FS: Lots of Watercooling Gear - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 06-18-2020, 04:48 PM - Thread Starter
Not New to Overclock.net
Buska103's Avatar
Rep: 78 (Unique: 73)
Timestamps and lots and lots of pictures: https://imgur.com/a/hxBX1Zj
Any questions ask. Shipping included in price for anything over $30.
Alphacool NexXxos UT60 Full Copper Radiator 360mm (60mm thick) - $60 - $$SOLD
fins are all PERFECT, comes with 12x 30mm M3 screws and 8x short M3 screws, small dent in the side
https://www.performance-pcs.com/alph...-ac-14174.html
Watercool WCP D5-VARIO + Watercool HEATKILLER 150 Tube Glass Reservoir + Mounting Kit - $125 - $$SOLD
hairline scratch on the reservoir top, couple marks on the base plate
https://www.performance-pcs.com/wate...-wc-30049.html
https://www.performance-pcs.com/wate...-wc-30204.html
https://www.performance-pcs.com/wate...-wc-30236.html
EK Supremacy EVO CPU Water Block (Nickel/Acetal) + PreciseMount Naked - $45
https://www.performance-pcs.com/wate...-evo-na-d.html
EK-Thermosphere Universal GPU Water Block (Nickel/Acetal) with G80/R600 Mounts - $45 - $$SOLD $35
https://www.performance-pcs.com/wate...sphere-np.html
10x XSPC Compression Fittings plus 8.4ft PrimoFlex Advanced LRT Tubing Onyx Black - 1/2in. ID X 3/4in. OD - $45
64"+10"+10"+9"+8" = 101" = 8.4 ft
EK Compression Fittings plus 7ft EK ZMT Matte Black Tube - 3/8" ID 5/8" OD (9.5mm x 15.9mm) - $60
4x normal
5x 45deg rotary
3x 90deg rotary
32"+14"+12"+11"+8"+8" = 85" = 7 ft
Misc Fittings - all for $25
2x 45deg G1/4 rotary fitting - $4/ea
1x 45deg G1/4 rotary fitting - $4
1x 45deg G1/4 non-rotary fitting - $3
6x stop plugs - $1/ea
2x EK stop plugs - $1/ea
1x EK 3-way T splitter - $4
Fill Port - $5
1x 10mm extender (needs o-ring) - $2
3x XSPC Barb Fittings - 1/2" ID - $6
3x 1/2" clamps $free
Buska103 is offline
post #2 of 3 (permalink) Old 06-29-2020, 09:51 PM
AMD fan
Tobiman's Avatar
Rep: 65 (Unique: 50)
I want the EK compression fittings without the tubes. Pmd.
LIAN LI PC-05SX/SILVERSTONE SX800 LTI
R7 3700X
MSI 2070 SUPER GAMING X
ASUS X570I STRIX
ACER XV340CK
ASUS MG279Q
32GB GSKILL RIPJAWS 3733MHZ C14
Tobiman is offline
post #3 of 3 (permalink) Old 07-05-2020, 06:29 AM
Pinnacle Fit's Avatar
Rep: 24 (Unique: 18)
Pm sent
Sent from my iPhone using Tapatalk
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
Gigabyte Z390 Aorus Master
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is offline
You may not post new threads
