Lost reputation and flame - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 03-05-2019, 11:59 PM - Thread Starter
go4life's Avatar
Rep: 588 (Unique: 418)
Hello all.
Just wanted to inform that I have personally lost several hundred reputation points and flame, and have noticed that others have lost theirs as well.
Good luck team OCN
From the cold North
|i9 9940X @ 4.6ghz 1.22v|
|MSI X299 PRO|
|MSI RTX 2080 Ti Duke @ 2ghz/8200mhz|
|4x4gb Corsair Vengeance @ 4000mhz CL17-20-20-35 1T|
|1tb Samsung 970 Pro M.2| |2tb Intel 660p M.2|
|Corsair AX1600i|
|EK Velocity| |HWLabs Black Ice Nemesis 420 + 280| |EK-D5 PWM G2|
|LD PC-V7|
Operating System
|Custom Windows 10 Enterprise x64|
|Acer Predator X34P 3440x1440 @120hz IPS|
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
|JBL L890| |2x Advance Acoustic MAA-705 mono amps| |Emotiva XDA-2 DAC receiver|
go4life is offline
post #2 of 6 (permalink) Old 03-06-2019, 12:26 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 45 (Unique: 27)
I commiserate;
The loss is indeed staggering, one hardly feels the same person anymore! Walk out the door, neighbours look at you sideways; "wasn't he the one..?"; go to the super, cashier now thinks you're there to rob them. Why, your dog looks at you funny now; talk about dodgy, innit.
The sheer insult, the degradation.
Had two flames once, now none.. so appalling was the loss, trully.. that i never really did anything about it. I do however hope you find the strength to recover from this.
Edit: Here, some rep for you. A small fix but, nonetheless.
Pride, honour and purity.
Aenra is offline
post #3 of 6 (permalink) Old 03-06-2019, 12:48 AM - Thread Starter
go4life's Avatar
Thanks, I do not know what to say other than that I agree... All is to much, and yet to little. As if all is lost, yet always that small hope of a better tomorrow.
Best wishes to you Aenra
From the cold North
|MSI X299 PRO|
|Corsair AX1600i|
|LD PC-V7|
Operating System
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
go4life is offline
post #4 of 6 (permalink) Old 03-06-2019, 03:07 AM
News Fiend
ryan92084's Avatar
You should give the following a read although ignore the 10 starting rep part that was changed to 0
Quote: Originally Posted by BFRD View Post
Just a quick update. All of the coding is complete and turned in to VS. To repair the inflated REP values left in the previous iteration a series of SQL queries needs to be executed. These queries are quite intensive and "touch" every user more than once. Due to the intensity of this VS needs to find an appropriate time to schedule this to be done. It is unclear to me if they will stop the site for a few minutes or not. Once that is complete the VS QA team will need to approve my changes to the site templates. I have been unable to wrestle an ETA for that process. So to recap what needs to happen and what changes the user's will see.
  • All Reputation values will be reset to reflect only 1 rep point given
  • Unique rep will be calculated and stored 1 point for each unique person to rep you
  • 10 rep points will be added to each user to reflect the starting rep of 10 for new users
  • All users will top out at 5 flames once they reach 750 rep points
  • Staff members will not be able to display rep points, flames, or receive rep
  • A site "promotion" will automatically move users into a "For Sale Enabled" usergroup at 35 rep points
  • The For Sale forum will be limited to those users in this group regardless of previous access
It should be noted that some users will see a MASSIVE drop in reputation. Previously, the system was setup so that rep-power (the number of rep points a member can give) increased with the number of days they were a member, the number of posts they made, and the amount of rep they had. I believe that my rep-power was roughly 2,500. The system should have been configured to never allow more than 1 point given at a time. So, if I had given reputation to a new member just once they would have had a rep score of 2,510. Once the system is updated that user would be reset to have a rep score of 11 (one from me and the 10 initial). Like I said, a MASSIVE drop. It should also be noted that a few members may see an increase in rep. It appears that the new system started users off at 0 rep points instead of 10. So, if you had 1 rep before you will end up with 11. Granted that won't affect many users. Also, the initial 10 does not count toward unique rep. The user that started a 1 and then moved to 11 would show only 1 unique rep. Users with only the initial 10 will not show any value for unique rep.
