13 (permalink) Old 04-07-2019, 03:31 AM - Thread Starter
Few more items sold. List updated with remaining available items at top.
I7 4790k 4.7ghz
Asrock Z97 Extreme4
Crucial MX100 256gb
Samsung F3 1TB
Samsung F3 1TB
Seagate 3TB
EK Supremacy Evo
Corsair 900D
Operating System
Win 7 64 bit
Mouse
Logitech G9X
Mouse
Mionix Propus 380
Audio
ATH AD700
Audio
Audio
Logitech X-530
You may not post new threads
