Ryan's New Forum FAQs (unofficial) - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 02-01-2018, 07:01 AM - Thread Starter
News Fiend
ryan92084's Avatar
These questions are getting asked all over the forum so here's a handy repository of the answers.
Here's a FAQ
What happened to the old forums?
Huddler platform is EoL so they were forced to move. The forums have "joined" vertical scope (google them). See https://www.overclock.net/forum/3-ov...ter-three.html and https://www.overclock.net/forum/3-ov...migration.html
Can we go back?
No
Do you know about my xxxx issue?
check the punch list https://www.overclock.net/forum/1779...l#post26579201 to see what they know about and are working on
Where is the Rep?
The rep system is undergoing a complete rebuild. You can read about it here https://www.overclock.net/forum/3-ov...m-rebuild.html
Why is my title ''New to Overclock.net''/where are custom titles?
All is explained here https://www.overclock.net/forum/3-ov...l#post26993641
What happened to rig builder? Where are the rig sigs?
UPDATE Both are now live https://www.overclock.net/forum/3-ov...l#post27313529
How do I make rig sigs hidden/enlarged by default
Go got UserCP>edit signature>See rigs in signatures and choose your option (see image)
How can I make all these subscription/quoted emails stop?
Three steps Make sure to save your changes at the bottom of each page
  1. Go to your subscription page and use the upper right check box to select all threads. Then go to the bottom right use the drop down menu next to the "Go" button to change the notification settings. (see image) If you have several pages of active subscriptions you may have to repeat this. Sorting the list by last post can help.
  2. Check your auto subscription settings in User CP>Edit Options>Default Thread Subscription Mode and turn them off or to no email you don't get auto email subscribed in the future.
  3. Finally the options for being emailed when you get quoted or mentioned are under UserCP>User Tagging>Settings (see image )
If for some reason the above steps don't work you can try disabling UserCP>Edit Options>Receive Email from Administrators but I haven't tested it.
My subscription settings aren't working as expected?
See above but change settings to whatever you desire (off, subscribe but no email, instant email, daily, weekly)
Also make sure "Receive Email from Administrators" is enabled under User CP>Edit Options if you want to receive emails.
My emails for PMs are off/on and I want the opposite?
UserCP > Edit Options > Receive email Notification of new Private message (see image )
How do I jump to the first unread post?
Use the down facing arrow to the left of the thread title. The right facing arrow to the right of the title takes you to the last post (see image). When you are already in a thread there is a button at the top if you have unread posts to jump to (see image) If you haven't visited a thread since the migration the first unread may be wrong until you catch up in a thread
Why can't I get rid of these notifications?
The "Your Notifications" link is currently busted but they are listed towards the bottom of the avatar drop down box (see image ). You can disable quote and mention notifications by hiding them under the tagging options in the UserCP.
How do I upload images to my post and not just have them attached at the bottom of a post?
UPDATE New method https://www.overclock.net/forum/1516...our-posts.html If the list doesn't populate correctly after uploading the image (by attachment manager or drag and drop) you can try using post preview or posting and then editing to repopulate the list. Alternatively you can use the drag and drop upload with [attach] tags (see image)
Why is the editor missing all formatting options?
Change it in UserCP>Edit options (under settings and options on left)>Miscellaneous Options>Message Editor Interface> choose something better than basic for all the old options back
Where are the smileys?
In the more advanced editor. See above for how to change.
Can I get rid of the Latest Discussions sidebar?
Yes https://www.overclock.net/forum/1516...l#post26577065
Why is everything so bright? Make it darker
UPDATE Dark theme is now live https://www.overclock.net/forum/26712401-post57.html
I have a bug to report or a feature to request!
First double check the punchlist (See above) and if it is unlisted you can try submitting it here https://www.overclock.net/forum/1779...it-bug-report/
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #2 of 3 (permalink) Old 02-16-2018, 06:19 PM - Thread Starter
News Fiend
ryan92084's Avatar
Reuploading the images since the links keep breaking
Name:	Subscription change.jpg
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #3 of 3 (permalink) Old 03-07-2018, 09:01 AM
VS Guy
Overclock_Admin's Avatar
Thanks for posting, made sticky.
Jeff M
Testing Rig
(0 items)
Overclock_Admin is offline