Please understand that these changes are happening across the board. No user is exempt. No amount of complaining will change your score from the number to which it gets reset. The values are calculated from the data in the tables and changed with prejudice.
If I find out more information about timing I will post it here.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #5 of 6 (permalink) Old 03-06-2019, 03:44 PM - Thread Starter
go4life's Avatar
Thanks for the update BFRD & ryan92084
From the cold North
|MSI X299 PRO|
|Corsair AX1600i|
|LD PC-V7|
Operating System
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
go4life is offline
post #6 of 6 (permalink) Old 07-02-2019, 10:27 PM
technologist
neurotix's Avatar
Rep: 356 (Unique: 203)
This meant more to me than a number ever could:
11 pages of people saying I was helpful and personally thanking me
Ryzen 9 3900X @ 4.5GHz CCD0 1.375v VID OC, 4.2GHz CCD1- 1900Mhz fclk/uclk
ASUS ROG Crosshair VIII Hero BIOS 1201
EVGA GTX 1080ti FTW3 2025/5940MHz
EVGA RGB SLI HB Bridge
G.SKILL Flare X B-Die 3200 C14 @ 3800MHz C14-16-15-15-30-48 1T 1.475v GDM off
Samsung 970 Evo 500GB m.2 2280 PCI-E NVMe SSD
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Samsung 840 Evo SATA 256GB
COOLERMASTER V1000 (Seasonic 1000w 80+ Gold)
Arctic Cooling Liquid Freezer II 38mm 360mm AIO
Anidées AI-AUREOLA RGB fans x7
Prolimatech PK-3 Nano 30g tube
Anidées AI CRYSTAL AR3 RGB Midtower
Operating System
Debian Linux 10
Operating System
Win10 X64 Pro 1903 (gaming only), stripped down, updates blocked, Firewalled.
LG 34WN80C 34" 3440x1440 21:9 IPS, 300 nit, HDR
Keyboard
GMMK v2 104 key | Kailh Box Jades | HyperX PBT pudding (for now)
Keyboard
OCN Ducky DK1008 MX Blues
Keyboard
Corsair K70 Lux red led/MX Reds
Keyboard
Rosewill K85 RGB Kailh/Kaihua Blue switches
Keyboard
Ducky One 2 RGB fullsize
Keyboard
Doraemon keyboard- E-Element Z-88 RGB fullsize, Kailh Box White, Cherry Blue O-Rings, White/Baby blue generic Amazon Tai Hao caps
Mouse
CM MasterMouse MM520
Mousepad
SuTechSmart aka generic giant thicc cloth RGB mousepad at the top of the Amazon ranking. ($20)
Audio
Logitech G230 red
Audio
Logitech Z2300 2.1 120w 8" sub, w/ 40w satellites
Other
Phanteks RGB 5050/Digital RGB strips
Other
Respawn Black/Gray Racing Chair
i5-7600k 5GHz 1.32v
ASUS ROG Z270H Strix
Sapphire R9 380X Nitro 1200/1500mhz
G.skill Ripjaws4 DDR4-3000 CAS15
Western Digital Caviar Blue 320gb
Samsung 850 Evo 256gb
OCZ ModXStream Pro 500w
Corsair H60/PK-3
Thermaltake Core V71
Operating System
Win10 Home
2x ASUS V236H 1080p
Keyboard
Corsair K70 Lux Blue LED Cherry MX Blue
Mouse
Cooler Master
Mouse
Thermaltake GAMMA
Raspberry Pi 3B
Optical Drive
DENON DCD-560 CD Player, dual integrated 20bit Burr Brown PCM61P DAC's
Operating System
Kodi 17.2
ASUS V238H 23" 1080p 60 Hz
Audio
Pioneer SX-255R Receiver, 4x 100w
Audio
TECHNICS SB-A32 Floor Standers, 4x8" polyurethane woofers, 100w/cabinet, 1" His and 3" Midrange
Audio
Polk Audio PSW-505 300w subwoofer, replaced woofer with CT SOUNDS TROPO 12" 4Ω DVC car sub wired in series, 8Ω, 300w
Audio
Kenwood GE-4030 Stereo Graphic Equalizer
Audio
TECHNICS RS-T18 dual tape deck
neurotix is offline
You may not post new threads
You may not post replies
